Throttle Bodies not working? - ZX6R Forum
post #1 of 6 Old 04-05-2017, 09:38 PM Thread Starter
So I was putting my bike back together after a valve adjustment and it was going smooth until I tried to start it.... nothing. I double checked all the connections and it's good. I've had my battery on a tender and the throttle Actuator Control Module was making a weird noise and then it went away then after did a high pitch noise kinda like when the fuel tank has a lot of pressure in it. What could it be? I spilled a little gas on it but quickly cleaned it up when taking the tank off that's my only guess. I took off the throttle system to remove the control unit but didn't want to take it all apart.
Here is a video link so you can see what I'm talking about:
ChandlerO is offline
post #2 of 6 Old 04-05-2017, 10:03 PM
If the battery is bad or dead, the battery tender might not actually be able to bring it back to a full charge. Have you tested the battery with a multimeter to see if it is putting out at least 12.5V?
post #3 of 6 Old 04-05-2017, 10:31 PM
Your battery is dead as fuck
Are ur battery connections on there tight? Are they clean?
post #4 of 6 Old 04-06-2017, 04:14 AM
Check the where the negative battery cable grounds to the bike.
PainfullySlo is offline
post #5 of 6 Old 04-06-2017, 11:56 AM
all the above
post #6 of 6 Old 04-09-2017, 02:06 AM
dead man switch ?
StarWing is online now
DIY: 2013+ Syncing Throttle Bodies bobbehp Mechanical and Technical 18 03-13-2015 04:33 AM
Throttle not working kawboy93 Mechanical and Technical 6 12-03-2014 10:11 AM
Kawasaki 636 noisy throttle bodies Kirt636 The ZX6R 0 10-22-2014 02:32 PM
Keyless cap & throttle bodies sync Rickthefix Mechanical and Technical 10 10-13-2014 01:16 PM
FS: 07 zx6r throttle bodies zxrider432 Classifieds 0 12-10-2012 01:45 PM
