Cam Tensioner Noise solution? - ZX6R Forum
post #1 of 2 Old 04-09-2017, 07:18 AM Thread Starter
I Ride: 2006 ZX6R
I just saw on a fb post I can no longer find that showed videos of before and after this procedure. He got it to go out one tick without having to go through the normal manual steps of backing out bolts until it clicks.
What he did was put it in 5th/6th, shut off motor, pull in clutch and walk backwards slowly and let out the clutch. Apparently that gives the bike enough slack in the timing chain to adjust out one click.
Has anyone heard of this? The videos are convincing.
06 ZX6R - Vortex Rearset, GPR V1, Driven Clipons (soon), Pazzo clutch lever, CNR Brake lever, Secondary Butterflies removed, PCV+Autotune, Micron Serpent Headers/Midpipe, Yoshimura RS-5 slipon, MotionPro Throttle, Aftermarket Adjustable Levers, Ram Air mod, Jumper mod
03 EX250 - Wife's current whip
eulark is offline
post #2 of 2 Old 04-09-2017, 07:20 AM Thread Starter
I Ride: 2006 ZX6R
From Kawi forums: run it around the yard and get it in 6th gear. shut it off. raise the rear off the ground. rotate the rear tire a few times by hand. get someone to help so it doesn't fall over with you. this will alow the cct to adjust a notch or two. the best thing to do is get a new manual adjusting type cct from APE. i replaced mine at about 6000 miles. it is very common for the stock cct to be noisy. if you do a search you will see.
eulark is offline
G1 Loud rattle/rubbing noise Cam chain tensioner? Mishy Mechanical and Technical 9 03-19-2017 07:42 PM
brodas !! no more noise, i reset my cam shaft tensioner ! renzovc16 The ZX6R 5 05-30-2015 07:25 PM
Need some advice. 05 636 cam chain tensioner Shoebaca Mechanical and Technical 30 05-20-2014 03:38 PM
Cam chain tensioner too tight, please help!!! zx6ixxer The ZX6R 48 05-09-2013 01:44 PM
Cam chain and tensioner tdwilliamson Mechanical and Technical 3 05-09-2012 02:44 PM
