2014 ZX6R Speigler Rennsport brake line issue - ZX6R Forum
post #1 of 6 Old 04-10-2017, 05:39 AM Thread Starter
blank's Avatar
I Ride: 06 CBR600RR (Sold), 2010 R1 (Sold), 2014 1199R, 2014 ZX6R
Hey guys, not sure if anyone else has the 13+ Speigler Rennsport brake lines Y configuration. But my lines were almost 7 inches passed the caliper. I've installed these lines before on my other bikes without issue. Several buddies of mine experience this too with their front and rears. Its so long that I cannot use stock brackets to make it neat like the stock rubber lines. I double checked the label and made sure it was correct.
My mounting setup.
Line starts in front of the master, mounts to the clip then behind the forks and to the caliper. If I compress the forks during hard braking, the lines would touch my radiator.
Looking for suggestion.
Thanks
blank is offline
post #2 of 6 Old 04-10-2017, 06:49 AM
I Ride: '12 zx6r track bike
If you decide to go with a front suspension upgrade kit (Racetech for example) it will lengthen your front forks approx. 15 mm, so you may want the extra length. If not, contact the manufacturer. I will say, you should check out video of MotoGP races: the front brake lines on most of those bikes are way long!
post #3 of 6 Old 04-10-2017, 09:18 AM
As I went with a 2 line setup, I can't provide any insight....
post #4 of 6 Old 04-10-2017, 10:43 AM Thread Starter
blank's Avatar
My buddies went with 2 line setup and he has the same issue. I called Spiegler and they said that their lines had added length designed for race setups. My buddies bike is race prepped with fork extenders and even his 2 line setup is are wicked long.
I got the measurements from Spiegler 8.2in to the 950 (T) 22.8in Right, 21.2in with grommet left.
S-KA0354 is correct. But these lines are wicked long
blank is offline
post #5 of 6 Old 04-10-2017, 08:14 PM
Weird. I went with the two line setup from Spiegler as well, and I almost though mine were going to be too short. They definitely don't have any extra length to them. I got my set from Sportbike Track Gear.
post #6 of 6 Old 04-10-2017, 08:37 PM
I Ride: 2014 Kawasaki ZX-6R
Are you sure you are mounting them correctly? They don't mount behind the forks, it should be around the outside front of the forks like in this picture.
Martillo y Mantequilla #99
Brake line sizes 2000 zx6r docflipside The ZX6R 4 07-15-2016 10:22 PM
G1-2 hugger fit j1-2 salami Mechanical and Technical 2 06-21-2016 01:36 PM
