05 Zx6r 636 stopped again - ZX6R Forum
post #1 of 2 Old 04-10-2017, 12:36 PM Thread Starter
I Ride: 2005 Kawasaki ZX6R
I recently posted a thread about my 05 zx6r but i got it fixed the first time but it quit on me again after a big storm. No idea how the rain messed with it to the extent for it not to run but i guess anything is possible. I took it back apart to see if it was what it was before but now when i turn the key on to start it, it reads i have no or low gas when i have 3/4 tank of gas. I checked the fuel pump because my buddy laid my tank down when it was charging and touched the positive gator clip against the pump. I put a rag over the pump flow and cycled the key and gas came out. I am guessing the injectors are clogged but came here for more opinions. I also know the compression but I dont know if that will be the reason.
1st cylinder=175
2nd cylinder=175
3rd cylinder=165
4th cylinder=180
I am not to sure on what they're suppose to be according to the forums they should be around 190. If you have any thought on why it stopped again please help me out
Zx6r 05
mday97 is offline
post #2 of 2 Old 04-10-2017, 02:39 PM
Different gauges and cranking times and battery charge etc will net different numbers......
Your numbers look fine although I would rather not see that 15psi spread *that is over 8%..... I like to see within 2-3% difference
I doubt your injectors are plugged, but...........
did water get in the fuel?
or did it blow in under the tank and your stick coils are marginal and once wet not sparking the plug?
electrical connectors get wet?
yada yada yada
Another Track build 2014 636 motor in 09 ZX6R Evil Cupcake Pictures 14 12-31-2016 09:10 AM
ZX6r 636 buying question??? FlyBy The ZX6R 17 02-04-2010 04:38 PM
