Code 35 Immobilizer amplifier malfunction - ZX6R Forum
  • 2 Post By BandZZ
  • 1 Post By HIGHDEFMOTO
post #1 of 5 Old 04-11-2017, 12:55 AM Thread Starter
I Ride: 636 06
While I was changing cooling liquid I dropped my tank and fuel hose was still attached
As you can see on the picture the delivering pipe is probably damaged
FI light blinks and the code is surprisingly "35 Immobilizer amplifier malfunction"
I'm confused, as I thought that I can simply change broken parts and job done
Is it possible that immobilizer is shuting down because of broken pipe or it can be dameged as well?
ID:	61426   Click image for larger version
BandZZ is offline
post #2 of 5 Old 04-11-2017, 04:16 AM
Do u have a European model zx6r?
post #3 of 5 Old 04-11-2017, 11:51 AM Thread Starter
I Ride: 636 06
Yes, it is UK one.
BandZZ is offline
post #4 of 5 Old 04-17-2017, 03:14 PM Thread Starter
I Ride: 636 06
Case closed.
It was loose wire.
RJ2112 and HIGHDEFMOTO like this.
BandZZ is offline
post #5 of 5 Old 05-01-2017, 07:28 PM
HIGHDEFMOTO's Avatar
I Ride: 2005 ZX6R
Hey there. Can you tell me more on the loose wire? Where/what/how?
I just got the code too and it has to something like that as I drove it in the garage and took fairings off for another issue and now won't start and shows code 35. So I guess I bumped a wire or something somewhere.
Cheers
EDIT: This is funny to me but as soon as I wrote this I remembered that on the inside on the right hand fairing is the actual Immobiliser Amplifier unit that plugged into the bike wiring. So when I took the fairings off it came off with it. So dumb, but I realized this mistake within 30 mins of this. Imagine if i didn't figure this out for days. I would have been in a bad mood 😒
Anyway, I'll leave this here as a reminder to myself and others to always backtrack what's you've done to find the problem.
Pic attached is the unit removed from the fairing and next to plug.
Happy days.
HIGHDEFMOTO is offline
FI code 67 error ticky The ZX6R 4 11-30-2014 04:59 PM
Zx6r HELP! iDriftNak3d Mechanical and Technical 22 05-14-2013 11:07 PM
immobilizer amplifier malfunction ozzynmax Mechanical and Technical 1 09-05-2012 02:51 PM
07 zx6r Fuel ECU Sub-Throttle ?? fitter07ZX6R Mechanical and Technical 21 03-29-2012 07:16 PM
07 won't start! Help! bowhunter11 The ZX6R 42 03-18-2012 09:10 PM
