STUCK oil filter!!!! WTF?!?! Can I heat it? - Page 3 - ZX6R Forum
 26Likes
post #31 of 33 Old 04-18-2017, 02:45 PM
Originally Posted by the prophet View Post
Keep lookin for that oil, eventually you will see it. Like the man said, hand tight is not gonna be enough.
LOL, the 65,000+ miles on my bike says different. Same thing with my cars/trucks and many hundreds of thousands of miles. Hand tight is plenty (and you can check it after the first ride or two to make sure it's still tight if your are worried about it).
Twistee likes this.
post #32 of 33 Old 04-18-2017, 03:05 PM
Twistee's Avatar
I Ride: ZX6R G2 (99)
I've changed every oil filter on every bike - both road and track - that I've ever owned/co-owned/ridden. I should have bloody shares in Silkolene and K&N. Never - not even once - have I had oil escape from around a filter. Not once have I ever had a filter come loose. Not once have I put one on more than hand tight. The track bikes may have had them lockwired, but innumerable road miles later... Anyway. It doesn't matter. It's your bike, and you can put on the filter how ever you choose.
But, please, if you're selling it on, loosen it to a sensible level before its ridden away!
... hand tight would be just fine, thank you.
Twistee is offline
post #33 of 33 Old 04-23-2017, 06:44 PM
MrEsky's Avatar
To fuel the debate a little....
I hand tight and then bump it a little with a filter wrench.
To be fair, I have accepted that I have bitch hands and have to compensate with tools.
MrEsky is offline
2013 oil filter wrestling. GEB Mechanical and Technical 12 10-03-2014 07:44 PM
Oil Explosion badgerninja Mechanical and Technical 32 07-22-2014 05:27 PM
Rotella T6 5W-40 carotte Mechanical and Technical 57 07-31-2013 10:03 AM
Oil Filter torque Settings ZX6R_C1H The ZX6R 13 06-27-2009 03:28 PM
