STUCK oil filter!!!! WTF?!?! Can I heat it? - ZX6R Forum
 26Likes
post #1 of 33 Old 04-12-2017, 08:50 AM Thread Starter
MeanMachinzx's Avatar
I Ride: 2013 Zx6r, 1999 Zx7r (sold), 2006 Zx6r (sold)
Hey guys,
So I'm doing the final preps to get my girl back out on the street and I go for the oil change, drain the oil...etc. but my friggen K&N filter is like WELDED on there.
I've tried everything, oil filter wrench, vice grips, that god damn shitty 17 mm bolt instantly stripped.
Would it hurt to heat up the filter to try and remove it? Heating causes expansion...maybe it'll work? Anyone heated up a filter before and did it work?
MeanMachinzx is offline
post #2 of 33 Old 04-12-2017, 08:55 AM
Addhoc's Avatar
Dont heat the filter. Thats not going to end well. Take the fairing off of that side. Shove a screwdriver all the way through the filter and turn. One of two things will happen:
1) Filter comes off
2) Filter comes off in pieces with out the threaded end at which point you use vice grips to get the rest of that fucker off
MrEsky likes this.
Addhoc is online now
post #3 of 33 Old 04-12-2017, 08:58 AM
I use a pair of channel lock pliers across the end of the can.... open the jaws up until you can squeeze it across the end, and let them crush into the can. That will give you enough leverage to twist the filter and break it free. You might have to repeat it once or twice to get the gasket to break free.
It will mangle the end of the old filter.... but you don't really need to be concerned with that.
When the filter does come off, make D@MN sure, the O ring comes off as well. You don't want to have a stack of them on the case, it will never seal.
When you install the replacement, use some of the old oil to lubricate the new filter's O ring so it won't cook onto the case and cause this grief the next time.
WERA689, Indy and Twistee like this.
post #4 of 33 Old 04-12-2017, 09:53 AM
Yep Like RJ said.. Channel locks..
My K+N worthless nut that would not fit any socket properly just rounded off.
Used a Large set of channel locks, crushed the hell out of the filter getting a good bite, So use a oil drip pan under it when taking off..
Going back on, don't use a K+N many issues lately with them leaking at bad welds. A dab of oil on the O-ring and hand tight.
Strider and Twistee like this.
Indy is online now
post #5 of 33 Old 04-12-2017, 11:01 AM
The nut on the end of the filters work well if you don't tighten it to 70 ft lbs of torque. Oh and fill the filter with oil before you put it on. It lubes the threads and primes the oil pump in one action.
Indy and MrEsky like this.
the prophet is offline
post #6 of 33 Old 04-12-2017, 12:18 PM
Twistee's Avatar
I Ride: ZX6R G2 (99)
I have no idea why people feel the need to torque down an oil filter to outrageous levels.
Add <technical term> a dollop </technical term> to the new filter and a smear of oil to the o-ring. Install only hand-tight (assuming you don't have the grip strength of a steroid-enhanced gorilla speedlining PCP).
I recall spending over twelve hours (!) under a car with a mallet and drift s-l-o-w-l-y removing the metal bracket of an oil filter after using the screwdriver method, because whatever chimp had installed the last one had gotten VERY overenthusiastic.
Indy and Gawernator like this.
Twistee is online now
post #7 of 33 Old 04-12-2017, 01:05 PM
Screwdriver method has worked for me through 2 filters, the stock filter and a K & N that rounded off. Usually need to hammer it through the middle or else it'll start peeling the outside of the filter. I don't have channel locks so never tried that.
As far as heat, I wouldn't go any further then maybe trying to let the bike sit in the sun.
RedAndBlack is offline
post #8 of 33 Old 04-12-2017, 01:14 PM
Gawernator's Avatar
What worked for me was crushing the filter with vice grips, then attaching more vice grips to the first vice grips and using that as a lever to spin it off. Factory gorilla tight. FYI guys hand tight isn't tight enough for our bike according to the service manual.
sbk1198 likes this.
Gawernator is offline
post #9 of 33 Old 04-13-2017, 11:42 AM Thread Starter
I both lubed the filter and then hand tightened that sucker (not with the strength of a troglodyte), just normal hand tightened. I'm perplexed as to why this thing is stuck so severely.
Twistee likes this.
post #10 of 33 Old 04-13-2017, 12:14 PM
Twistee's Avatar
Some people go crazy with their thinking that an oil filter needs to be fastened with crazy levels of torque so that only the turbine of an oil tanker could remove it.
Are you terrified and screw down the filler cap to insane levels too? No? So what makes you think your oil filter is going to be fired across the road from firing up the engine after a change?
post #11 of 33 Old 04-13-2017, 01:29 PM
Hand tight is never enough for me. You gotta do a bit more than that. Not much but more. I had a filter on my car back off enough to start pouring oil but luckily I caught it before it leaked too much. Thanks Jiffy Lube.
post #12 of 33 Old 04-13-2017, 01:47 PM
Twistee's Avatar
The problem with "hand tight" is that there's no actual definition. It depends on your own strength. That said, the only time I've ever needed a filter wrench is to get one off.
The advantage we have is that we can detect leaks, unusual noises, etc far more readily than with a car. Most car drivers don't bother to take any notice unless a warning light flashes up. If you've got a leaking oil filter, that back end slide as it's coating your wheels is usually a lot more effective an indicator that there's a leak than any warning light.
post #13 of 33 Old 04-13-2017, 02:21 PM
Hand tight is never enough for me. You gotta do a bit more than that. Not much but more. ...................
I was taught contact, plus at least 1/4 turn.....
Indy, Gawernator and Twistee like this.
post #14 of 33 Old 04-13-2017, 02:46 PM
scoot33's Avatar
I Ride: zx6 j2
a filter strap is a good thin to use ,i sometimes get them tight on hgv truks semis in usa language ,they get that tight that i got to use a 1/2 breaker bar with a filter strap so it will fuck that filter off https://www.google.co.uk/url?sa=i&rc...92206307796596
zx6r j2 mods done ,,
scoot33 is offline
post #15 of 33 Old 04-13-2017, 05:43 PM
I Ride: '12 zx6r track bike
The manual specifies 17 N-m
If you're worried about it loosening put a hose clamp on it and then safety wire to a fixed point.
2013 oil filter wrestling. GEB Mechanical and Technical 12 10-03-2014 07:44 PM
Oil Explosion badgerninja Mechanical and Technical 32 07-22-2014 05:27 PM
Rotella T6 5W-40 carotte Mechanical and Technical 57 07-31-2013 10:03 AM
Oil Filter torque Settings ZX6R_C1H The ZX6R 13 06-27-2009 03:28 PM
