Changed spark plugs now low idle and stalls - Page 2 - ZX6R Forum
 7Likes
post #16 of 20 Old 04-14-2017, 01:59 PM Thread Starter
Yeah it ran fine before new plugs, the far right header pipe if sitting on bike doesnt get hot like the others. I pulled the plug and it had spark even put the old one back in and checked the gap and even used a torque wrench to put them in. The video i watched on how to change them said to take the carbs off to get to the plugs which i later found out i didnt need to so could that have anything to do with it?
DDAW22 is offline
post #17 of 20 Old 04-14-2017, 02:15 PM
It could, only if the carb wasn't properly seated in the intakes properly.
I use a light coating of silicone in the intakes to help them slide in.
Have you confirmed that cylinder is getting spark?
Does it have a stick coil? swapped with another cylinder?
post #18 of 20 Old 04-14-2017, 02:20 PM Thread Starter
I checked for spark and it did spark, i was thinking of loosening the clamps on the carb to make sure its pressed down all the way.
It does have stick coils but i havent swapped with any others
DDAW22 is offline
post #19 of 20 Old 04-15-2017, 07:55 AM
If one cylinder is cold, it has to be missing fuel, air, or spark.
Since you know it's sparking, and the other cylinders are getting all three..... I'd be checking out the injector for that cold cylinder. Make sure the wiring is good and the electrical connection is good.
post #20 of 20 Old 04-15-2017, 08:02 AM Thread Starter
I noticed also that if i have the choke on all pipes will heat up but after I turn it off the one pipe will begin to cool down
DDAW22 is offline
low idle , rpm , spark plugs , stalls
Idle Control Wire Broke. bike stalls pudzey Mechanical and Technical 3 03-31-2016 04:00 AM
Stalled at idle after new spark plugs yar786 The ZX6R 23 03-04-2011 06:27 PM
Idle Control Wire Broke. bike stalls Sick&Quick The ZX6R 5 07-01-2009 05:14 PM
