Engine Case Damaged at Sprocket Cover Mount - ZX6R Forum
  • 1 Post By RJ2112
post #1 of 6 Old 04-13-2017, 09:14 PM Thread Starter
Picked up this 01 6R and have an issue with the case where the sprocket cover attaches.
(Disclaimer: Having this area built back up and retapped... so I am going to resolve it.)
However, I have some riding buddies who have the same scenario from their "catastrophic chain failures". They claim it is not an issue and I am making a big deal out of nothing... However, this being the bolt which holds the spacer on the rear of the sprocket cover, I cannot imagine this is advisable, but I am wondering how many people, if any on this forum ride with this broken off.
Thanks in advance,
Seth
Siburns is offline
post #2 of 6 Old 04-14-2017, 06:06 AM
Have a picture a little further out..
Hard time figuring out the location. Mine's intact so far. I think. lol.
post #3 of 6 Old 04-14-2017, 06:25 AM
x2. I actually just pulled a destroyed sprocket cover off yesterday and I'm still not sure where that picture is lol.
capitalcrew is offline
post #4 of 6 Old 04-14-2017, 10:27 AM Thread Starter
Sorry for that. I am not with the bike right now, but I grabbed a screenshot for clarification. The circled pin which the sprocket cover threads into... The mount pictured is where that pin threads into the engine case.
Thanks again!
Name:	sprocket cover.jpg
Siburns is offline
post #5 of 6 Old 04-14-2017, 11:51 AM
I don't think I would get very excited about that one, TBH.
If it's the mount for the stand off that holds the cover over the front sprocket, and it's not caused a crack in the engine case to allow an oil leak.... probably not all that significant. You still have at least two screws holding the cover in place, which should suffice. Not a load bearing member.
If you can, I would however use some metal epoxy and bond the mount back in place so you could use all three mounting points.
Indy likes this.
post #6 of 6 Old 04-16-2017, 12:50 AM Thread Starter
Thank you!
Siburns is offline
Question about engine cover gaskets jdotkdot Mechanical and Technical 2 04-17-2016 12:08 PM
Replacing engine cover bolt oscar07202 Mechanical and Technical 7 03-31-2016 07:27 PM
03-04 zx6r bent frame slider......engine mount bolt part number? PLUJ Mechanical and Technical 3 04-21-2014 05:36 AM
2006 ZX6R Sprocket Cover Removal Aeon87 Mechanical and Technical 1 02-09-2012 10:02 AM
