Doing Valve Adjustment - CAM markings? - ZX6R Forum
  • 1 Post By riverszzr
  • 1 Post By stangn99
post #1 of 12 Old 04-15-2017, 04:27 PM Thread Starter
Hi all,
I'm attempting to do a valve adjustment by myself for the first time. I've measured and all exhaust valves are out of spec, along with most of the intakes.
I'm at the part where I have to rotate 1,4 to TDC and removing the 20 bolts.
One thing I'm unsure of is the markings on the cams.
I can't for the life of me locate ANY markings on the cams. Am I just looking in the wrong place? I've watched some videos online and noticed others had their cams marked on the inside (facing towards the engine)
Could it possible that the 2006 just didn't have markings?
stangn99 is offline
post #2 of 12 Old 04-15-2017, 05:41 PM
I have a 2006 600RR.. The markings are a mother, to see in the first place.
Second, it's even worse putting them back.
I know it sounds and IS a pain in the ass but you really should consider pulling the engine.
I WILL NEXT time.
If you don't, and I don't blame you which is why I didn't. (think PainFullSlo ) suggest I pull engine. Your going to need a mirror. The exhaust cam is the easiest to see, with the EX facing the headers. The IN on the intake is nuts.
NOW if you decide to not pull the engine. ONCE You find the marks. Get a Paint PEN.
Use some carb or brake cleaner on a Q-Tip and clean the area on the valve side of the cam and make marks that are DIRECTLY behind the EX and IN marks on the front you need a mirror to see.
They really need to be exact, because those marks are what your going to have the best chances of getting the cams facing correctly when they go back in.
I also then marked at the 12 oclock position the cam and the chain. TAKE pictures of that also.
ALSO take twice the number of pictures you think you will need, from 4 different angles of the cam marks and MOST importantly the LOBE positions. Take notes. The crank was on 1/4, I COULD check the following valves right before I took it apart.
Lastly, having a spare set of hands when you put the cams back in to keep the chain in position while the cam holder is torqued up is just about a must. I imagine practice makes perfect. It's just I did not have any before starting.
Doing the above for a lay person like myself is a must, and I didn't take enough pictures or notes. Since it was over a week before the shims cam in.
post #3 of 12 Old 04-15-2017, 05:46 PM
on 2006 zx6r the markins are located on the outer side of the cams sprockets. They are facing the frame, that's why you cant see them.
on this videos it shows clearly where those IN, EX markins are.
but let me ask you, when you took valve clearance measurements your crank should have been already on 1,4 position. How come you are asking this question before taking cam over off?
goblin is offline
post #4 of 12 Old 04-15-2017, 05:57 PM Thread Starter
https://www.youtube.com/watch?v=OOzUREHmJis
Thanks so much for this video. I'll take a look to see if I can see any markings on the outer side of the cams.
When I measured the clearances I did them in order from left to right, instead of what the manual suggested. It was just easier to keep track. I measured at 1,4 and 2,3, then rotated to 1,4 again before undoing camshaft tensioner and removing the 20 bolts.
Have I done something wrong? This is a serious learning curve for me, and I knew the risks getting into it...So it's all good if I did.
stangn99 is offline
post #5 of 12 Old 04-15-2017, 06:03 PM
Try this chart.. don't remember if it had the corrected tolerances on it. SO DOUBLE check.
Great video, notice not in bike..
Great catch goblin, that was the reason I said use a mirror. I just wasn't clear why.. LOL..
OP,, read the entire section a dozen times. Do everything in order.
Details like putting the cam chain tensioner back in before rotating the engine IS HUGE.
(don't ask)
Name:	shim measurment chart.jpg
post #6 of 12 Old 04-15-2017, 06:14 PM
you were not supposed to take measurements at 2,3 position. At least the service manual does not say that.
http://service.tanga-moteurs.ro/data...e%20Manual.pdf
Page 2-26. It tells on which cylinder TDC which valves to measure.
But I honestly think they messed up #1 and #4 TDC's. I believe where they say #1 TDC you should read #4 TDC, and vice versa.
goblin is offline
post #7 of 12 Old 04-15-2017, 06:56 PM Thread Starter
So I essentially measured each valve when the lobe was pointing outwards (away from motor). I can put everything back together and remeasure if this is incorrect.
To be quite honest, I didn't it easier to watch videos than read the manual. The manual, to me anyway, is difficult to navigate and understand. I'm also really really new at this though.
These are the measurements I got based on instructions I followed from a video, manual and random websites.
stangn99 is offline
post #8 of 12 Old 04-15-2017, 07:47 PM
I must confess it was not easy for me to read the manual either.
I after years of maintaining my Harleys I grew spoiled by the quality of their shop books.
Kawi's manuals cannot be accused of prolixity.
goblin is offline
post #9 of 12 Old 04-16-2017, 08:06 AM
I choose to measure a single cylinder at a time
ie;
#1 @ TDC and measure only #1 clearances
#2 @ TDC and measure only #2 clearances
#4 @ TDC and measure only #4 clearances
#3 @ TDC and measure only #3 clearances
then if any are going to need adjusting...........and high probablity that they will
I loosen the cam cap bolts and re-torque and measure again before actually removing and changing shims
as how you torque the cam caps vs how they were at, will change clearance valaues..............
post #10 of 12 Old 04-16-2017, 12:47 PM Thread Starter
ie;
That's pretty much how I measured it on mine. At every cylinder I measured, the lobes were pointing away from the engine (TDC) as suggested online.
I put everything back together today. I used a mirror as suggested and I was able to locate the markings on the outside of the cams. Why would Kawasaki do this?!?!
I was able to count the pins on the chain and successfully counted the 28 as per the manual going from 1,2,3 to 28.
I re-torqued the cap bolts and remeasured and noticed the clearances were just slightly different (by like 0.01mm)
I'm going to triple check my measurements again and attempt marking the cam + chain before going any further.
Thanks for all the tips so far. I suspect someone was already in the motor at some point, since some in the bolts have wrench marks on them. The bike was also previously downed, so could be a scrap yard motor.
Sent from my Le X820 using Tapatalk
stangn99 is offline
post #11 of 12 Old 04-22-2017, 08:08 PM Thread Starter
Hey guys,
Just a quick update. I haven't had much time to tinker with the bike as I'm also working on some backyard projects.
I managed to mark up the cams and chain with a marker, kept tension on the chain, and remove the cams.
Some of the exhaust valves have shims marked 8 6. When I measure these they come out at 2.96mm.
Does this mean a valve adjustment was done at some point on this bike? I can't find 8 6 marking in the manual. Should I assume it's 2.95 for go with that?
By the way, I'm averaging the tolerance (EX 0.22 ~ 0.31 = 0.265 IN 0.11 ~ 0.19 = 0.15) is the preferred method?
stangn99 is offline
post #12 of 12 Old 04-22-2017, 11:49 PM
Measure every shim.
Accuracy is bound by your ability to measure.
What is the smallest increment you can measure with your calipers?
What is the smallest step in size of your feeler gauges? How many fall within the range allowed for the acceptable lash?
Whatever the biggest unit is, that's the limit of your accuracy.
Any number you use cannot be any more accurate than the greatest error.
Not trying to rain on your parade, simply stating the constraints anyone who does this has to deal with.
valve adj and cam chain question justkal23 Mechanical and Technical 6 07-28-2015 02:32 PM
Valve adjustment post noise Boglen81 The ZX6R 21 08-23-2014 11:43 PM
How To Videos: Valve Clearance Adjustment MistressOfMayhem Mechanical and Technical 13 09-19-2012 05:54 PM
kawi tick/ knock? cam tensioner or valve adjustment? hdasilva1990 Mechanical and Technical 10 05-06-2012 06:58 PM
