First Gear Clutch Won't Disengage - ZX6R Forum
  • 1 Post By RJ2112
post #1 of 9 Old 04-16-2017, 08:18 AM Thread Starter
Hi Guys,
Late last season I cracked my clutch cover of my 04 ZX6r in a spill. Recently I replaced the cover as well as the spark plugs, air filter and did an oil change; however, after these changes, when I put it in first gear, there is a significant amount of forward movement from the rear wheel as if the clutch is not disengaged (even though the clutch lever is fully pulled in). I have played around with the clutch cable adjustments and it doesn't seem to have any effect.
I am wondering if this could be from installing the clutch cover incorrectly or if there are other issues? I don't believe changing the spark plugs/air filter/oil could have caused this. Any suggestions on how to fix this?
rgcamp is offline
post #2 of 9 Old 04-16-2017, 08:37 AM
It doesn't sound like you've touched anything that should result in a change in clutch action..... the list of what could be happening is pretty big, and the best answer is to take it apart and check it out.
If the bike sat for some length of time with little or no oil on the clutch, the clutch and friction plates could have rusted together.
capitalcrew likes this.
post #3 of 9 Old 04-16-2017, 10:16 AM Thread Starter
Thanks for the insights. I guess I will bite the bullet and pull the clutch apart.
rgcamp is offline
post #4 of 9 Old 04-18-2017, 01:55 PM
Hello and welcome!
post #5 of 9 Old 04-18-2017, 02:40 PM
The clutch cover on some bikes needs to be installed properly to get the correct slack at the clutch cover end. Make sure to do just as the manual reads. My R1 is a pain in the ass to get right. It sounds like you didn't do it right.
the prophet is offline
post #6 of 9 Old 04-18-2017, 02:41 PM
The lever down at the clutch cover needs to be pointed correctly to get the correct slack at the upper lever.
post #7 of 9 Old 04-20-2017, 09:03 AM Thread Starter
Thanks for the help Prophet. I plan to take the cover off again this weekend so I will check over where the wire attaches to the cover and see if it went on correctly
rgcamp is offline
post #8 of 9 Old 04-20-2017, 09:10 AM
If you think the plates might be stuck you can let it run on a stand and it should come free eventually. Won't help if you've installed something wrong though
capitalcrew is offline
post #9 of 9 Old 04-20-2017, 10:07 AM
On my R1 the lower clutch lever at the case has a mark on the lever itself and there is a mark on the case as well. You have to line up the marks when you place the cover back on the bike. Then you know the thing is lined up correctly.
How to launch/race start a motorcycle PainfullySlo Racing 33 02-03-2016 01:09 PM
Bike won't start in gear, clutch switch? RedAndBlack The ZX6R 11 09-24-2014 04:57 AM
ASV Levers - Start in gear - review and advice jimundascores Mechanical and Technical 14 04-04-2014 06:48 AM
