white cloud in my oil window - ZX6R Forum
  • 1 Post By Twistee
  • 1 Post By RedAndBlack
post #1 of 4 Old 04-16-2017, 10:14 AM Thread Starter
I Ride: 2002 zx6r
I saw an almost white milky substance in my oil window. Could this be condensation or is my head gasket blown? how long should i wait to see if it goes away? Its a brand new oil change.
ngk330 is offline
post #2 of 4 Old 04-16-2017, 11:53 AM
Twistee's Avatar
I Ride: ZX6R G2 (99)
The horrible answer is: It depends.
A little mist in the oil window and a tiny bit of "cream" in the filler cap isn't something to be overly concerned about. If you're removing your filler cap and can see your clutch plates covered in "cream", that's a definite concern. There could be a multitude of reasons for a little condensation making its way into your oil (even freshly changed).
When it comes to these things, I do it the 'old fashioned' way. I use my own senses. Does the engine make new or different noises? Is the power down? Does the clutch now slip more? If you're familiar with the bike, you should be able to notice these things if you give them your attention.
Clean the goop from the filler cap, and keep an eye on things. If the amount of white goop doesn't start to diminish (and/or the ass dyno is giving you concern), you want to check this out a lot more thoroughly.
Twistee is online now
post #3 of 4 Old 04-16-2017, 04:45 PM
Likely condensation. Wouldn't worry about it too much. Especially if there was no coolant in your old oil.
RedAndBlack is offline
post #4 of 4 Old 04-16-2017, 05:31 PM
Gawernator's Avatar
To be safe you could change the oil again, look at it after idling the motor, take it out for a longish ride then come home and check it again. If the oil is still mixed with coolant then you have an issue.
Gawernator is offline
Oil level window Nogain8525 Mechanical and Technical 6 12-27-2015 08:40 AM
brodas ! my DIY OIL and FILTER CHANGE renzovc16 The ZX6R 10 04-22-2014 08:45 AM
Stator Replacement, Oil Change, More with pics devildogae Guides 15 09-10-2013 07:12 PM
oil level window greenrocket The ZX6R 25 08-05-2013 12:14 PM
Oil light and red warning light flashing after oil change justo1013 Mechanical and Technical 16 07-31-2013 09:22 AM
