How "aligned" does the rear wheel need to be? - Page 2 - ZX6R Forum
 6Likes
post #16 of 20 Old 04-18-2017, 03:03 PM
+1 on the Motion Pro Chain Alignment Tool
You can also use a metal ruler/straight edge. Hold it against the rear sprocket under the chain and look over the top of the chain to line it up with the straight edge.
Or you can go all out and get the laser tool: Luster Care Laser for CAT Chain and Belt Alignment Tool
+1 on the DuPont Chain Saver
I like this chain lube a lot. It doesn't collect dirt/grime, and it doesn't fling off all over everything.
post #17 of 20 Old 04-19-2017, 07:21 PM Thread Starter
Guys I love this forum. Great advice. And no one called me an idiot for wanting my chain aligned too much
Eurodriver is offline
post #18 of 20 Old 04-19-2017, 07:33 PM
Twistee's Avatar
I Ride: ZX6R G2 (99)
To me, the only person who's really an idiot is the one who doesn't ask for advice and tries to blunder on through it. If you want to be concerned about the chain, be more concerned with keeping it clean, properly lubricated and at the right tension.
Besides, I contend with Asperger Syndrome (and have done before it became a 'thing') which comes with a bizarre mix of OCD and ADHD.
Eurodriver likes this.
Twistee is offline
post #19 of 20 Old 04-25-2017, 01:45 PM Thread Starter
So I hit 600 miles - chain was loose again.
I got the motion pro alignment tool. What a life changer.
Threw it up on the stand. Loosened the axle bolt. Put the alignment tool on the sprocket and adjusted the chain til it was within spec. Made sure the chain matched the tool and tightened it back up.
Literally did an oil change and a chain alignment in <1hr. Before, the alignment alone would have taken me 45 minutes!
This forum rocks. I don't even own a Kawi anymore and I wont leave
Scorpi0 likes this.
post #20 of 20 Old 04-25-2017, 02:05 PM
Gawernator's Avatar
Motion pro rocks!!
Gawernator is offline
Maybe I should sell all my tools - rear wheel install problem GEB Mechanical and Technical 28 09-17-2014 12:40 PM
2015 Kawasaki ZX6R Features and Benefits NickJ The ZX6R 0 07-18-2014 12:29 PM
2004 rear wheel collar loose...what do? mr5drums Mechanical and Technical 11 06-26-2014 11:16 AM
2002 rear wheel assembly (Wheel spacers) AnfarnoCorin Mechanical and Technical 5 06-17-2014 01:35 PM
rear wheel. 08limegreen Mechanical and Technical 1 10-02-2013 06:19 AM
