Throttle cable too short - ZX6R Forum
post #1 of 2 Old 04-17-2017, 06:14 AM Thread Starter
I have a 95 zx6r which has street fighter handlebars. The throttle sticks so when I rotate it, it doesn't snap back. I took apart the assembly and I've had a look at the cables. The pull cable only has maybe 1/2cm of length past the sheath at the throttle side when installed in the carbs. I believe this is the problem.
I've tried rerouting the cable, locking all the adjustment screws so I have maximum length and I've checked the idle screw own the carbs. I've pulled the cable out entirely and the free length remains the same regardless so I know its not related to the handlebars. There definitely should be more length than a 1/2cm, right?
I have no idea how to fix this and i'm concerned that if I buy another cable it will just result in the same problem. Just wondered if anyone had any idea what might be going on?
Picture of the cable: http://imgur.com/QjyzouU
Axxokiller is offline
post #2 of 2 Old 04-17-2017, 12:10 PM
wrong cable would be my guess
Take a picture of the end hooked up to the carbs
then remove the cable entirely and simply pull one end out as far as it will go and measure........ You should have about 90-100mm of interior cable extending past the exterior sheeth
I do not have a 95-97 cable loose handy..... but do have other ZX6R cables and they all come between 90 and 100mm
throttle cable
Need help with throttle cable and clutch cable diagram buterican Mechanical and Technical 5 09-02-2014 11:45 AM
Secondary throttle plates removed, running issues rxlucky7 The ZX6R 4 01-11-2014 08:04 PM
2006 throttle not returning Bioviper The ZX6R 5 09-18-2013 07:50 PM
Throttle cable adjustment issues ZPVanT Mechanical and Technical 12 10-09-2012 10:51 AM
Throttle issues radon901 Mechanical and Technical 7 09-27-2012 05:23 PM
