Lubing pivot points? - ZX6R Forum
 4Likes
  • 2 Post By Strider
  • 2 Post By riverszzr
post #1 of 8 Old 04-18-2017, 07:59 PM Thread Starter
Sex3Sex's Avatar
Is there a specific type of lube you would use to lube the pivot points on the bike? Would normal chain lube be okay?
Is there anything else I missed that would need to be lube from my list below?
Clutch lever pivot
Gearshift link pivots
Side stand pivot
Brake lever pivot
Brake pedal pivot
Sex3Sex is offline
post #2 of 8 Old 04-18-2017, 08:15 PM
I use DuPont Teflon Multi-Use lubricant for most of those particular pivot points.
You can get it at Lowes: https://www.lowes.com/pd/DuPont-11-o...ricant/1059839
I have also used DuPont White Lithium Grease for similar applications: http://www.performancelubricantsusa....ith-teflon.php
For the "Gearshift link pivots", if you are talking about the joints at each end of the shift rod, I would use marine grease. If you are talking about the pivot on the shift lever itself, then use the DuPont lubricant.
PainfullySlo and Sex3Sex like this.
post #3 of 8 Old 04-18-2017, 08:42 PM
I use what I have, which is just WD-40 and marine grease. So depending on the application I use one of those two lol. The only exceptions are the chain, because I have chain lube/wax for that and the O-ring on oil filters because I just use engine oil on that.
2013 CBR500R (race bike)
2009 ZX6R (race bike)
sbk1198 is online now
post #4 of 8 Old 04-19-2017, 02:05 AM
Spray some lube in your ignition and fuel cap as well. Maybe some on the chrome on the shocks.
Scorpi0 is online now
post #5 of 8 Old 04-19-2017, 08:32 AM
I would not be using chain lube
Strider and PainfullySlo like this.
post #6 of 8 Old 04-19-2017, 10:50 AM
Sticky icky chain lube. Ya, I want that all over my bike.
the prophet is offline
post #7 of 8 Old 04-19-2017, 12:08 PM
I have used white lithium grease for almost all of the pivots on the bike for the past 5 years.... I recently took apart the clutch pivot because it had gotten much too tight, and when I put that back together I used light machine oil in the pivot. Not sure why the lock nut had become tighter, but it was causing the lever to bind on the housing.
When I took it apart there was some residue from the lithium in there. I don't think it had anything to do with the action, but I know I am not going to do that again.
As has been said, pretty much any lube is better than no lube -- I too would stay away from anything really sticky. It just collects too much dirt and grit.
post #8 of 8 Old 04-19-2017, 12:23 PM
Twistee's Avatar
I Ride: ZX6R G2 (99)
The only greases I find useful are a general purpose lithium grease and copper grease. I use Scottoil for my chain oiler (almost exclusively - I have used gear oil a couple of times in a pinch). I have a can of PTFE spray, but this is very seldom used.
If there's anything particularly mandated for use by the service manual (molybdenum disulphide is an example), I'd use that. Otherwise, the GP grease does for everything I need.
... don't forget the swingarm pivots!
Twistee is online now
2016 MotoGP Season **Spoilers Inside** Ilya Racing 1999 11-14-2016 05:32 AM
ZX6 05 Clutch/Throttle Cable Lubing bristolbiker Mechanical and Technical 3 08-21-2013 05:03 AM
Brake Lever Pivot Locknut netcode Mechanical and Technical 6 06-24-2013 11:17 AM
swing arm pivot bolt torque spec crashnreburn Mechanical and Technical 4 02-11-2012 08:25 AM
