How to set preload on forks with different springs? - ZX6R Forum
  • 1 Post By the prophet
  • 1 Post By PainfullySlo
post #1 of 5 Old 04-19-2017, 10:59 AM Thread Starter
@PainfullySlo , if I recall you use different springs in your forks to get that "in-between" spring rate, but maybe others do as well so feel free to pitch in. So how do you set preload on the forks if you go with different spring rates in each fork tube? Do you set them equal by displacement (basically same number of turns) or do you set them equal by force, which would result in different displacement?
I recently changed my springs 1 size up in stiffness (from 10 to 10.5) and now they're a bit too stiff, so I'm thinking maybe I should just swap one of them back, so I'll end up with a combined rate of 10.25 N/mm.
2013 CBR500R (race bike)
2009 ZX6R (race bike)
sbk1198 is offline
post #2 of 5 Old 04-19-2017, 11:04 AM
ninjaman89's Avatar
Why does it matter? As long as you're not cranking one of them down too far, just keep them within a reasonable range and adjust them as necessary until you get the desired setting
ninjaman89 is offline
post #3 of 5 Old 04-19-2017, 11:04 AM
Set them the same. Consider the 2013 zx6r forks. They only have one preload adjuster. It works. Don't worry about it. Not enough to make a big difference.
PainfullySlo likes this.
the prophet is offline
post #4 of 5 Old 04-19-2017, 12:31 PM Thread Starter
I know the 2013+ have preload adjuster on only one side and it always baffled me how it works ...but I suppose that's no different than putting 2 different springs on.
sbk1198 is offline
post #5 of 5 Old 04-19-2017, 12:55 PM
^ this.
I set the preload the same on both sides.
sbk1198 likes this.
PainfullySlo is offline
Suspension Settings stuartb Mechanical and Technical 10 04-26-2015 03:08 AM
Need help 07-08 forks moto82199 Mechanical and Technical 0 03-14-2015 07:46 AM
How to: Fork Seal Change for 1995-1997 ZX6R/Conventional Forks AgentOrange Guides 0 07-28-2012 01:03 AM
