New Zx6r with starting problem - ZX6R Forum
post #1 of 9 Old 04-20-2017, 07:00 AM Thread Starter
I Ride: 2000 Zx6r
Hello my name is keyan. I have a 2000 Zx6r that my cousin gave me. And a couple of months ago he lost the keys and replaced the ignition twitch with a aftermarket one and ever since it ant ran. I have replaced the cdi box and the pulsing coil and I still don't get spark out of my spark plugs. I need som help here guys.ps I will show pics later
Keyan Moore is offline
post #2 of 9 Old 04-20-2017, 07:49 AM
Twistee's Avatar
I Ride: ZX6R G2 (99)
Without extra details, this could be hard to answer.
Just a couple of possibilities include:
1. He hasn't connected the plug correctly when he changed over the ignition barrel (you'll need a new fuel cap lock too!).
2. He's used a crap unit from eBay that's fried something.
3. He's damaged or disconnected something when rigging things up.
- When you turn the key, do the clocks light up/headlights and indicators work?
- Does the engine try to turn over, but you're just not getting a spark?
- Are the fuses all okay?
- Has the ignition or engine stop switch shorted?
- Has some of the wiring shorted?
- Is it definitely in neutral?
- Is the starter locked out?
- Has the sidestand switch shorted?
The more info you can give us, the quicker we'll be able to help.
It's probably best to put as much of the original items in place as you can, and work methodically from the ignition barrel on back.
Welcome to the forum!
Twistee is offline
post #3 of 9 Old 04-20-2017, 08:07 AM
commiehunter's Avatar
I Ride: ZX6R 636
If it worked, and you replaced the ignition, and it won't work, I doubt the problem is CDI or pulsing coil. More likely the ignition, no?
Does your ignition wiring show continuity when you have the key in the on position?
commiehunter is offline
post #4 of 9 Old 04-20-2017, 09:14 AM Thread Starter
I Ride: 2000 Zx6r
When I turn the key on the clocks come on all the lights come on accept the oil light but it will turn over it's just the spark plugs don't spark. I don't know were he go the ignition from all I know is he order it off eBay
post #5 of 9 Old 04-20-2017, 09:15 AM Thread Starter
I Ride: 2000 Zx6r
All the fuses are fine. I checked all the grounds they at fine
post #6 of 9 Old 04-20-2017, 10:42 AM
Twistee's Avatar
Like I said, put the original kit back on (obviously, not the ignition barrel). If you put new items in, you're just adding more potential failure points before you find the cause.
Disconnect the ignition barrel and check that the connection is 100% correctly fitted. Check the wiring back from that point and make sure there's been nothing stretched or frayed.
Ask him if he got that ignition barrel new or second hand. Has he been able to start and run the bike at all since the barrel was replaced?
Twistee is offline
post #7 of 9 Old 04-20-2017, 11:04 AM Thread Starter
I Ride: 2000 Zx6r
No it hasn't ran at all. I'm thinking of just buying a new ignition because before he lost the key it ran fine
post #8 of 9 Old 04-20-2017, 11:11 AM
Twistee's Avatar
That sounds like a plan to me.
When it comes to parts, getting just any old crap off of eBay tends to be a bad idea. OE costs more, but at least you know it'll work (and you can easily return it/get a refund if it doesn't).
Twistee is offline
post #9 of 9 Old 04-20-2017, 11:47 AM Thread Starter
I Ride: 2000 Zx6r
Right that's what I was think I just ordered it I'll let you know how it goes
07 zx6r help! problem starting madkaw6 07 New Users 14 12-02-2014 05:34 AM
brake problem not braking problem 05 zx6r bezerker501 Mechanical and Technical 15 07-22-2013 09:15 PM
Odd Starting Issue. 09 ZX6R ZXDrew Mechanical and Technical 3 11-12-2012 09:27 AM
