Low End Bogging - ZX6R Forum
 4Likes
  • 1 Post By RJ2112
  • 1 Post By PainfullySlo
  • 1 Post By aodrn
  • 1 Post By mharrison
post #1 of 11 Old 05-08-2017, 02:00 AM Thread Starter
311motosport's Avatar
I Ride: 2006 ZZR600 & 2007 Ninja 650R
Low End Bogging
If you all have a minute I need your input on a problem I am having with my 2006 Kawasaki ZZR 600 which has the ZX6R motor with Carbs 19k miles. Due to a health issue and bad fork seals (I just fixed) this is the first outing since last year. My bike was stored inside my house all winter with non ethanol 93 octane and seafoam as a fuel stabilizer (The Life of a Bachelor). I would crank it once a month and have kept it on a battery tender. So the bike cranks up fine and idles fine but it has a bog (lack of power) from 0-7000 RPMs then it goes away and runs normal from 7000-14000 RPMs. Ive made a few runs with it and other than the bog it runs fine idles fine starts fine. I ended up putting a whole can of seafoam in it and ran it with no change in the performance. I probably only ran it 15 miles like this and was thinking it might clear up (clogged pilot jet). After a successful rebuild on my forks... having it run like crap was a kick in the Nuts! It ran perfect when I put it up last year. Any input would be appreciated. Thank you all.
2006 ZZR 600 20k miles. Michelin Pilot Power 3's. Two-Brothers exhaust. R & G frame sliders. AmsOil 10w-40, AmsOil oil filter and K & N air filter. Stock motor.
2007 NINJA 650R 29k miles. Michelin Pilot Power 3's. Two-Brothers slip-on. Two-Brothers Juice Box. R & G frame sliders. AmsOil 10w-40, K&N oil filter and BikeMaster air filter. Stock motor.
PERFECT PRACTICE MAKES PERFECT!!
311motosport is offline
post #2 of 11 Old 05-08-2017, 02:05 AM
Im pretty sure this is carb related but I dunno too much about em. Wait a few minutes and someone should help u out.
post #3 of 11 Old 05-08-2017, 03:25 AM
I'm confused, (not unusual) So this is a 2006? with carb's.
I've got a 2006, 600RR and it has 8 injectors.
This is new to me, did not know of any 06 with carb's.
If indeed it has carbs, and ran fine in the past with these jets. No modifications since last running good your choices are pretty few.
First, pull ALL the fuel. Nice new premium.
Confirm air filter is clean. Run the bike for a nice outing.
Idle and main jets aren't the same. So the normal driving will get the fuel moved in.
Idle will be the only time your seafoam will make it threw the idle circuit.
That doesn't help. Carb rebuild.
If problem doesn't get worse, run a tank or two with cleaner. See what happens.
Indy is online now
post #4 of 11 Old 05-08-2017, 05:19 AM
Pull the float bowls off the carbs and see what falls out.
311motosport likes this.
post #5 of 11 Old 05-08-2017, 07:14 AM
OP has a ZZR which is indeed carburated.
Anywho, it really sounds fuel related so I would pull apart the carbs...
PainfullySlo is offline
post #6 of 11 Old 05-08-2017, 09:34 AM
aodrn's Avatar
I Ride: 2007 ZX6R
I'm lazy. I would try running a couple of tanks of gas out before pulling the carbs. It just takes a speck of crap in the wrong spot to really jack up the way a bike runs. If it's bad enough that you wouldn't want to ride it like that, then it probably wouldn't fix itself anyway.
aodrn is offline
post #7 of 11 Old 05-08-2017, 04:32 PM
Thanks Slo.. seems odd same year carbs and injection.
Too much work. Live and learn.
Indy is online now
post #8 of 11 Old 05-09-2017, 06:47 AM
mharrison's Avatar
I would start here. Too much Sea Foam will cause it to run like crap too.
mharrison is offline
post #9 of 11 Old 05-17-2017, 03:59 AM Thread Starter
This is the 2006 ZZR 600 which is the same bike as the 2000-2002 ZX-6R. All the parts interchange between the 2005-2008 ZZR 600 and 2000-2002 ZX-6R. Which Indeed has Carbs......4 of them to be exact.
post #10 of 11 Old 05-17-2017, 04:01 AM Thread Starter
Is there really people who own a motorcycle and don't know if it has Carbs or Fuel Injection.........
post #11 of 11 Old 05-17-2017, 04:15 AM Thread Starter
Seems to me I have a pilot jet clogged but I have not had a chance to look into it. I do thank all of you for your response.
05 zx6r help (low power/torque) rads92 Mechanical and Technical 5 08-25-2016 07:53 AM
Does low power mode consume less gas? cabiker91 Mechanical and Technical 13 08-14-2016 04:15 PM
2013 ZX6R Low fuel indicator/light Xcavor Mechanical and Technical 5 09-21-2015 06:56 PM
Trackday at Snetterton ended in low side. Vid to come d1andonlyant Ride Reports 6 06-30-2013 10:22 AM
02 Carb tuning: Trying to gain low end torque Andyrew Mechanical and Technical 1 05-20-2013 04:47 PM
