Cracked oil pan (2003) - ZX6R Forum
  • 1 Post By gyrate
  • 2 Post By gyrate
post #1 of 8 Old 05-12-2017, 05:21 PM Thread Starter
gyrate's Avatar
I Ride: 2003 zx6r
Unhappy Cracked oil pan (2003)
Thought you'd all like to see this. I got some questions to go with this as well.
Was going to my first oil change on my 636 yesterday; but I ended up cracking my oil pan because I wasn't paying attention to if I was loosening or not (I'm already accepted that I am a dumbass). I could be wrong but I think the last person put the drain plug in cross threaded; it only took 2 quarter turns with a 10 inch wrench to crack my oil pan.
Anyways, here's the damage...
http://zx6r.com/attachment.php?attac...=63562&thumb=1
Waiting for a new oil pan, gasket, plug & washer to come in; they are on backorder for another 2 weeks. I plan on re-using the old 14 bolts holding the mangled oil pan currently; nothing wrong with that?
Don't be like me!
gyrate is offline
post #2 of 8 Old 05-13-2017, 02:58 AM
There is a small amount of force on the pan bolts...... the recommended numbers are in the shop manual for that bike, which you can download from this site. If it doesn't recommend a torque pattern.use one anyway. It should also state if you need thread locker.
post #3 of 8 Old 05-14-2017, 01:54 PM Thread Starter
gyrate's Avatar
I Ride: 2003 zx6r
Manual says 87 in-lbs for the oil pan bolts and no comment for thread lock. I agree with the torque pattern comment as well.
gyrate is offline
post #4 of 8 Old 05-14-2017, 02:53 PM
Steel bolts, into aluminium.... the bolt will out last the engine case....
post #5 of 8 Old 05-14-2017, 02:59 PM
Don't be like me!
That's....impressive. In a bad way. You had to be hauling on that to make it crack that way.
Anyway, you should be fine to re-use your oil pan bolts. 87in-lb is nothing so stretch should not be a concern.
PainfullySlo is offline
post #6 of 8 Old 05-14-2017, 04:37 PM Thread Starter
gyrate's Avatar
I Ride: 2003 zx6r
I find it impressive too, I'm a scrawny 140 pound guy with pool noodles for arms.
arsftarmy and upland117 like this.
gyrate is offline
post #7 of 8 Old 05-23-2017, 02:41 PM Thread Starter
gyrate's Avatar
I Ride: 2003 zx6r
Think this will hold up?
ID:	64346   Click image for larger version
ID:	64354   Click image for larger version
gyrate is offline
post #8 of 8 Old 05-23-2017, 04:04 PM
ZedExMuse's Avatar
Yes, Mssr Poodle Noodle Arms... if & only if you obtain for yourself a torque wrench:
https://www.harborfreight.com/catalo...=torque+wrench
Cheers
C8H10N4O2
ZedExMuse is offline
oil change oil pan damage
did my first oil change! :) rodas6r Mechanical and Technical 6 05-02-2012 10:10 PM
No oil pressure for 2003 ZX6RR. Gurus, I need you! N3RB The ZX6R 11 01-02-2009 06:05 PM
