Zx6r owner with a question - ZX6R Forum
post #1 of 8 Old 05-13-2017, 09:57 AM Thread Starter
I Ride: 2000 Zx6r
Hello my name is keyan I have a question. Is it normal for my bike to redline out of first gear at like 35-45 mph? And if it's not what's wrong with it
Keyan Moore is offline
post #2 of 8 Old 05-13-2017, 11:28 AM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
worn out clutch-plates
if your rear sprocket isn't the size of your rear wheel (stunt stuff)...then definitely your clutch plates.
MrZ is offline
post #3 of 8 Old 05-13-2017, 06:34 PM Thread Starter
I Ride: 2000 Zx6r
Ok thanks I will check that out
post #4 of 8 Old 05-13-2017, 07:14 PM
The only other possibility is someone used oil that is not compatible with motorcycle wet clutches. Or your clutch lever may be adjusted much too tight, causing slippage.
post #5 of 8 Old 05-14-2017, 06:42 AM Thread Starter
I Ride: 2000 Zx6r
So if I drain the oil will that fixe it
post #6 of 8 Old 05-14-2017, 08:26 AM
No.
Does the bike speed up as the RPMs climb?
Or does the bike stay at the same speed while the RPMs climb?
post #7 of 8 Old 05-14-2017, 08:35 AM Thread Starter
I Ride: 2000 Zx6r
What's it hit that 40 mph the rpms raise but the bike doesn't go faster
post #8 of 8 Old 05-14-2017, 12:32 PM
Sounds like either your clutch needs adjusting, or your clutch is worn out.
Question about fuel management for my '09 ZX6R thaduke2003 The ZX6R 6 10-01-2014 09:08 AM
95 zx6r clutch basket question muguerza The ZX6R 0 09-15-2014 06:30 PM
Greetings! I'm a new member and ZX6R rider, second time Ninja owner. RzRPwR New Users 9 10-19-2013 10:19 AM
ZX6r 636 buying question??? FlyBy The ZX6R 17 02-04-2010 04:38 PM
