636 running lean w/a powercommander - ZX6R Forum
  • 1 Post By RJ2112
post #1 of 5 Old 05-13-2017, 10:17 AM Thread Starter
I Ride: '04 636
I'm looking for someone who really knows these fuel injected bikes.As mine is running lean and haven't been able to figure out why.I'ved tried to contact a guy named Rivers w/no response and am wondering if there's anybody else who mine be able to point me in the right direction
pro439 is offline
post #2 of 5 Old 05-13-2017, 04:34 PM
Bennett636's Avatar
I Ride: 2005 Kawasaki ZX-6R 636
What map are you running? What mods are on the bike to need a power commander?
Wrecked/Sold: 2005 Kawasaki zx-6r 636, 15k mi, k&n air filter, muzzy titanium slip-on, jumper mod, servo eliminator, core moto trans blue SS brake lines, michelin pilot power 2ct front and back, gloss black powder coated rear sets.
The new: 2005 zx-6r 636, Magma Red, 21k mi, full muzzys exhaust, PCIII, k&n air filter, laggy a servo eliminator, jumper mod, core moto trans red brake lines, gloss black powder coated rear sets.
Bennett636 is offline
post #3 of 5 Old 05-14-2017, 05:29 AM
..... more importantly, how do you know it's running lean?
Bennett636 likes this.
post #4 of 5 Old 05-14-2017, 07:43 PM
What they said and to add.
Was it lean before PC..
Mod's done and tune loaded.
What year bike Which PC and does it have autotune installed.
post #5 of 5 Old 05-20-2017, 07:49 PM Thread Starter
I Ride: '04 636
I did the air into the exhaust port delete,sprint air filter ,Muzzy pipe.When I got the power commander it was set at Zero.Put it on the bike and went for a rode test.I didn't even get out of the driveway.The bike wouldn't accelerate.Thought maybe the power commander was screwed up put it back to stock.Way worse. I did adjust the valves found them all over the place.Set the intakes to .009 and the exhaust to .025 mm.Cams are timed right because I one 1 tooth off and couldn't turn the only so far one way or the other and it would stop.I got the stuff to adjust the settings in the power commander and starter out looking at other maps for a base line and starter there.Rode the bike still very much more than 5000 rpms and it would lay over.I kept pushing the fuel to it until it stopped making a difference still starts laying over about 5500 and won't pull to 7000.Now 2 falls ago I moved to a different storage rode about 4 miles and started losing power and the bike finally quit.I could hear the fuel pump not priming.So I took it apart on the side of the road and found the metal bowl full of rust.I clean all the rust out and flushed with VP 12.Put it back together and no issues.Bought a new pump and put it in.Didn't check fuel pressure.and I haven't done a plug check.I took the injectors out to see if any of the rust had made into them and didn't see anything.I did find one of the boots for the throttle bodies folded over and I straighten that out but that didn't do anything for it.I just now ordered o-rings for the fuel rail as they leaked when I put it back together ,new injector seals, new mounting boots and new vacuum caps for all the stuff I removed associated w/the air injection.I'm going to put it together,do a plug check before I run it and spray ether to see if I have any vacuum leaks. I'ved tried and tried to get ahold of rivers to see if there a place that can calibrate the injector so there all the same and not just clean them but he has never got back to me.Also this bike has sat 7 years because of a crash.I got all the panels replaced and now want to ride it.There diffidently something screwy because with fuel curve I have in it it's getting about 10 mpg.I tapped the upper port and put a plug in it for the block off for the air injection.'04 636
Thank You
pro439 is offline
Remembering the Ninja ZX-6R 636 twilliams83 The ZX6R 23 03-01-2014 08:25 AM
04 636 running probs epflynn Mechanical and Technical 9 10-16-2011 10:02 PM
running on 3 cylinders 05-06 636 joshd412 Mechanical and Technical 12 09-27-2011 09:36 PM
2005 ZX6R 636 won't stay running Sinisterinc Mechanical and Technical 2 08-19-2011 09:52 AM
03 636 vs. 07 ZX-6R EvilTwin The ZX6R 17 12-14-2010 02:24 PM
