Need help ASAP!! - ZX6R Forum
post #1 of 2 Old 05-17-2017, 08:18 AM Thread Starter
I Ride: 2001 ZX6R
Need help ASAP!!
I need to wire in a 100 ohm resistor into my aftermarket ignition switch for my 01 zx6r, and the switch didn't come with a resistor already installed. I know that normally it would go on the white and grey wires, however the new switch has a green, and orange wires instead so I'm not sure which one would be considered the white wire. Has anyone done something like this? I'm not looking to hotwire the bike.
steve leon is offline
post #2 of 2 Old 05-17-2017, 10:05 AM
First Steve Welcome to the forum.
Second, take some time and say HI in the new members section. Tell us about your past bikes and present.
How long you have had it, along with mods done. OH, no pictures it didn't happen.
On your question. Down load the service manual.
Ohm out the old switch. It can't be all bad.
Compare the new switch on how it ohms out. If all the wires are not the same color your going to need to map what the old was to confirm the new connects to the proper section.
If done incorrectly you could fry some wires or the bike won't start.
Crap! Need asap sheerider11 Want to Buy 45 03-10-2016 08:38 AM
Help needed asap!!! Shadyaj3 The ZX6R 10 04-07-2015 08:58 PM
WTB: 05/06 OEM or aftermarket rear sets ASAP!!!!!!!! Ninjammsc Want to Buy 0 05-17-2014 04:38 PM
riim swap help asap asap kawasakirydr Mechanical and Technical 7 01-30-2014 06:25 PM
2007-2008 frame and title needed!! ASAP teleguz Mechanical and Technical 1 07-30-2013 09:21 PM
