Had to pull head... - ZX6R Forum
 5Likes
  • 1 Post By commiehunter
  • 3 Post By wildfire77
  • 1 Post By riverszzr
post #1 of 9 Old 05-19-2017, 07:34 AM Thread Starter
wildfire77's Avatar
I Ride: Track Preped 07 ZX6R
Had to pull head...
The engine is replacing a blown engine, so its been used and I don't know its maintenance history. Bolts on everything seemed over torqued (cam caps, and head bolts). I'm assuming the head bolts haven't been touched since the factory.
So anyway, in putting the head on, and tightening the bolts; the threads in the block sheered on one of them... (yes i'm following the torque specs per the manual 11ft/lbs then 39ft/lbs.) Has anyone ever heard of this on a current generation (2007-present) zx6r motor?
Keep it on 2 wheels!
BIKES:
2002 Ninja EX250 sold (new 2002-2006)
2004 GSXR 750 sold (2008-2010)
2008 GSXR 1000 sold (new in 2010-2014)
2012 Aprilia Tuono RSV4 APRC sold (early 2014 - Fall 2015)
2007 Track Prepped Ninja ZX6R (Fall 2015 - Current)
wildfire77 is offline
post #2 of 9 Old 05-19-2017, 08:39 AM
commiehunter's Avatar
I Ride: ZX6R 636
Paging @riverszzr
Scorpi0 likes this.
commiehunter is offline
post #3 of 9 Old 05-19-2017, 10:35 AM
I'd have to think that you are not the first person to put a head on that motor after it left the factory.\
post #4 of 9 Old 05-19-2017, 04:21 PM
Yes,, had issues with my cam retainer..
My NEW Torque wrench sucks. Went back my old one I was afraid was out of tolerance.
SO my guess is your torque wrench is also having issues or your bolt was either over torqued and weakened or it it was corroded in place. The later seems improbable.
Depending on what you find after tear down. Consider replacing all those bolts, assuming they are all weakened thus stretched.
I regret not doing that on my Honda, ended up with a weeping leak lower jugs after the rebuild.
post #5 of 9 Old 05-19-2017, 07:08 PM Thread Starter
wildfire77's Avatar
yea. pretty corroded which didn't help, but figured out what i did though...
so it was a long day with little sleep. was torquing to ft/lbs... the 39 in my post is the n/m measurement... the ft/lbs conversion is 29. very similar numbers. way over torqued. lesson learned...
the good news. the engine is coming together again after lathing a custom head stud. pictures to come...
RJ2112, PainfullySlo and Indy like this.
BIKES:
post #6 of 9 Old 05-20-2017, 04:28 AM
That's good..
Once I pulled the wrong wrench, wasn't inch pounds, was foot pounds.
post #7 of 9 Old 05-24-2017, 08:55 AM
I had an engine (used one from ebay) come to me that was suposedly unmolested and out of a great low mileage running bike.
What I found was every case bolt on the thing had been stripped (all the main bolts had zero threads- the smaller peremiter bolts would spin and spin and spin and spin only slightly tight)
At any rate..... the engine had been taken apart, 5 new transmission gears put in, and all three shift forks--but then they filled all the holes with silicone and pushed the bolts in and let it all cure and promptly sold said engine.....
The plus side for me......... I was taking it apart anyways and didn't "need" the cases.......and the $800 of brand new transmission gears and shift forks likely paid for the engine
But man what a pain in the ass to get those bolts out and the cases apart
I guess my point is.....People (not all, but too many) are liars and cheats and will say anything do anything to make a sale
PainfullySlo likes this.
post #8 of 9 Old 05-24-2017, 08:59 AM
fyi...cam cap bolts especially always feel like they are tighter when you first remove them, even when they have been properly torqued upon install
There have been times I have found them to "feel" so tight I actually pulled out the torqued wrench just to see how tight the break lose point is..... often I find over 120 inch lbs on spec trq of 94-104 inch lbs....
post #9 of 9 Old 05-24-2017, 12:16 PM
I Ride: ZX6R 636
I ran newton/meter to ft/lb conversion the wrong way once and tore the head off a cylinder head bolt in a VW engine. Fortnately it was the bolt not the threaded hole that gave way.
EZ Pull Clutch DIY sljackson Stunting 8 03-09-2016 07:29 PM
How To Pull FI Codes EvilTwin Guides 30 06-11-2012 10:08 AM
cylinder head questions DrewC Mechanical and Technical 7 09-28-2011 07:30 AM
head porting whats seen in gains pizzot Mechanical and Technical 31 09-20-2011 01:50 AM
& for my next medium distance day trip... kawasakifreak77 Motorcycle Talk 11 08-11-2009 09:15 PM
