Screws on Fuel Rail Stuck - ZX6R Forum
  • 1 Post By Turtleface
post #1 of 8 Old 06-17-2017, 07:15 AM Thread Starter
CodeMonkey's Avatar
I bought an '05 636 that I'm using as a project/flip bike. I'm going to clean the injectors, but the two middle screws on the fuel rail aren't budging and I can feel them wanting to strip. With limited space, due to the angle, what would y'all recommend? I'm just about to dremel the head and use a flathead screwdriver, but I'd rather that be my last resort since so much wiring is in that area.
Pictures for reference.
Edit: Sorry for the double circles, the pictures were way bigger when I edited them, so it was necessary.
ID:	66418   Click image for larger version
CodeMonkey is offline
post #2 of 8 Old 06-17-2017, 02:50 PM
U sure u got the correct sized screwdriver? Having the right size will help bigtime.
Try going a bit bigger.
post #3 of 8 Old 06-17-2017, 05:04 PM Thread Starter
CodeMonkey's Avatar
I made more room by removing the coolant reservoir and the screwdriver I'm using fits perfectly. Even using liquid wrench and that screwdriver, I still can't get it going. Ugh.
post #4 of 8 Old 06-17-2017, 05:16 PM
Turtleface's Avatar
I Ride: '07 ZX6R
If you have room, sometimes you can unstick screws by seating the screwdriver in the screw, and tapping on the end of the screwdriver with a hammer. A manual impact driver might work as well.
Rmkawi likes this.
Turtleface is offline
post #5 of 8 Old 06-19-2017, 08:31 AM
ely
ely's Avatar
I Ride: 09 ZX6R
Yes a manual impact driver is what I used they are pretty inexpensive at harbor freight
ely is offline
post #6 of 8 Old 06-19-2017, 07:36 PM
Steve Knecum's Avatar
Try a little valve lapping compound on the screwdriver tip. Make sure its the correct size. Also Airkroil is the best penetrating oil out there.
Sharpen a punch to a very sharp tip on a,gribder wheel and tap it loose with a light ball pein. But be careful. Try the 1st suggestion first
9 sec 636 in the making!!
Steve Knecum is offline
post #7 of 8 Old 06-19-2017, 07:46 PM
I Ride: 01 zx6r j1
Whippet container, freeze bolt, soak in blaster like it owes you money then manual impact screwdriver
Rmkawi is offline
post #8 of 8 Old 06-19-2017, 07:48 PM
I Ride: 01 zx6r j1
Froze bolts the same way for my carbs and it worked like a charm. Then if space provides use small hex bolt for replacement.
Rmkawi is offline
1995 ninja 600 fuel problem mitch Mechanical and Technical 4 06-17-2014 07:28 AM
Problem with fuel consumption Justus Mechanical and Technical 15 08-30-2012 02:19 AM
Draining fuel tank on 2012 ZX6R GlennCauley Mechanical and Technical 10 07-24-2012 01:41 PM
How To: Service Fuel Pump and Strainer ZoomSplat Guides 14 04-20-2012 05:40 AM
