How do you repair tank dent? - ZX6R Forum
 16Likes
post #1 of 21 Old 06-18-2017, 07:34 PM Thread Starter
I Ride: 2014 Kawasaki ZX-6R
So I crashed recently and now the right side of my tank is dented. I want to repaint it to prevent corrosion and thought that I might as well fill up the dent.
Any suggestions on what to use?
I was thinking of using Bondo filler.
Bondo Professional Gold Body Filler quart 233
Martillo y Mantequilla #99
post #2 of 21 Old 06-18-2017, 07:41 PM
Question is, do you trust yourself to fill it in really well to where you'll barely be able to tell it's there? I also doubt you'll be able to get the same finish when you paint over it as you'll get on the tank, and personally that would drive me crazy lol
If they're side dents like commonly seen on zx6r and r6 tanks, I just hid mine with R&G tank sliders ...can barely tell that it was dented.
2013 CBR500R (race bike)
2009 ZX6R (race bike)
sbk1198 is offline
post #3 of 21 Old 06-18-2017, 07:46 PM Thread Starter
I just need it to be "good enough". The tank dent doesnt bother me nearly as much as the frame scratches.
I'm buying those ricambi fairing so it'll cover the tank anyway. I would just like to prevent corrosion
sbk1198 likes this.
post #4 of 21 Old 06-18-2017, 08:10 PM
Ah...then why bother? Just paint it as it is, dented.
Did you contact Rob from MTR then for the fairings?
sbk1198 is offline
post #5 of 21 Old 06-18-2017, 08:21 PM Thread Starter
Yes I did. Ordering through them.
sbk1198 likes this.
post #6 of 21 Old 06-18-2017, 11:27 PM
Rab
Rab's Avatar
I Ride: ZX6-R 636 A1P
Buy a cheap dent puller. Ding king etc.
They use a glue gun (the glue removes easily) and then you stick the plunger in the kit to the dent, fit the cross member, turn the screw and pop out the dent.
Even if it doesn't pop all the way out you wont need as much filler and it will look alot better.
Make sure to sit the tank out in the sun to get it warm makes the metal easier to pull.
jd41 and Gawernator like this.
Rab is offline
post #7 of 21 Old 06-19-2017, 09:09 AM Thread Starter
I'm going to try and pop out the tent as best as I can. What kind of filler should I use? Is the Bondo Gold a good choice or is there anything better?
post #8 of 21 Old 06-19-2017, 09:38 AM
Backmarker's Avatar
A picture of the dent would help...
Backmarker is offline
post #9 of 21 Old 06-19-2017, 10:07 AM Thread Starter
post #10 of 21 Old 06-19-2017, 11:00 AM
mharrison's Avatar
I Ride: 1999 zx6r
That is MUCH too deep to fill as it. You'll have big chunks of bondo falling out. It is not intended to be more than a thin coat.
I would try the glue on puller as others have suggested if you are determined to fix it yourself.
jd41, Indy and Gawernator like this.
mharrison is offline
post #11 of 21 Old 06-19-2017, 11:57 AM
Looks like you can go into the top of the fill hole with a tool to knock it out some. Even if you have to make a basic tool to do it. Knock it out a bit further than needed and then slowly, carefully tap it back in to desired shape, sand and fill.
the prophet is offline
post #12 of 21 Old 06-19-2017, 01:39 PM
Backmarker's Avatar
yup...way to big to just fill...
post #13 of 21 Old 06-19-2017, 11:00 PM Thread Starter
Found a good method on how to go about fixing the dent
post #14 of 21 Old 06-20-2017, 05:22 AM
That's a lot of work for fixing a dent on a track bike. Just leave the dent as is and re-paint the tank to avoid corrosion later on.
sbk1198 is offline
post #15 of 21 Old 06-20-2017, 07:18 AM
Gawernator's Avatar
That's a big dent so I wouldn't leave it like that if possible. Try and pull it out
jd41 likes this.
http://www.gawerracing.com
Gawernator is online now
Realistic explosion danger; stud gun and gas tank asterix Mechanical and Technical 27 07-20-2014 02:12 PM
How to Remove Tank Slider vanderdjiang Mechanical and Technical 3 06-29-2014 11:52 PM
WTB 2003/2004 gas tank or trade my stunt tank for oem MeleeGarage Want to Buy 1 06-18-2014 05:52 AM
'95 ZX6R-F1 fuel tank question x69rzx The ZX6R 4 06-07-2013 01:57 PM
Can this gas tank dent be pulled? Lobster The ZX6R 22 02-25-2012 06:35 PM
