Cornering: Need some advise! - Page 2 - ZX6R Forum
 50Likes
post #16 of 205 Old 09-10-2011, 02:03 PM
los78's Avatar
I Ride: 2006 zx6r
Good information, have the same issue with my left turns. Glad I ran into this.
los78 is offline
post #17 of 205 Old 09-10-2011, 02:40 PM
yoshi's Avatar
I Ride: a 2006 zx6r
apart from the great advice on here remember to relax, dont tense up and BE CONFIDENT, a properly maintained bike can handle far more than you think
Formerly known as rotax81
My Facebook
Facebook
My Youtube Channel
yoshi is offline
post #18 of 205 Old 09-10-2011, 02:56 PM
ZoomSplat's Avatar
Originally Posted by EvilTwin View Post
^ much more thorough explanation.
09ZX-6R, what are your thoughts on rotating your foot on the peg so that your pressing on the end of the peg instead of the top?
Footwork is a very important part of setting up your body position. Rotating your inside foot and using your heel guard to plant your heel gives you a more solid base, allows for more accurate peg weighting, and helps align your lower body. Moving your outside foot forward and placing the arch of your foot on the peg will allow you to drive your knee into the tank harder and give that leg a break while you're not using it in the corner, allowing it to rest for the next time you turn that direction. These techniques will help you ride longer because your legs wont be tired as quickly.
ZoomSplat is offline
post #19 of 205 Old 09-10-2011, 04:55 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
so heres how it works...
improper foot and rider position before corner entry and prior to prepping.
proper rider and foot position prior to corner prep. (notice the feet moved back to the toes, and your ass slides to mid seat. this straitens the back and shoulders.
now to prep for your corner entry. this is where the toe meets the peg nipple and the heel rotates up onto the heel guard. this in turn allows your knee to rotate out correctly with no effort or strain.
then slide your entire body to the side of the bike (in this case, to the right) so your asscrack meets the edge of the seat and your chest is inline with the mirror.
impropper position aka being crossed up
propper position
from there you will then lean your body forward and bend your inside elbow and straiten your outside arm.
the outside arm and leg should look like this. the elbow straitened but not locked, your knee griping the tank and foot slightly forward on the peg.
then relax your body and lean the bike into the turn while looking over your elbow and remaining tucked to the inside of the bike.
at this point alot of riders and some new racers are sketchy about hanging off the throttle side because there right hand and arm are unpredictable with maintaining body posture and control. the usuall mistake is this when the body is positioned but the hands are not. notice the bent wrist. causes strain and hard throttle control.
the best hand position is this... it maintains control and is totally strain free. quite comfy too.
Lobster, darren, mousematt and 9 others like this.
09ZX-6R is offline
post #20 of 205 Old 09-10-2011, 04:58 PM
silversurfer's Avatar
awesome post 09
silversurfer is offline
post #21 of 205 Old 09-10-2011, 05:03 PM
MG815's Avatar
I Ride: 03 636
^^^^ That is awesome! Thanks! I just went out myself for the first time on my bike through some twisties, I took it nice and easy, however I really wanted to get a visual on how to properly go through the corners. I did the half butt off the seat, outside knee clamped to the tank, and inside knee towards the curve, but it just felt so sketchy. I have a buddy I ride with who has a GSXR, been riding for years and he keeps telling me the bike will be able to handle so much more than I think it will. I thought I was leaning a lot, apparently I was barely leaning over according to him haha
MG815 is offline
post #22 of 205 Old 09-10-2011, 05:04 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
if you notice my avatar you can see the inside of a lean with proper body posture and knee down. its not a fast corner so my body is slightly upright. this is ok do to the fact that the g-force and angle of lean dont require to much low Center of gravity tucking.
09ZX-6R is offline
post #23 of 205 Old 09-10-2011, 05:10 PM
ZoomSplat's Avatar
Using your outside knee into the side of the tank will allow you to control your position relative to the bike without making any unintentional inputs through the bars. Placing the peg on the arch of your foot will give your muscles on the outside leg a break. This, in conjunction with your knee in the tank, will keep you from weighting that peg and upsetting the chassis.
As for arms, I usually bring my inside elbow in just a little bit, more out of habit than technique, and use my outside forearm against the side of the tank at times. This gives me another hard point against the bike, and provides a reference of my body position and angle vs that of the bike.
One thing I would add is that once you've prepped for the corner, you're hanging off already and have your speed set and about to tip in, do not move. You've bought that real estate. That's yours to keep, but don't alter it. If you're not off far enough, tough shit, you're going to have to adjust for it with your speed and you just lost a tenth through that corner. Adjusting BP in lean and at speed will upset the chassis, and could potentially result in an off. You may find that you have some wiggle room in some corners at a given speed, but its best to not try until you're comfortable with whats going on and have built the muscle memory to avoid mistakes.
post #24 of 205 Old 09-10-2011, 05:10 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
heres a better view of me. same as the avatar just bigger.
heres one of full tuck, high g-force, medium lean angle, high speed corner exit and passing of 2 riders. notice how far over the side i am. the more the better and fast it will be. also, the more upright the bike can be to allow for hard acceleration.
MasterTurkey and Tigerbee like this.
09ZX-6R is offline
post #25 of 205 Old 09-10-2011, 05:11 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
i hope all this helps.
09ZX-6R is offline
post #26 of 205 Old 09-10-2011, 05:19 PM
PHOENIXZX's Avatar
I Ride: ZZR600
Awesome info guys...thank you
Sam
Two Brothers CF Bolt On, Hotbodys Undertail, Flush Mount Turn Signals, LED Integrated Tail Light, LED lighting,NO MORE~~~~~ Extended Swing Arm (YANA SHIKI LRC BILLET SWINGARM EXTENSION -6 INCH ~~~~~, Blacked out Wind screen. Fender Eliminator, De-Baged.Swing arm spools Gear: Joe Rocket Blaster leather jacket, AGV Mesh textile, Alpine star Gloves, KBC Black helmet.
PHOENIXZX is offline
post #27 of 205 Old 09-10-2011, 05:54 PM
lbzx6's Avatar
I Ride: 08 ZX6
Thanks I am book marking this thread great explanation and pics 09
lbzx6 is offline
post #28 of 205 Old 09-10-2011, 06:16 PM
hulkmn069's Avatar
I Ride: 2007 ZX6R
This thread makes me want to turn my bike into a track bike so much worse than before. Now if only I could make 40lbs dissappear from myself tomorrow and afford tires body and fees.... I can wait on the forks and shock. lol on the bright side I did replace my spongy stock lines with some stanless twin lines and holy S what a diffrence.
hulkmn069 is offline
post #29 of 205 Old 09-10-2011, 06:18 PM
Super Moderator
EvilTwin's Avatar
Sure. I can do that.
Evil...the position of your toe will be on the peg nipple wen ur heel is rotated up onto the heel guard. Its normal but u dont want to have it so far out u drag toes in corners.
There's a reason I need a new toe slider on my right boot... part of it is how I plant the ball of my inside foot on the end of the peg and partly b/c the pegs on my track bike had an inch cut off of them to give me more clearance, so then my boot was always overhanging a bit.
EvilTwin is offline
post #30 of 205 Old 09-10-2011, 07:08 PM
djnerek's Avatar
I Ride: 08 kawi green zx6r
good stuff. im not as confident in my right cornering either. probably because of the throttle.
mods: two bros m5 slip-on, mjs performance headers, two bros juicebox, k&n air filter, 12k ddm tuning HID kit (low and high), frame sliders, puig tire hugger, relocated back brake reservoir, jt sprockets (stock sizing), rk gold chain, de-badged, speedo drd, green leds inside fairings, sportbikelites integrated brake light, ebay levers (shorties) .....whats next
djnerek is offline
cornering
09zx-6r supersport
ass placement on seat while knee dragging on sportbike
corect sportbike riding posture
cornering hang off
motorcycle cornering
motorcycle cornering foot position
proper position cornering
proper sportbike posture
sportbike cornering body position
sportbike cornering position and technique
supersport motorcycles
zx6r 09 right foot peg
question for all you cornering gods vividlust Mechanical and Technical 45 09-17-2011 03:09 PM
advice on cornering?? steveplue The ZX6R 42 07-21-2011 12:15 AM
Hi, newbie in need of tyre advise Vodka Monsta United Kingdom 37 04-25-2011 06:22 PM
Advise please.... kman73 United Kingdom 19 01-13-2010 04:40 PM
Cornering on a 2006 ZX6R nightfir96 The ZX6R 23 08-12-2009 06:16 PM
