Cornering: Need some advise!This is a discussion on Cornering: Need some advise! within the Motorcycle Talk forums, part of the ZX6R Forum category; Hi All,
I am faced with this strange issue going into Right Hand Corners. I always overshoot and find my self in trouble if I ...  |
09-10-2011, 10:38 AM
#1 | | Team Green
Joined: May 2011 From: Winston Salem Posts: 109 I Ride: 2011 ZX6R | Cornering: Need some advise!
Hi All,
I am faced with this strange issue going into Right Hand Corners. I always overshoot and find my self in trouble if I am trying to make a hard right corner.
No problem what so ever with left hand corners, I can literally turn at 30 degree angles (or less even!) without my knee down.
What am I doing wrong and what do I need to do to get better at it?
09-10-2011, 10:41 AM
#2 | | Post Master General
Joined: Sep 2010 From: VA Posts: 8,731 I Ride: 2009 GREEN ZX6R |
body position.
slide your but towards the inside. put your head towards the inside mirror. smooth throttle. look through turn.
09-10-2011, 10:50 AM
#3 | | MotoGP Champion
Joined: Oct 2008 From: Walnut, Ca Posts: 2,646 I Ride: 07 ZX-6R street, 03 636 track |
Slow corners or fast corners? the main thing is to look where you want to go, but body position is dictated by speed. In a slow corner, like really slow, you lean the bike over and keep your body upright. Any time your trying to take a corner as fast as possible, you should scoot off the seat, drop your upper body down to the right side (or left if you going left) of the tank, and look though the corner along the line you want to take.
09-10-2011, 10:56 AM
#4 | | Pro Racer
Joined: Oct 2009 From: Orlando Florida Posts: 779 I Ride: 2010 ZX-6R |
well its hard to explain properly without a visual. but, ill try... prior to entering your corner you should be preped for entry. meaning you body position should be already proper. upon entering your ass should be mid way up the seat and your asscrack should be on the inside edge of the seat, or pad, which ever u have. your feet should be set so that the balls of your feet are on the pegs. your knee to the inside should be pointed out wards and your inside heel should be rotated up onto the heel guard. this will assist your knee in the propper position. your outside knee should be planted against the tank to hold your body weight. then your upper body should also be low and inline with the inside of the bike where your mirror is or should be to include your head. your outside arm should be semi strait over the tank and your inside arm should be damn near 90 degrees at the elbow. your head should be looking over your elbow and thru the turn. now alot of people are a bit uncomfortable with leaning in on the throttle side. this is due to the fact that they may twitch the throttle by accident and get screwed up. the best method to combat this issue is to turn your inside hand outward inline with your forearm when bent. in other words, not to sound dirty, it should look as if your stroking the throttle from the outside. get it? this way you can control the throttle and front brake properly without the feeling of strain on your wrists. if you need i will post pics. let me know. Im a race coach here at the local tracks. so this is something we deal with alot.
eviltwin also is correct. the faster the corner then the more your body position plays into it.
09-10-2011, 11:00 AM
#5 | | World Superbike Racer
Joined: Apr 2011 From: Martinsburg WV... originally from Annapolis Md... Posts: 1,742 I Ride: 2007 Kawasaki Ninja ZX6R (gone) looking for another |
interesting......
09-10-2011, 11:01 AM
#6 | | MotoGP Champion
^ much more thorough explanation.
09ZX-6R, what are your thoughts on rotating your foot on the peg so that your pressing on the end of the peg instead of the top?
09-10-2011, 11:12 AM
#7 | | Squid
Joined: Jul 2011 From: KCMO area Posts: 92 I Ride: 2011 Candy Plasma Blue ZX6-R |
09ZX-6R,
Obviously, I didn't ask the original question, but I could use the advice. Your explanation is very detailed; the problem is I have practically no imagination and cannot visualize what you are describing. Particularly the arm/hand position. I would find the pictures you mentioned very helpful, if you wouldn't mind.
Thanks,
Mike
09-10-2011, 11:19 AM
#8 | | Team Green
Joined: Aug 2011 From: Northwest, UK Posts: 163 I Ride: ZX6R C1h (636 2005) | Quote:
Originally Posted by 09ZX-6R well its hard to explain properly without a visual. but, ill try... prior to entering your corner you should be preped for entry. meaning you body position should be already proper. upon entering your ass should be mid way up the seat and your asscrack should be on the inside edge of the seat, or pad, which ever u have. your feet should be set so that the balls of your feet are on the pegs. your knee to the inside should be pointed out wards and your inside heel should be rotated up onto the heel guard. this will assist your knee in the propper position. your outside knee should be planted against the tank to hold your body weight. then your upper body should also be low and inline with the inside of the bike where your mirror is or should be to include your head. your outside arm should be semi strait over the tank and your inside arm should be damn near 90 degrees at the elbow. your head should be looking over your elbow and thru the turn. now alot of people are a bit uncomfortable with leaning in on the throttle side. this is due to the fact that they may twitch the throttle by accident and get screwed up. the best method to combat this issue is to turn your inside hand outward inline with your forearm when bent. in other words, not to sound dirty, it should look as if your stroking the throttle from the outside. get it? this way you can control the throttle and front brake properly without the feeling of strain on your wrists. if you need i will post pics. let me know. Im a race coach here at the local tracks. so this is something we deal with alot.
eviltwin also is correct. the faster the corner then the more your body position plays into it. | This is why I love this forum!! properly good advice |
09-10-2011, 11:39 AM
#9 | | Superbike Champion
Joined: Jul 2011 From: MD Posts: 1,058 I Ride: a Schwinn | Quote:
eviltwin also is correct. the faster the corner then the more your body position plays into it. | I've been told with all of this too that I should push my shoulders inline with the curve to help avoid riding crossed up. Comments on this advice given to me?
09-10-2011, 11:52 AM
#10 | | MotoGP Champion
Joined: Sep 2010 From: MD Posts: 3,817 I Ride: Dreaming of a BMW S1000RR |
I think we forgot to mention counter steering.
09-10-2011, 12:06 PM
#11 | | World Superbike Racer
Joined: Apr 2011 From: Martinsburg WV... originally from Annapolis Md... Posts: 1,742 I Ride: 2007 Kawasaki Ninja ZX6R (gone) looking for another | Quote:
Originally Posted by EvilTwin ^ much more thorough explanation.
09ZX-6R, what are your thoughts on rotating your foot on the peg so that your pressing on the end of the peg instead of the top? | LOL yea... hey good info though..
09-10-2011, 12:17 PM
#12 | | MotoGP Champion
Joined: Oct 2008 From: Walnut, Ca Posts: 2,646 I Ride: 07 ZX-6R street, 03 636 track | Quote:
Originally Posted by HotIce I think we forgot to mention counter steering. | I've never been conscious of counter steering, it's always been something I've just done, therefore I always forget to tell people to do it.
09-10-2011, 12:53 PM
#13 | | Team Green
Joined: Jul 2011 From: Phoenix, AZ Posts: 235 I Ride: ZZR600 | Quote:
eviltwin also is correct. the faster the corner then the more your body position plays into it. | Great advise... would you mind posting pics if you have them?
09-10-2011, 01:05 PM
#14 | | Track Star
Joined: May 2009 From: FT Hood Posts: 492 I Ride: 08 ZX6 | Quote:
Originally Posted by PHOENIXZX Great advise... would you mind posting pics if you have them? | +1
09-10-2011, 01:47 PM
#15 | | Pro Racer
Sure. I can do that.
Evil...the position of your toe will be on the peg nipple wen ur heel is rotated up onto the heel guard. Its normal but u dont want to have it so far out u drag toes in corners.
| | | Search tags for this page | | motorcycle cornering
