10 kawasaki zx6r clutch problem - ZX6R Forum
post #1 of 6 Old 06-02-2013, 10:13 AM Thread Starter
I Ride: 10 zx6r
So, I recently got a 2010 zx6r with 1500miles on it. The bike runs great but when I bought it the clutch was kinda weird. It seemed like the adjustments were wrong so I adjusted the clutch lever spin dial first, and it seemed to be ok after that. A few days later it was doing the same thing(moving while the clutch was in gauged. Holding the clutch lever in and putting the bike in first would stall it most of the time) when that happen I adjusted the cable by the engine and that seemed to help a lot. A few days later I had to adjust it again and again and finally after I got to the end of the cable it wouldn't even let me shift. At this point I ordered a clutch thinking this was the problem. I put the clutch in just like the service manual said. The problem I am having now is the clutch release rod won't caught the other rod inside the clutch. It is doing the same exact thing it was doing before, even with the new Barnett clutch. So the clutch plates and springs were not the problem. Dose anyone know what my problem could be. The bike shop is of no help and it seems they want me to destroy my bike. They told me to do a burn out and that might fix it(I have no oil in my engine due to the fact that. I was changing the plates out) so I don't think they know what they r doing so I'm not taking my bike there. Help please!! if I knew how to send pics I would. I'll find out in a few min tho.
Loganvortex is offline
post #2 of 6 Old 06-02-2013, 10:19 AM
ZXROM's Avatar
I just had that problem on my 08 all I did was replace the pin that sticks out from the clutch basket.
Though your bike is much newer with less miles, still check out my old thread, maybe it will help. Good luck.
Bah... stranded again, clutch issue
ZXROM is offline
post #3 of 6 Old 06-02-2013, 10:26 AM Thread Starter
I Ride: 10 zx6r
Thank you zxrom the pic of your arm looks a lot better than mine dose. The rod inside my clutch looks perfect . So I'm going to order the 2 parts today from bike bandit there prices are kinda height but they can deliver with express shipping and that sounds good to be do to the fact that my bike has been sitting for 3 weeks. Thank you again
post #4 of 6 Old 06-02-2013, 10:29 AM
ZXROM's Avatar
Since you got an aftermarket clutch, I'd check and make sure the pin length i correct and the pin to rod clearance is correct as well, also when you install the clutch cover back on, the rod needs to be at a certain angle, it's in the repair manual.
Btw, how is the cable itself?
ZXROM is offline
post #5 of 6 Old 06-02-2013, 10:45 AM Thread Starter
I Ride: 10 zx6r
Oh ok. Just ordered the parts. The clutch cable seems to be ok. I don't see any damage to it.
post #6 of 6 Old 06-03-2013, 05:23 PM
Seems that clutch problem is really a problem with zx model even with my friends zx12 and zx9r. But once you change the clutch kit with aftermarket once problem will be solved.
kartl is offline
2005 Kawasaki zx6r part out bob636kawi Classifieds 14 11-15-2013 10:07 AM
2005 Kawasaki 636 ZX6R Race / Track Bike friedcalamar Classifieds 1 09-16-2012 09:27 PM
FS: 2005 kawasaki zx6r ninja 636,raw titanium,new tires,exhaust,perfect,230 pics MJW7800 Classifieds 0 04-20-2012 11:53 PM
FS: Kawasaki ZX6R 636 DynoJet Power Commander PCIIIusb 05/06 UKBrad Classifieds 3 03-12-2012 12:59 PM
