Initial Review of my Aprilia RSV4R. - ZX6R Forum
post #1 of 16 Old 06-06-2015, 04:15 PM Thread Starter
I Ride: 2014 RSV4R, 2012 ZX6R
I picked up a matte black 2014 RSV4R a couple of days ago on a deal that was very, very hard to walk away from. Here are my initial impressions.
Engine
Probably the defining aspect of this bike. 65* V4, 184 horsepower. Let's start with the sound. There's nothing like it. Even with the stock pipe, it sounds like the armies of hell has been unleashed! This is the sound that every sportbike strives to have! If you haven't heard it, I urge you to go to YouTube. It's definitely a bad guy bike, if there ever was any. Power wise, there's no shortage here. It delivers power in a very linear fashion, with a very strong mid-range and top end. It makes peak HP at 12,500 RPMs but doesn't drop off all the way to its 14,200 RPM redline. It's also very smooth. Not I-4 levels of smooth, but it's pretty close.
The engine doesn't wake up until past 6000 RPMs and it just accelerates smoothy past to the redline. No power dips, no strange powerband, no surprises. Your powerband is 6000 - redline, which is huge. However, what hurts it in practicality is...
Transmission and Gearing
It's geared high. Like, ridiculously high. I've done a 1st gear redline run and the indicated MPH is over 95 MPH. Insane. Due to the high gearing, you generally can't be lazy with this bike. The right gear for the right corner. No riding one gear higher since below 5000 RPM, you're lugging the engine. Not good. No 6th gear highway cruising unless you're above 70 MPH. At 55 MPH, I'm at 4th gear cruising. If I shift to 5th, I'd have to accelerate to keep the revs up so I don't lug the engine. It takes a while to get used to, and if you're riding really tight and twisty tracks and/or roads, be prepared to corner in 1st or 2nd gear. Luckily, the fueling is spot on.
Shifting the bike is smooth like butter. Downshifting in the same. There's a lot of engine braking as well. Something else to get used to. The slipper clutch is great. I banged downshifts from high revs and I never had an issue of the rear stepping out. Clutch pull is light, but can be a little tricky finding the engagement point. There's also a quickshifter(upshifts only) which allows you to upshift without pulling the clutch or even closing the throttle. As a matter of fact, the only way to quickshift is to hold the throttle open. Never had a bike with a quickshifter before, but it's so nice to have. The gears just fall in to place with no glitches or hiccups. It does what its told.
Chassis/Suspension/Ergos
I have the R instead of the Factory, so I don't have the adjustable stuff on the frame or the Ohlins forks and shock. Touted as the best superbike chassis out right now. The unpainted frame and swingarm is aesthetically pleasing to the eye. I've always been a huge fan of bare frames and swingarms. They look great! Never have I ever ridden a bike that imparts such confidence while at lean. This frame is solid. It's insanely stable. So much so, that I had to modify my lines doing the same roads as I did with my 2012 ZX6R. Corner entry is likewise, a no fuss affair. Front end feel is astounding while on the brakes and turn in is very stable. It's so confidence inspiring, that I was dragging knees with 200 miles on the bike. And I haven't even set up compression and rebound yet(but sag has been set for my weight).
This comes with the standard cartridge forks and a Sachs shock. Despite being lower spec, they pair very well together on the bike. I haven't set it up the way I like it so I can't speak on the weaknesses of the stock stuff. That being said, the ride is quite compliant. It's not overly stiff like the 09-12s suspension. For street riding through uneven surfaces, it absorbs bumps quite well. It's almost... comfortable.
The riding position is, surprisingly similar to the 09-12 ZX6Rs. The bars are a little narrower and slightly forward. Clip-on height in relation to the way you sit is also similar to the 6R. The pegs are set higher on the RSV4, but due to the high seat height, my knees are actually slightly less bent when the balls of my feet are on the pegs. The position is definitely in line with sportbikes. It's no GSXR1000 in terms of comfort, but it's not 998 levels of discomfort either. I can ride this bike for a whole tank without feeling like I need to stretch. Those coming from the 09-12 ZX6R will find it easy to get comfortable with the bike.
The seat heigh is 33.3 inches. Heck, maybe taller since it comes with a 200/55 rear tire. The seat is wide. It's no-nonsense, racebike levels of seat height. I'm 5'7 with a 30" inseam. I am literally on the tips of my toes at a stop. Just barely touching the ground on both sides. I have to put one foot down flat. I won't be able to back this bike up without getting off and pushing it or if the surface is flat or downhill. Not recommended for short guys(like me!) unless you have a lot experience riding tall bikes in the street. At the track, it doesn't matter.
Electronics
This bikes comes with APRC. 8+off level traction control, 3+off levels of ABS, 3 level launch control, 3+off levels of anti-wheelie control, and 3 fuel maps. I don't see how anyone can tame this bike without all of this electronic tomfoolery. I had my TC level set to 6, which is 2 levels down from being the most intrusive. In one corner, I got on the throttle harder and sooner than I normally would. I saw the TC light flash and felt my line tighten up. The way it intervenes is so transparent, you can't even feel it.
I have yet to activate ABS on this bike, so I can't speak on it. I set my AWC to level 3, and did a full throttle 1st gear run. I felt the front lift a little, and gently settle back to the ground. It's nice. Launch control, I will probably never use.
The 3 maps include Road, Sport, and Track. Road limits power output to 140 hp and softens throttle response in the first 3 gears. Sport has full power, but also has softer throttle response in the first 3 gears. Track has full power, and immediate throttle response. I use Road mode for longer rides to and from my riding roads. Sport is a good way to learn the bike without biting off more than you can chew. And Track is just insane levels of response and power. I wouldn't use Track if you're hamfisted and can't modulate.
TC as adjustable on the fly via + and - buttons on the clutch side. And you can switch between the 3 maps on the fly via starter button on the throttle side.
Brakes
It comes with Brembo monoblock front calipers and a Brembo master cylinder. The rear is also a Brembo set up. Steel braided lines are standard. It doesn't have the initial bite from the Nissins in the 09-12s, but it's much easier to modulate. Braking power is immense. I thought the 09-12s brake set up was the best I've ever had, but the brakes on the RSV4 trumps that. This bike will stop quickly. And stoppie quite easily if that's your thing. I always found it tricky to trailbrake with the 09-12 ZX6R due to the hard initial bite, but the setup on the RSV4 makes it crazy easy. I have yet to activate ABS so I can't speak on it.
Rear brakes? I don't use them unless I want to get the rust off of the rear rotor.
Build Quality/Appearance
The bike is built solid. In a typical Italian fashion, they skimp on the little things like the footpegs, clip-ons, and levers. My 2012 ZX6R had nicer pegs, clip-ons, and levers. But everything else is put together quite well. Only time will tell how reliable this bike is, but from what I've read in the Aprilia forums, there are only a handful of bikes with issues. I hope mine isn't one of them. The paint is nice and of high quality. Almost BMW levels of thickness. I have a matte black bike(almost graphite in certain lighting conditions) so I never have to worry about spider webbing.
I've always been a a huge fan of the looks of the RSV4. The 3 headlamps, the half-fairing exposing the beautiful engine, the really, really short tail, the agile stance... It all comes together nicely. The Italians know how to make good looking bikes. And I'd take the looks of the RSV4 over a Panigale or an MV Agusta.
Practicality
You will find none here. It comes with passenger pegs, but you have to buy a passenger seat, which doesn't look comfortable. It comes with a seat cowl. Under it has no room for anything besides your paperwork. And even that is a tight fit. The little tool kit is under the seat, which must be removed to gain access to it. Theres a little allen key under the seat cowl to remove the 2 bolts holding the seat. Under the seat has no room either. That's where the battery is located. I'm a little disappointed that I can't even find a place to put my tire pressure gauge on the bike, so I guess I'll need to carry it in my jacket from now on.
This bike is not designed for commuting. The gearing is tall. In traffic, you'll be in 1st gear most of the time. As far as MPGs go, I've averaged about 30 MPG with cruising to and from my riding location and aggressive sport riding. However, I have heard of people getting as low as 24 MPG(or lower), and as high as 35 MPG. It's not frugal. It's a thirsty beast. Luckily, the tank is 4.9 gallons. But I imagine my range will be a little over 100 miles a tank with a mix or riding hard and cruising. I found that between 5000 and 6000 RPMs is the the sweet spot for fuel efficiency. So I try to stay around there when I'm just transiting.
There's also the heat. This engine runs hot. At 60 MPH on a 80* day, engine temps hover around 180 to 190*. There's also the radiating heat. It's hot! At a stop, you'll feel your legs roast. My butt doesn't feel the heat, unlike a Panigale, but my legs are roasting.
It comes with Pirelli Diablo SuperCorsa SPs. The rears seem to have a dual compound just by looking at them and I'm not too sure about the fronts. I'll be lucky to touch 3000 miles with those tires. I would not suggest riding with them when its raining. For long distance riding, increase the pressure on the rear and lower them when you get to the fun roads. But you can't carry your tire pressure gauge on the bike. So that's a conundrum. It's not very practical.
Overall Package
It's a smooth, great handling bike. It turns with with a little more effort than a 600, yet it retains the stability of a superbike. It's one of those bikes you have to commit to while cornering. If you're not smooth, you'll know. But if you're smooth, have good lines, and COMMIT, the bike works with you to go even faster. Trust the tires. Trust the chassis. Commit to the corner. And your comfort level with rise along with your corner speeds. It's not a particularly forgiving bike, but the electronics and ABS can potentially save you and you'll shit your pants in the process. I do NOT recommend this bike for beginners. AT ALL. If you've been riding your first bike for 6 months and decided you need to upgrade, DO NOT choose this bike. To make the most out of this bike, you should have done track days and rider education. Otherwise, you'll never even get to 50% of what this bike is capable of. And you'll shit your pants more often than not. It's a very intense and tiring experience riding one of these. It's truly an overload of the senses. Even with my paltry 8 years riding experience and having owned 3 sportbikes in the past, and having done numerous track days, this bike can be a handful. I'll have to adjust my riding style and lines to get the most out of this bike.
Conclusion
I've read and watched videos stating that this bike is a race bike with lights. I've always been a little skeptical of that. As they say that for all sportbikes. But I found that it's the truth. This bike is made to win races. From the tall seat height, to the even taller gearing, to the immense heat generated, to the paltry MPGs, there were no compromises made on this bike. If you're looking at an RSV4 for commuting, you're looking at the wrong bike. For me, this bike is for weekends and days off, and track days(I ain't 'bout dat ride erryday life yo!). If you want a high performance machine that makes no concessions for practicality, this is the one.
I can honestly say that the RSV4 is in fact, closer to a race bike than a street bike. It's an amazing piece of machinery.
Off Camber likes this.
-2014 RSV4R
-2012 ZX6R
almazing is offline
post #2 of 16 Old 06-06-2015, 04:18 PM Thread Starter
Initial Review of my Aprilia RSV4R.-imageuploadedbytapatalk1433632615.732606.jpg
Initial Review of my Aprilia RSV4R.-imageuploadedbytapatalk1433632630.436554.jpg
Initial Review of my Aprilia RSV4R.-imageuploadedbytapatalk1433632641.427866.jpg
Initial Review of my Aprilia RSV4R.-imageuploadedbytapatalk1433632653.548166.jpg
Sorry about the lack of, and crappy pics. I've been doing more riding than taking pictures.
-2014 RSV4R
-2012 ZX6R
almazing is offline
post #3 of 16 Old 06-06-2015, 05:54 PM
ZX6ARE's Avatar
I Ride: 2010 ZX6R
Such a thorough and detailed review. Great stuff and congrats on the new bike. These Aprils look insane. FASHION FOR SURE!
Just curious, what made you choose The RSV4 over say, the S1000 Or a Ducati ?
2010 ZX6R
M4 CF Street Slayer l XDCycle FE Kit l 5000k HID Hi Lo l LED Parking Lights l OES No Cut Sliders l
ZX6ARE is offline
post #4 of 16 Old 06-06-2015, 06:00 PM
RobMoore's Avatar
I Ride: '15 FZ 07, '08 SV650, '05 ZX6R
^ because V4?
RobMoore is offline
post #5 of 16 Old 06-06-2015, 06:08 PM Thread Starter
I've always had a soft spot for the RSV4 even when they first came out in 2009. That V4 engine and looks you can't really compare to any other bike. Plus saying "R-S-V-4" has a certain ring to it. I has loads of personality. Plus aftermarket part prices are generally in line with Japanese sportbikes. And I got a killer deal.
The BMW S1000RR is nice and is insanely fast. But it feels... normal. I think the BMW is the best built sportbike out here. It just oozes quality. The Germans know not only how to build things, but overbuild them. In my neck of the woods, it's ridiculously hard to get one at a discounted price. Supply and demand.
The Ducati Panigale is a very, very pretty bike. I've owned 2 Ducatis in the past and I wanted something different. I don't like that the fact that the 1299 or 1199 cost nearly 20K and the S version of those are thousands more. And then there's the insane maintenance costs. Being a frameless design, it generally needs to be disassembled to do the inevitable valve clearance checks. That's about 2K every 15000 miles. Not something I'm OK with. Plus the cost of parts are insane. An Akrapovic slip on is nearly 3K. And there aren't too many slip-ons or exhaust systems to choose from. It's an expensive bike to begin with, and the spending won't stop at the purchase of the bike.
badgerninja likes this.
-2014 RSV4R
-2012 ZX6R
almazing is offline
post #6 of 16 Old 06-07-2015, 01:32 AM
lockey99's Avatar
I Ride: 03 gsxr600 (sold) 08 zx6r (sold) 08 r1 (current)
My colleague Pete who now has the h2 (see last page on master h2 thread) part exchanged his rsv4 factory in for it. He said it was a fantastic bike but also had many issues with his (failed stator, leaking fork seals, wireless throttle issues etc)...all within the first 5k miles...he did however praise the bikes balance and loved the engine although said he still preferred the smoothness of his 06 sp edition r1. I do think personally though the rsv4s look exquisite
lockey99 is offline
post #7 of 16 Old 06-07-2015, 04:47 AM
Very jealous. That bike is in the #1 spot on my "want" list.
FYI the lugging, right gear for the right turn, and lots of engine braking are characteristics of every v2/v4 out there.
Enjoy the bike, that is one hell of a ride.
PainfullySlo is offline
post #8 of 16 Old 06-07-2015, 05:02 AM Thread Starter
What year was his RSV4?
-2014 RSV4R
-2012 ZX6R
almazing is offline
post #9 of 16 Old 06-07-2015, 05:06 AM Thread Starter
The RSV4R are being sold at hugely discounted rates. With a little research and footwork, they can be had for an affordable price.
I used to ride Ducatis, so I kinda forgot about how different they are compared to I4s. However, I didn't realize that the V4 would be more similar to a twin than an I4. It's one hell of an engine.
-2014 RSV4R
-2012 ZX6R
almazing is offline
post #10 of 16 Old 06-07-2015, 05:22 AM
lockey99's Avatar
2013
lockey99 is offline
post #11 of 16 Old 06-07-2015, 08:19 AM
ZX6ARE's Avatar
I Ride: 2010 ZX6R
Originally Posted by RobMoore View Post
^ because V4?
Below what what i was looking for.
Thanks again. Ive never ridden an RSV4. but i have a ducati and an S1000. which is why i asked the question. I can agree that the S1000 is a monstrous bike but it is almost, regular so to speak. just has the best parts available. And the duc's are gorgeous. but one thing about both Duc and BMW is not only is the primary purchase expensive, but tagging what you mentioned, the PARTS are literally insanely expensive as well. Wl the cost of doing an exhaust, filter, and basic other upgrades you could have purchased a Jap bike lol.
Glad you like the Aprilla, hopefully one day ill ride one and see what its all about. I did have my heart set on a S1000 within a season or 2.
2010 ZX6R
ZX6ARE is offline
post #12 of 16 Old 06-07-2015, 08:20 AM
spiderman636's Avatar
I Ride: 2005 zx6r
OP saw your post on NCS as well. sorry to go off subject but post up sometime if you are ever wanted to ride. I am in the NC mountains quite often typically morganton, marion, lil swiss, roan mountain area somewhere.
great write up btw.
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, 'Wow! What a Ride! ~Hunter S. Thompson
spiderman636 is offline
post #13 of 16 Old 06-07-2015, 08:43 AM Thread Starter
great write up btw.
Would love to join you for a ride. I don't have a hard date of when I'll be up in the mountains again. When I head that way, I generally spend the night so I'm not riding for 16 hours straight. I need to find a discreet and low profile luggage solution for my new bike though.
-2014 RSV4R
-2012 ZX6R
almazing is offline
post #14 of 16 Old 06-07-2015, 08:08 PM Thread Starter
Did some riding today and I think I finally got mentally and physically used to the RSV4. God, this bike is insanely stable while cornering. I've never been on a more stable bike while at deep lean angles. It's a paradox how heavy it is(450-ish lbs wet!), yet it's so stable in the corners, turns in with ease, transitions from left to right like a pendulum, and willing to change lines at will. All without upsetting the chassis. Trailbraking on the RSV4 is insanely easy. If you're pretty good at trailbraking, you'll find that doing so in the RSV4 is like child's play. The chassis is very communicative and the grip at the rear is immense. It's almost like it's saying, 'Broooo, you can lean more and go faster. I'm just chillin' right now. Is that all you've got?' I'm sure that the stock Supercorsa SPs have a lot to do with it, but I certainly don't think anyone owning this bike would go with a tire with less grip than say, Michelin PP3s.
I still think the front end feedback on the 09-12 ZX6Rs is better by a small margin, but it can't match the stability of the RSV4. The stock rear shock on the RSV4 is certainly a significant step above the stock rear shock on the ZX6R. The 'feel' is there and is not 'detached'. I find myself cornering much faster than I ever would with the ZX6R, and it's not the TC or the power advantage the RSV4 has. It's the amazing chassis Aprilia has designed.
-2014 RSV4R
-2012 ZX6R
almazing is offline
post #15 of 16 Old 06-08-2015, 07:12 PM
razorzedge's Avatar
Great review! And definitely a good looking bike.
razorzedge is offline
2011 Aprilia RSV4R APRC First Ride HotIce Motorcycle Talk 0 07-18-2011 08:21 PM
