Engine Oil Pan Heat Pad - ZX6R Forum
  • 1 Post By RJ2112
post #1 of 4 Old 02-06-2017, 01:36 PM Thread Starter
PhilRupp's Avatar
I Ride: 2013 ZX6R 636
Just A thought....I work above 11300FT at a mine and well. I have thought about adding a heat pad to the oil pan. Just to keep the idle time low on my warm up. I was looking at having the pad warm up about 30-45 minutes prior to me actually starting the bike up. I don't plan on run the heat pad on all day or night, to avoid creating condensation in the engine. I have a older friend that has tried this and never had issues with condensation in the engine.
Just a NEWB, trying to get a feel and concerns on this topic.
PhilRupp is offline
post #2 of 4 Old 02-06-2017, 03:13 PM
The best way to warm up your engine, is to ride the bike as soon as you start it. Don't romp on it, just ride it easy until you see a temp displayed, then operate as normal.
PhilRupp likes this.
post #3 of 4 Old 02-07-2017, 04:44 PM Thread Starter
PhilRupp's Avatar
Thanks, I'll treat her like a normal commute then. It is probably better anyways...cold tires and cold road....yeah wouldn't want to have my first road incident all because I get over confident on only having the engine up to temp.
Thanks for the response
PhilRupp is offline
post #4 of 4 Old 02-07-2017, 05:09 PM
When bikes had carbs with manual chokes and air cooling, getting it to run smoothly was a lot more involved. ECU with FI has all but eliminated the need for a warm-up.
Start it and ride it. Don't be stupid until it's warm.
Yikes! Blasting oil from air clean system oil receiver. RipRoarin Mechanical and Technical 22 07-19-2015 06:04 PM
Cracked my oil pan by torquing the drain screw... Jwf88 Mechanical and Technical 28 09-22-2014 09:12 PM
Oil Pan Csantos1591 Mechanical and Technical 1 09-04-2014 01:43 PM
Engine oil Grunk The ZX6R 2 06-06-2009 11:20 AM
