Best way to clean a dirty greasy rectifier - ZX6R Forum
 4Likes
  • 1 Post By NINJA FTW
  • 2 Post By sixer
  • 1 Post By RJ2112
post #1 of 11 Old 02-18-2017, 06:37 PM Thread Starter
sixer's Avatar
Howdy, So my rectifier is all full of road tar, dirt, grime and chain lube...
So im thinking I could just spray it with CRC electronics cleaner and use a tooth brush and then wipe it off...
If not how do I clean it??..
Thanks
sixer is offline
post #2 of 11 Old 02-18-2017, 07:07 PM
That will work.
I would start with a WD-40 myself, spay and let it soak. Grease cut's grease and doesn't evaporate. After 30 minutes, slight scrub and repeat.
Once clean then use the CRC.
post #3 of 11 Old 02-18-2017, 07:32 PM
NINJA FTW's Avatar
I Ride: 2015 ZX-6R 30th Anniversary Edition
pee on it
Scorpi0 likes this.
NINJA FTW is offline
post #4 of 11 Old 02-18-2017, 08:51 PM Thread Starter
sixer's Avatar
Lol..id pee in my pants b4 id pee on my bike.
Thanks Indy.
sixer is offline
post #5 of 11 Old 02-18-2017, 09:29 PM
The best products I've found to cut through that kind of gunk are these:
DuPont Motorcycle Degreaser
Motorex Chain Clean
Both of these work very well. The gunk almost melts off without even needing much scrubbing.
post #6 of 11 Old 02-19-2017, 12:11 AM
Sanctuary's Avatar
https://en.wikipedia.org/wiki/Colon_cleansing
As you eat another's words
Malnourished, you starve.
Sanctuary is offline
post #7 of 11 Old 02-19-2017, 12:21 AM Thread Starter
sixer's Avatar
;Lol, dont be so anal.
Only reason i asked was i know the recti is a sensitive electrical item..
;Strider thanks
Sanctuary and Strider like this.
sixer is offline
post #8 of 11 Old 02-19-2017, 03:04 AM
;Strider thanks
If your r/r lives where it can get soaked by rainwater, grease, and dirt....... it's designed to be weather proof. If you ever crack one open, they are a solid mass of epoxy with parts stuck in it.
Try and avoid the seals at the plugs..... other than that, have at it.
post #9 of 11 Old 02-20-2017, 11:01 AM
I Ride: 2006 ZX6R
Thanks Indy.
WHOA WHOA you mean you havent marked your bike yet to claim it?? newbies...
06 ZX6R - Vortex Rearset, GPR V1, Driven Clipons (soon), Pazzo clutch lever, CNR Brake lever, Secondary Butterflies removed, PCV+Autotune, Micron Serpent Headers/Midpipe, Yoshimura RS-5 slipon, MotionPro Throttle, Aftermarket Adjustable Levers, Ram Air mod, Jumper mod
03 EX250 - Wife's current whip
eulark is offline
post #10 of 11 Old 02-20-2017, 03:53 PM
;Strider thanks
You're welcome!
post #11 of 11 Old 03-02-2017, 05:49 PM Thread Starter
sixer's Avatar
welp the CRC QD electronic cleaner worked well with a little help from the WD 40 and a tooth brush and a few q tips..After cleaning i wiped it off with a wet rag...
Don't inhale the crc stuff.
ID:	57466   Click image for larger version
ID:	57474   Click image for larger version
sixer is offline
Dirt on sproket, cannot clean off ravenshield Mechanical and Technical 7 03-31-2016 12:35 PM
03 ZX6RR Revivial! (to clean a fuel pump?) Jayson Mechanical and Technical 5 08-17-2012 10:59 AM
How to clean and lube the chain... DaddysNinja Mechanical and Technical 44 03-13-2012 06:26 PM
