When Will My Motorcycle Battery Die? - Page 2 - ZX6R Forum
 12Likes
post #16 of 24 Old 02-23-2017, 09:47 AM
Holy 1.21 Jigawatts!!!!
Scorpi0 is online now
post #17 of 24 Old 02-23-2017, 11:21 AM
Elduderino01's Avatar
I Ride: 2001 ZX-6R
speaking of batteries. I have had mine sitting on the maintainer all winter. Recently ive noticed that the maintainer will be blinking yellow. As in charging i do beleive. I have not noticed it steady green which should be a full charge. Not sure why. I do have an led underglow on it. Does draw a very slight volt. But until recently it would go flat green for some time. Any ideas wtf is going on? Havent tested the bettery yet
Elduderino01 is offline
post #18 of 24 Old 02-23-2017, 11:33 AM
Blinking orange on a deltran means that the leads aren’t properly connected. Solid orange means it is charging. Blinking green means it is topping it off / over 80% and solid green means it is charged.
capitalcrew is online now
post #19 of 24 Old 02-23-2017, 11:59 AM
I Ride: 2001 ZX-6R
Nah not for mine. Cant remember the name for the life of me. Im not at home. Its something +3. That i know.
post #20 of 24 Old 02-23-2017, 12:11 PM
Gotcha. Well my assumption is that it is charging it then shutting down to prevent overcharging and then you're seeing it kick back on when the voltage drops some.
post #21 of 24 Old 02-23-2017, 03:30 PM
I Ride: 2001 ZX-6R
if it shut down it would be a steady green.
post #22 of 24 Old 02-23-2017, 05:36 PM
Pull the tender, wait a day check voltage compare it to when you pulled it off.
If you can get it load tested do so. Could be you lost a cell.
My deltran stays green once it's topped off.
Indy is online now
post #23 of 24 Old 02-27-2017, 02:43 PM
I Ride: 2001 ZX-6R
I did pull it off the tender. Waited a day. Now will sycle between steady green, and flashing green. Steady is good, blinking is testing. Id say i am good.
post #24 of 24 Old 02-27-2017, 06:04 PM
Sanctuary's Avatar
I Ride: 2013 ZX6R, 2013 Triumph Street Triple, 2017 Triumph Street Triple RS (on order)
I like chicken tenders.
Here's my battery.
As you eat another's words
Malnourished, you starve.
Sanctuary is online now
Bad Battery? scubaru Mechanical and Technical 15 05-10-2015 08:38 PM
Huge motorcycle crash trev0006 Videos 3 10-21-2012 05:47 PM
Another view - Couple getting it on riding on motorcycle trev0006 Motorcycle Talk 2 09-21-2012 11:29 AM
