Upgraded the Minja - ZX6R Forum
 10Likes
  • 6 Post By commiehunter
  • 2 Post By commiehunter
  • 2 Post By RJ2112
post #1 of 5 Old 03-29-2017, 03:43 PM Thread Starter
commiehunter's Avatar
I Ride: ZX6R 636
Upgraded the Minja
So I still have the Ninja 250 I started on, I call it the Minja (mini ninja). My wife rides it, and I've taken it out when I either had my bike in the shop getting tires or when I lost my key.
So I can rail on this bike pretty hard, but the original suspension is EXTREMELY soft. Like, bouncing up and down over rough pavement, lots of movement when cornering aggressively, and it jumps when upshifting. So I thought we should upgrade the suspension. The other day when she was riding she had it leaned over and it started rocking on her due to the really bad damping on the rear shock, so SHE agreed we should upgrade the suspension.
I got Sonic Springs using the rate calculator either they or RaceTech provides, and I bought RaceTech Gold Valve Emulators, and I picked up an EX250J shock (08+ 250) for the rear.
Last Saturday, I started the project. The rear shock replacement was cake. 20 min, two bolts, on and off.
For the front, I pulled the forks completely off the bike, cleaned them, replaced the fork seals (one was leaking), and reassembled with the new springs, valves, and spacers for correct preload. While I had the fairings off I decided to do some other maintenance. I cleaned the airbox, cleaned the entire engine and transmission housing of road grime and leaked oil gunk, and adjusted the valve clearances.
It rides SOO much better. I can clutchless shift through the first 3 or 4 gears with the throttle pinned and it goes like it's on a guide rail. No more bouncing or floating, it brakes better, corners better. Well worth the price of the parts.
Scorpi0, RJ2112, lance22me and 3 others like this.
commiehunter is offline
post #2 of 5 Old 03-29-2017, 05:18 PM
Nice! So I'm guessing it rides more like and '08+ 250R now?
post #3 of 5 Old 03-29-2017, 05:55 PM
The right springs are the foundation of good suspension....
Hopefully the improved set-up works as well for your spouse?
post #4 of 5 Old 03-30-2017, 08:07 AM Thread Starter
I Ride: ZX6R 636
Yeah, probably, though I haven't ridden one.
When I calculated the spring rate, I used her weight for the variables, so the springs should be set up for her. Even if it's not set for me for racing, I can still tell the bike is so much better off.
She rode last night and said she absolutely loved the new setup.
RJ2112 and Strider like this.
post #5 of 5 Old 03-30-2017, 09:55 AM
My FZ6 had terrible springs, from the factory. The rear was way too soft, and under damped.... the front had progressive springs that were much too soft on both rates. It never rode on the softer part, so the front had already consumed about 70% of the travel, just sitting on the bike.
I dropped in linear rate .95 Kg/mm fork springs and mounted up a fully adjustable Ohlins remote reservoir shock..... the difference was immense. The chassis was completely transformed, because it just did what I asked it to instead of all sorts of random stuff that mostly ended up being what I wanted.
It's really like a whole new bike, TBH.
Strider and commiehunter like this.
upgraded zx6r g1 calipers to rf900 4 pots but the pads over bite the disks Ellie Mechanical and Technical 6 01-05-2016 03:02 PM
New ZX6R Owner Just upgraded! NicheRiding New Users 17 10-24-2015 12:29 AM
Finally Upgraded BlueFlash Mechanical and Technical 7 05-09-2015 01:00 PM
people who upgraded from ninja 250/300 or have both 250/300 and a zx6r markgbe Motorcycle Talk 34 01-18-2014 05:28 PM
upgraded my bike! new to this forum jrowe14 New Users 8 05-12-2013 11:43 AM
