Rpms won't go higher than 8k - ZX6R Forum
 8Likes
post #1 of 75 Old 07-16-2016, 11:06 AM Thread Starter
I Ride: 2006 ninja zx6r
I was in 4th/5th gear on the highway just now and the rpms wouldn't go past 8k. I've never been past that before, but this time i wanted to go a little more and rolled on the throttle and it stayed right there at 8? Any thoughts?
zxnick is offline
post #2 of 75 Old 07-16-2016, 11:30 AM
Does it rev past 8K when it is in neutral?
post #3 of 75 Old 07-16-2016, 12:12 PM Thread Starter
No. In neutral it stops at 8k as well
zxnick is offline
post #4 of 75 Old 07-16-2016, 01:36 PM
PinoyRider88's Avatar
I Ride: '13 ZX-6R
No power commander hooked up or anything? Anyone do an ECU flash?
2013 ZX-6R(20,XXX glorious miles )
PinoyRider88 is offline
post #5 of 75 Old 07-16-2016, 01:46 PM Thread Starter
It has a dynajet power commander III. See the photo. The seller said it may have reset to the low setting when he replaced the battery. How might I adjust this? Do I need the bike running and do the buttons that show low mid and high affect the rpm limit?
zxnick is offline
post #6 of 75 Old 07-16-2016, 02:18 PM
jimundascores's Avatar
Check that fuel and vacuum lines are not kinked. You could check your fuel pump, but I don't have advice on how to do that. Also, make sure that Eddie Murphy didn't put a banana in your tailpipe.
jimundascores
Scorpi0, AlexZX6R and Nekowrites like this.
jimundascores is offline
post #7 of 75 Old 07-16-2016, 07:59 PM
Disconnect the power commander first. It could be the problem.
AlexZX6R and MarkR like this.
post #8 of 75 Old 07-17-2016, 06:22 AM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
^This first
Then check for correct fueling, friend of mines had this issue cause of clogged secondary injectors.Bike had been sitting for a long time.
MrZ is offline
post #9 of 75 Old 07-17-2016, 08:33 AM Thread Starter
I can do that. But I do have a full race yoshi exhaust. Not a slip on. Will the power commander being disconnected cause my bike to run lean??
zxnick is offline
post #10 of 75 Old 07-17-2016, 09:12 AM
No it wont do any damage in such a short amount of time.
post #11 of 75 Old 07-17-2016, 01:43 PM Thread Starter
So I just went out again and tested the rpms in all gears. Stops at 8k in all gears. I will disconnect the pc after the gym and give you an update. But does the pc plug into a laptop computer easily?
zxnick is offline
post #12 of 75 Old 07-17-2016, 03:30 PM
BrandonZX6r's Avatar
I Ride: 06 ZX6r 636
Does it reach 8 k normally and run at 8k normally once you are at that engine speed. Does it struggle to reach 8k and struggle to maintain it. Could be a weak fuel pump.
BrandonZX6r is offline
post #13 of 75 Old 07-17-2016, 05:51 PM Thread Starter
It would reach 8k rpm normally no problem and would stop at 8k and maintain it no problem. It was brought to my attention my kickstand sensor could be loose and the vibration at 8k could be tripping the sensor. So I checked and the sensor was definitely loose, tightened that, but dropped a bolt inside the bike while tearing it apart and looked everywhere for it. So I left the bike stripped down for the night. Gonna get back to it tomorrow. So I have not confirmed if the kickstand sensor is the issue or not.
zxnick is offline
post #14 of 75 Old 07-17-2016, 06:43 PM
Definitely not the kickstand sensor. Its a fuel issue.
post #15 of 75 Old 07-20-2016, 08:44 AM Thread Starter
I took apart the bike and was able to disconnect the power commander clips from the injectors, so it is now disconnected. I had a matter come up and didn't have time to put the tank back on and start the bike. I'll be doing that tonight. The bike should be able to rev higher than 8k rpms in neutral, normally right?
zxnick is offline
Horsepower, Torque, and how to use it properly on a motorcycle. PainfullySlo The ZX6R 34 09-26-2015 08:57 AM
small jerks at higher rpms 10-14k Lakeshow The ZX6R 13 09-12-2013 05:36 PM
Can only shift in higher RPM's elletram Mechanical and Technical 24 09-20-2012 06:07 PM
01 zx6r bogs at high speeds and higher rpms? dlstech Mechanical and Technical 11 08-01-2011 08:29 PM
Can't get bike to higher RPM's Syn Mechanical and Technical 11 04-10-2011 06:43 PM
