2001 J ZX6R "misfire" - Page 2 - ZX6R Forum
post #16 of 20 Old 12-12-2016, 09:08 AM
Mikuni 36mm carb bodies (J3 and later are 37mm)
Main fuel jets.........155 & 157.5
main air jet ...............45
Jet needle.................5E110-54-1
pilot fuel jet...............12.5
pilot air jet.................125
starter jet 35
float height 7mm +/- 2mm is spec but that is a huge range and drastically affects running for the worse....... ( I set them at 8mm or if you do the fuel level measurement, 19.5mm below the float bowl line as installed)
post #17 of 20 Old 12-12-2016, 10:18 AM Thread Starter
Seaniboi69's Avatar
I Ride: ZX6R
Brilliant, thanks again. I'm planning to remove the carbs, clean them (to ensure the garage did clean them as they told me), check all jets and needles (adjust if required) and reassemble.
I haven't got a massive amount of experience working with carbs but plenty of experience with my cars and I've read some threads about stripping them, it's looks straight forward, I've got the Haynes too so I should be golden.
Just need to convince the girlfriend that the hours I spend in the garage tinkering are worth it might take me a few days to get around to this. If I find any issues I'll be back but thanks again for the help
If you've never owned one, you'll never understand!
Seaniboi69 is offline
post #18 of 20 Old 12-12-2016, 01:42 PM
scoot33's Avatar
I Ride: zx6 j2
i would deffo get the magnifier glass as rivers said ,im 20/20 on the eyes and i cant see and normally there has always been some fucker in there and chewed the end of the jets up with a screwdriver,,if its any help my mixture is still set at 3 turns out with k@n and runs great,if you do need any jets if not correct i may have some just pm me ,if you got haynes your be fine got all the stock spec ,let us know how you get on
zx6r j2 mods done ,,
scoot33 is offline
post #19 of 20 Old 12-12-2016, 11:32 PM Thread Starter
Seaniboi69's Avatar
I Ride: ZX6R
Cheers scoot33, appreciate that. Let's see how I get on then. Going to pull them out this week and probably go over them on the weekend. Fortunately it is just a weekend toy so I'm not in a massive rush.
One last question, any recommendations for a carb cleaner, various forums are suggesting different aerosols or solutions but some appear to be USA only. I can see aerosols at halfrauds but wasn't sure if there was something better or if these are usually good enough?
post #20 of 20 Old 12-13-2016, 07:41 AM
Berrymans in the 1 gal can...............soak for hours--agitate the parts about every 20 minutes
but most any of those gallon cans of soak will do, just some take longer than others.......the aerosol stuff is just to rinse off the soak stuff and shoot through the passageways after a proper ultrasonic cleaning
2001 zx6r manual zx6r01 Mechanical and Technical 4 07-24-2013 08:57 AM
Getting 2001 yellow zx6r on Friday Some quick questions. ddavis513 New Users 30 02-13-2011 06:07 AM
2001 zx6r Six Addict Pictures 9 04-07-2009 03:27 PM
Power Commander for 2001 ZX6R? ZX6EDGE Racing 9 03-28-2009 09:57 PM
2001 zx6r need all plastics Sephone420 Classifieds 9 01-01-2009 09:54 PM
