2001 J ZX6R "misfire" - ZX6R Forum
post #1 of 20 Old 12-09-2016, 05:37 AM Thread Starter
Seaniboi69's Avatar
I Ride: ZX6R
Hi,
Another newbie here, a couple of months back I picked up my first ZX6R J 2001, ever since I've been trying to get to the bottom of a "misfire".
Long story short, the bike near enough runs fine, the only issue is a "misfire" when pulling away below 4K rpm, was like this when I bought it but hadn't noticed on the test ride. I immediately changed the plugs assuming they were shot, they looked decent enough but I thought I'd change anyway, clean the filter (k&n) and put back together, worked fine for about 200 miles until the "misfire" reappeared.
Having basic DIY mechanic knowledge I decided I'd try a garage next, they replaced the plugs also, told me the valve clearances were fine, sync'd the carbs and cleaned, cleaned the needles too. The same as above has happened.
Plugs seem to cure it but something must be killing the plugs? I have searched through the forums but can't find a similar situation. Would I be right in saying the coil packs are the next culprit? Any other suggestions to look at while I'm checking them? I would assume this to be a spark issue, the plugs weren't "soaked" in fuel, sooty or white, what else could kill them??
Any help is appreciated.
Seaniboi69 is offline
post #2 of 20 Old 12-09-2016, 07:21 AM
If the plugs are all the same color, and are not wet, I would think the problem is not with the plugs. If the cylinders are all firing equally, and you just have a random point in time where you 'lose' all of them, that's most likely electrical.
Your description does not give enough detail to narrow it down.
post #3 of 20 Old 12-09-2016, 10:36 AM Thread Starter
Seaniboi69's Avatar
I Ride: ZX6R
Thanks for the response. Sorry if I haven't given a lot of detail, didn't want to over explain the issue.
Bike is a 2001, 16,000 miles on the clock, K&N filter and a Micron sports exhaust.
The issue I can only explain like a misfire doesn't feel like it drops on all plugs, when setting off or crawling along under 4k rpm (which is usually only when in 1st or 2nd gear) the revs drop for a split second before picking back up as though it intermittently misses, above 4k rpm it runs fine. As you can imagine, on a bike this doesn't feel great negotiating slow corners etc as it feels like it's starting to pull, then drops then pulls again and so on until you get up above about 4k rpm.
When I changed the plugs about 500 miles ago the issue disappeared completely, revving and setting off smoothly, no intermittent miss at all. About 200 miles later (just a few days) the issue came back. Took to the garage, they cleaned everything as detailed in the first post and put some more plugs in, again it ran fine for a few days before the miss re-appeared.
Obviously the new plugs allow the bike to run fine for a short period then something is causing one to fail - right? I intend to pull them all and check them to see if I can identify the culprit but what could cause the plug failure if that makes sense? Assuming something is causing a plug to fail and it's not something else all together but given that new plugs cure it(until it fails again) it has to be that the plugs are failing.
Just looking for any suggestions while the tank is off.
Thanks again
post #4 of 20 Old 12-09-2016, 12:54 PM
scoot33's Avatar
I Ride: zx6 j2
seaniboi69,might be worth trying coil packs,not sure how much they are new but if pricey maybe some from ebay,does it do it when engine is hot or when cold ,is it always or intermittent
zx6r j2 mods done ,,
scoot33 is offline
post #5 of 20 Old 12-09-2016, 01:06 PM Thread Starter
Seaniboi69's Avatar
I Ride: ZX6R
Thanks, I'm thinking new coil pack(s) but new they're over £50 a piece, it's expensive to replace all 4 if not required. I'm going to check them all to see if they're corroded or any visible damage and test them with a meter. I'm hoping I find that one is to blame.
Since the fault has reoccurred it's constant, anytime the bike is accelerating below 4K rpm it has this misfire and feels like it stutters getting up past 4K rpm, once above that it pulls absolutely fine. I've a feeling if the plugs were changed yet again it would run smooth again for a couple of hundred miles until the fault developed again so it can only be a spark issue??
I'll check the plugs and packs and see if I can spot anything. If anyone has any other possible suggestions to look at I'd appreciate it. The Haynes manual doesn't give a lot of other suggestions that I think it could be
If you've never owned one, you'll never understand!
post #6 of 20 Old 12-09-2016, 07:07 PM
scoot33's Avatar
I Ride: zx6 j2
if it clears after 4 k it could be something else ,if it was plug or coil pack realistically it would be all the time misfiring,have you checked the base settings on your carbs the mixture screws ect,carbs and air leaks can cause all sorts of shitty small problems ,how is your mechanical knowledge ,i would have a look to see what mixture screws are set at,the j is set at 3 turns out ,and check to see any dodgy pipe work has fell off or split
scoot33 is offline
post #7 of 20 Old 12-09-2016, 08:28 PM
Dirtroad's Avatar
I Ride: 1998 Kawasaki ninja zx6r
Since you are convinced that replacing the plugs temporarily solves the problem, try this:
Replace the plug in number 1 cylinder. Go for a ride to see if it fixed it.
If it fixed it, you have now narrowed it down to cylinder number 1.
If it still has the miss, Replace the plug in number 2 cylinder. Go for a ride to see if it fixed it.
If it fixed it, you have now narrowed it down to cylinder number 2.
If it still has the miss, Replace the plug in number 3 cylinder. Go for a ride to see if it fixed it.
If it fixed it, you have now narrowed it down to cylinder number 3.
If it still has the miss, Replace the plug in number 4 cylinder. Go for a ride to see if it fixed it.
If it fixed it, you have now narrowed it down to cylinder number 4.
If none of this eliminated the miss, you know that spark plugs aren't the problem or solution.
Dirtroad is offline
post #8 of 20 Old 12-09-2016, 11:04 PM Thread Starter
Seaniboi69's Avatar
I Ride: ZX6R
Ill check the mixture settings today, that's one thing I haven't touched to be honest, it doesn't smell like it's running lean/rich nor did the plugs show any signs. The garage have done a vacuum leak check (apparently) with no issues as they said the same but while I've got it open I'll take all the pipes off and give a visual inspection. It's not ideal but I don't have any equipment to test this.
Dirtroad, if none of the above works this might be my solution, I'll get a multimeter on them first then start to replace one by one just to rule it out.
If it's not the plugs/coils and I'm looking at this all wrong it's sounding like it could be a fuel/air mixture issue then. I'll update this evening once I've tried everything.
post #9 of 20 Old 12-11-2016, 11:58 AM Thread Starter
Seaniboi69's Avatar
I Ride: ZX6R
Right then. Spent yesterday and today checking various things.
Sparks out and they seem to fire fine, nice blue spark, not gunked up etc. Tested the resistance and that's within specification on all plugs, I guess this rules out plugs. Tested the resistance on all the coil packs, same again, within spec, no damage I can see. Tested the resistance in the secondary circuits, again this is fine.
Scoot33 it looks like you were right, electrics all check out so it must be an air/fuel issue.
I screwed in all the mixture screws and wound back out 3 turns (this was very close to how it was before I adjusted, maybe they were 1/8 of a turn different). Took the bike for a spin, still has the random stutter/misfire under 4K rpm. (Reluctant to say misfire now as it seems that it's firing fine).
Should I be altering the mixture screws now? With it having a K&N is it seeing too much air so needs adjusting to more fuel, would I be best to start screwing them out or start screwing them in? Also, any tips to doing this, if I need to adjust a 1/4 turn, try it then maybe adjust another 1/4 etc etc I'm just thinking about not having to remove the tank etc each time as I'll not know if it's made a difference until I test ride it.
Thanks guys!!
post #10 of 20 Old 12-11-2016, 01:26 PM
I have to think the electrical side of things aren't a concern.
You may have an air leak, which is causing the fueling to be off. Vacuum leaks can cause the sort of issues you seem to be having. A boot may not be seated properly, one of the vacuum control lines may be cracked, missing, or improperly routed......
Probably the best tool to diagnose at this point would be a vacuum gauge, to see if the manifold pressures are even.
If the bike has had the valves adjusted, the carbs rebuilt, the air filter cleaned, and the carbs synchronized -- it should run very well. If not, then something is still amiss, almost certainly inside the carbs.
Dirtroad likes this.
post #11 of 20 Old 12-11-2016, 03:23 PM
pilot fuel jet size?
pilot air jet size?
needle ?
needle jet?
main air jet?
main fuel jet?
are all these stock or have they been changed? If changed, changed to what?
post #12 of 20 Old 12-11-2016, 11:07 PM Thread Starter
Seaniboi69's Avatar
I Ride: ZX6R
pilot air jet size?
needle ?
needle jet?
main air jet?
main fuel jet?
I haven't changed any of these, looks like I need to dig a little deeper as the previous owner might have.
This might be a daft question but are these sizes marked on the jets and needles in anyway or do I need to get a micrometer on them? Sure the sizes will be in the Haynes for me to compare against
post #13 of 20 Old 12-12-2016, 08:01 AM
They are marked on the jets, depending on how clean and how good your eye sight is..... you may need a magnifying glass
post #14 of 20 Old 12-12-2016, 08:37 AM Thread Starter
Seaniboi69's Avatar
I Ride: ZX6R
Spot on. Probably won't get chance to look for a week but I'll let you know the outcome
post #15 of 20 Old 12-12-2016, 09:01 AM
Here are a few examples.....the first pic is a ZX6R, (f) model though..........
ID:	51402   Click image for larger version
ID:	51410   Click image for larger version
ID:	51418   Click image for larger version
ID:	51426   Click image for larger version
2001 zx6r manual zx6r01 Mechanical and Technical 4 07-24-2013 08:57 AM
Getting 2001 yellow zx6r on Friday Some quick questions. ddavis513 New Users 30 02-13-2011 06:07 AM
2001 zx6r Six Addict Pictures 9 04-07-2009 03:27 PM
Power Commander for 2001 ZX6R? ZX6EDGE Racing 9 03-28-2009 09:57 PM
2001 zx6r need all plastics Sephone420 Classifieds 9 01-01-2009 09:54 PM
