03 zx6 636 oil leak help left side - ZX6R Forum
 5Likes
  • 2 Post By riverszzr
  • 2 Post By ProZach
  • 1 Post By riverszzr
post #1 of 13 Old 01-18-2017, 06:10 AM Thread Starter
Did oil change few weeks ago rode bike after oil change then few days ago it got cold and I decided to tgo for ride and after getting off freeway notice front of my shoe was covered in oil came home took gas tank off looked and seen a lil oil on air filter but nothing bad but oil was all on left side bottom. But oil ND coolant level is good bike runs good.. Where do I look and look for I'm still new so please explain and be detailed what to do thank you very much
dmoney817 is offline
post #2 of 13 Old 01-18-2017, 06:47 AM
Did you overfill it and the oil is coming out of the air box drain?
"seen a little oil on air filter"............why would that be the first place to look for your oil leak??
You don't give enough details for much more help than that...
Scorpi0 and arsftarmy like this.
post #3 of 13 Old 01-18-2017, 07:23 AM
Clean all oil
Put fuel tank back on
Start the bike and check for the leak.
post #4 of 13 Old 01-18-2017, 01:39 PM
Hello and welcome!
It sounds to me like there was possibly too much oil put in. Check the site glass and let us know what the level is. Also, as Scorpi0 said, clean all the oil off and run the bike to see where the oil is coming from if it is still "leaking".
post #5 of 13 Old 01-18-2017, 02:06 PM
ProZach's Avatar
I Ride: 2003 636
Oil filter could have come loose while riding. Ask me how I know...
Scorpi0 and Strider like this.
Relax...
ProZach is offline
post #6 of 13 Old 01-19-2017, 02:54 PM Thread Starter
OK I check the air box cause been reading other post and that's what other people are doing so that's why I check there first but yes I'm certain there was too much oil put in so I just got done draining all the oil out of the bike and I drain the coolant to see if there was any oil and that and it was all good and green coolant
post #7 of 13 Old 01-19-2017, 03:26 PM Thread Starter
Originally Posted by Strider View Post
Hello and welcome!
Yes I did put to much oil I'm pretty certain I did I tried to put picturess but here is a link that u can seehttps://goo.gl/photos/dtmd32nvMdaNUveCA
post #8 of 13 Old 01-19-2017, 03:36 PM Thread Starter
So if oil over filled what harm did it do to bike . So I'm bout to put it all back together and put new oil back in and see if it still leaks
post #9 of 13 Old 01-19-2017, 03:38 PM Thread Starter
Here a link to the pictures I took https://goo.gl/photos/dtmd32nvMdaNUveCA
post #10 of 13 Old 01-19-2017, 03:41 PM Thread Starter
Also where you drain the oil at isn't there's supposed to be two bolts underneath there I noticed when I was draining the oil it looks like there's a bolt missing from underneath there
post #11 of 13 Old 01-19-2017, 05:46 PM
Just one bolt. The other bolt hole is there but its not drilled all the way through. Not sure what thats for....but Im guessing for the factory to handle the engine when moving it around or something.
Also, fill the oil with the bike standing straight up....not leaning on the kickstand.
post #12 of 13 Old 01-19-2017, 05:52 PM
other one is for the exhaust mount..not used on all models
but yes.make sure bike is level side to side and front to back!
Scorpi0 likes this.
post #13 of 13 Old 01-21-2017, 07:34 AM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
Top left is all shinny, is it soaked in oil?The plug and everything?
When you took your airbox off, there are two two hoses that plug underneath it. Were they...where they should be?...
MrZ is offline
WTB 03/04 636 left side rear set Lukee Want to Buy 0 07-14-2015 04:59 PM
FS: 05-06 636 blue tank has small dent on left side PineApple21 Classifieds 2 05-11-2013 05:02 PM
Oil leak!! MG815 Mechanical and Technical 20 02-02-2012 06:50 PM
03 ninja 636 oil leak from valve cover. Dimaggio1103 Mechanical and Technical 1 11-29-2011 09:22 AM
