New to me 13 zx6r - Page 2 - ZX6R Forum
 7Likes
post #16 of 25 Old 01-23-2017, 06:58 PM
I Ride: 2014 Kawasaki ZX-6R
Originally Posted by Fxclm5 View Post
common nor cal ppl lets go to ptt double header opener @ infineon 2/25-26
That sounds fun.
Martillo y Mantequilla #99
post #17 of 25 Old 01-24-2017, 12:25 AM
Rab
Rab's Avatar
I Ride: ZX6-R 636 A1P
welcome.
loving the gold wheels bud.
Rab is offline
post #18 of 25 Old 01-24-2017, 05:26 AM
Deckx's Avatar
has anyone done a rifleman 1/5th throttle insert mod?
I did mine with a cut out piece of PCV pipe... bit of trial and error with plumbing and electrical PVC couplings until you find best fit.... throttle cables are maxed out bit I'm pretty happy with it the travel.... have a proper kit on another bike and don't think its any better.
Deckx is offline
post #19 of 25 Old 01-24-2017, 03:46 PM Thread Starter
I Ride: 13 zx6r, Tuono V4, Grom
Originally Posted by madmax31 View Post
Just saw that your selling your fairings on BARF. Hit me up if you do go to Thunderhill! I haven't been to Sonoma yet because I hear mixed reviews about it. Do want to try Buttonwillow at least once this season.
im willing to risk going back to sears point for the double header
Fxclm5 is offline
post #20 of 25 Old 01-24-2017, 03:49 PM Thread Starter
Yup my amigo has done his own diy lawn sprinkler plastic mod on multiple bikes.
After buying riflemans 1/5th insert (its a weird plastic formula) hard plastic/soft gum at same time for the steel to ride against, for like $5-10 bucks shipped
And seeing others do the mod with generic garage parts, im never dropping 100+ on a motion pro kit.
For those trying to do this themselves, you may need to modify your stock cable limiter since the cam could and more then likely take up all the excessive slack, on the zx10r i had to cut off a plastic tab so the adjuster could thread all the way down or up etc.
Fxclm5 is offline
post #21 of 25 Old 01-25-2017, 07:03 PM
PinoyRider88's Avatar
I Ride: '13 ZX-6R
Welcome, where did you find a highmount two bros exhaust? Also how bad was the "salvage"
2013 ZX-6R(20,XXX glorious miles )
PinoyRider88 is offline
post #22 of 25 Old 01-25-2017, 11:15 PM
Sanctuary's Avatar
R6 throttle swap. Cheap and easy.
As you eat another's words
Malnourished, you starve.
Sanctuary is offline
post #23 of 25 Old 01-26-2017, 03:36 PM Thread Starter
not 2 bad
the highmount is a full exhaust that I will be selling later
the r6 throttle swap is still tame compared to the rifleman 1/5th, just his lead in angle and material chosen is the perfect combo wombo
Fxclm5 is offline
post #24 of 25 Old 01-26-2017, 07:44 PM
I Ride: '13 ZX-6R
not 2 bad
That really isn't that bad. Congrats!
post #25 of 25 Old 01-26-2017, 09:36 PM Thread Starter
Holy crap it took me 2+ hours to remove the 2x side fairings, the main nose and headlight
Those screws right beside the headlight are such a bitch... wtf!!!!!
Also my top/bottom triples are definitely warped, the forks do not sit out of the top equal distance all the way around, really weird. It will be like 10mm for about 50% of the outer diamter and the rest of the 50% will taper down a few mm lower.
Fxclm5 is offline
Stompgrip on 2000 zx6r uetza Mechanical and Technical 11 02-07-2013 03:59 AM
2007-2011 zx6r motors all mount the same in frames pizzot The ZX6R 15 06-05-2011 07:44 AM
