Zx6 raf 2011 rattle - ZX6R Forum
  • 1 Post By NinjaBros
  • 1 Post By Digg4Dom
post #1 of 5 Old 03-30-2017, 10:57 AM Thread Starter
Digg4Dom's Avatar
I Ride: Zx6r 2011
Zx6 raf 2011 rattle
Well first of all Hi to all, new to the forum but joined as it helped me alot the last week before buying my bike.
So bought it with a rattle.
Bike is 2011 zx6r af, 21k miles. Uk bike.
I have pulled the cam chain tensioner done one click refitted and its still the same.
Would you say from the vid clip "that hopefully" uploads its the valve that need adjusting??
All help apreciated
https://youtu.be/aMNdugB8A7E
Digg4Dom is offline
post #2 of 5 Old 03-30-2017, 11:19 PM
Hello and welcome!
First of all, don't do the "1 click adjustment" to you automatic cam chain tensioner. I would recommend removing it, cleaning and lubing it, then resetting it according to the procedure in the service manual, which you can download from the service manual section of the forum.
Second, that rattle doesn't sound normal. The above procedure may resolve the issue if the noise is indeed the cam chain.
Third, have you checked the oil level or done an oil change? That would be one of the first things I would do on a used bike.
post #3 of 5 Old 03-31-2017, 04:11 AM
NinjaBros's Avatar
I Ride: 09 ZX6R
Make sure your exhaust is tight. Headers can get loose and leak a little.
NinjaBros is online now
post #4 of 5 Old 03-31-2017, 07:07 AM Thread Starter
Digg4Dom's Avatar
I Ride: Zx6r 2011
Hi thanks for getting back.
I removed the tensioner and that was clean and working correctly but did refit 1 clock further out however.
The previous owner was changing the oil ever 1000miles.
Last change 51miles ago, level is correct and clean.
I shall check the headers, however its not a exhaust noise. But will check.
Exhaust fully checked on ok tight.
Its booked in for the valves to be checked and new shims if need be in 2 weeks. But was hoping it was something simply.
Thanks
Digg4Dom is offline
post #5 of 5 Old 03-31-2017, 04:06 PM
It does sound kind of like an exhaust leak (at the headers?) to me, now that it was mentioned above.
New guy. 2011 zx6 Gordon2835 New Users 6 01-24-2015 08:31 AM
2011 zx6 aligning forks mudflap Mechanical and Technical 6 11-09-2014 04:49 AM
FS: 2011 ZX6 Blue (Michigan) $8,000 11NinjaZX6 Classifieds 12 04-02-2014 10:13 AM
6OTM Winners 2011 PowerGroove Ninja 6 of the Month 0 06-27-2013 10:05 AM
2011 zx6 frame slide options juelzdip7 The ZX6R 15 04-29-2012 07:45 PM
