new member starts with questions - ZX6R Forum
 4Likes
  • 2 Post By commiehunter
  • 2 Post By Indy
post #1 of 11 Old 04-14-2017, 10:24 AM Thread Starter
hi there.
a new owner from brooklyn, ny is checking in. this isn't my first bike but fist sport bike. i always wanted to have one and finally decided to pull the plug last month. bought a used one off ebay, 20,000 miles '06 XZ6R, green.
Albeit low mileage the bike appears to be neglected, rusty drive chain, missing screws all around the fairing. Some screws overtighten with stripped well nuts threads. It was such a PITA getting them out. Right side tank screw missing... seriously?!?!?!?!?!. Missing dowel from camshaft cover.
The bike seems be lowered too, so the second order of business would be bring it to the stock heights.
What's the first order?, well that's where my question begins.
Seeing how neglected the bike was I decided to check valve clearance. Downloaded service manual from the web and was immediately puzzled.
The page 2-26 says #1 piston TDC is when IN mark of intake shaft faces opposite direction of EX mark of exhaust shaft. My problem is that at this position of the shafts noses are still on the valves, i cannot insert any size of feeler through under #1 lobes. But I can on #4 cylinder. So, I wonder what am I doing wrong? Is this possible that in '06 service manual they messed up #1 and#4 TDC positions?
Incidentally (no really), I downloaded 07 service manual. There, on page 2-21 the camshaft positions are drawn opposite to '06 manual, and actually make sense.
Please help and explain this conundrum.
goblin is offline
post #2 of 11 Old 04-14-2017, 11:10 AM
commiehunter's Avatar
I Ride: ZX6R 636
It is possible they're incorrectly written. Like, maybe 05 they were like that, manual didn't get updated, but there's an addendum out there for the change.
That kind of thing can happen. I'd verify it's not literally assembled backwards, but past that, doing what obviously looks correct probably is.
Indy and Addhoc like this.
commiehunter is offline
post #3 of 11 Old 04-14-2017, 11:46 AM
Hello and welcome!
post #4 of 11 Old 04-14-2017, 02:21 PM
My 06 I had the same problem. If your on 1/4 look at the valve clearance checks.
You will find OR at least I did, 1/4 was for both sides.
I could get half, at 1/4 rotate one revolution to 1/4 and did the other half.
Indy is online now
post #5 of 11 Old 04-14-2017, 02:51 PM
NitrusReigns's Avatar
Maybe goblin will, but I'm not following what you're suggesting here. Care to elaborate? I'll be doing my valve clearance check in the next month or so and would love to know more about a potential problem before getting to it
NitrusReigns is offline
post #6 of 11 Old 04-14-2017, 05:03 PM
OK,,, if you read the page and don't assume like I did..
The basically say, when doing TDC 1 check these valves.
When doing TDC 4 do these valves..
I ASSUMED I would put the crank at 1/4 measure those valves then rotate it to 2/3 and measure the rest. Never measured one valve using 2/3.
What I'm trying to say. IF you move crank to 1/4, look at the valves. You will either be doing the TDC 1 or the TDC 4. Both will have the crank at 1/4 IF at one, then rotate the crank until your at the other.
I'm attaching just those pages.
RJ2112 and Addhoc like this.
Indy is online now
post #7 of 11 Old 04-15-2017, 12:49 PM Thread Starter
Crank shows correct markings; there are two 1/4 and 2/3. This is because full cycle of the engine equals 2 revolutions of the crank.
In other words, when 1/4 marking in correct position either cylinder #1 or #4 at TDC. Rotating the crank 360 degree will reverse TDC of #1 and #4 cylinders. The question is which ones.
So, on the page 2-26 it clarifies that when markings on the cam shafts are as follows
<-IN EX->
This means #1 TDC.
When markings are
IN-> <-EX
This means #4 TDC.
And that's where I became confused, 'cuz <-IN EX-> brings #4 to TDC, not #1 as the Manual states. And vice versa IN-> <-EX in spite of the Manual is actually #1 TDC.
I've googeled 2006 service manual pdf, found a couple of more revisions yet all of them show incorrect markings. Assuming they are incorrect and I am not going crazy.
goblin is offline
post #8 of 11 Old 04-15-2017, 03:49 PM Thread Starter
im following what you said. i've checked everything else, and it's either the manual is incorrect or im loosing my mind. i reject the latter.
goblin is offline
post #9 of 11 Old 04-15-2017, 05:57 PM
LOL..
For valve checks, to heck with the cam markings. Just look and see which cylinder set allows you to do both intake and exhaust.
Using there chart you know what other ones should be good to check.
Rotate the crank 360, it will be the other example in manual.
The cam marks for me only came into play when they had to come out.
Indy is online now
post #10 of 11 Old 04-15-2017, 06:35 PM Thread Starter
LOL..
For the valve check, yes, I agree no need to check the markings.
Markings became important the moment I started putting chains back on the cams after replacing the shims. And this is where the roots for the confusion where.
On page 5-18 of camshaft installation it describes #4 TDC by markings <-IN EX->.
On page 2-26 the same marks <-IN EX-> say it's #1 TDC.
Nuts.
goblin is offline
post #11 of 11 Old 04-23-2017, 08:29 AM Thread Starter
For those who are interested. I finished valve clearance adjustment, had to replace only one shim. Put the bike back together, started up no issues.
So, I guess it's official - there is a typo on page 2-26 of 2005-06 service manual, the pictures reversed #1 and #4 TDC
goblin is offline
valve adjustment
New Ohio member with lots of questions Layne New Users 36 04-25-2014 08:18 AM
ZX6R.com Member Demographics Kozaru The ZX6R 84 01-15-2014 11:41 AM
New member couple questions! BSloss13 Mechanical and Technical 4 03-06-2013 04:20 AM
New member with some questions CAMMY5106 United Kingdom 16 08-06-2009 10:20 PM
