Looking for thoughts on newer ZX6RR - ZX6R Forum
  • 2 Post By NitrusReigns
  • 1 Post By ZX6R OZ
post #1 of 13 Old 04-25-2017, 01:38 PM Thread Starter
bjturner27's Avatar
Been reading posts and riding my 2003 ZX6RR on the track for about 5 years.
I'm thinking of selling and getting a new one, maybe 2010 and up. Anyone have recommendations about how much newer I should go or the differences, advantages?
bjturner27 is offline
post #2 of 13 Old 04-25-2017, 02:47 PM
NitrusReigns's Avatar
Why do you feel like you want a newer one?
ZedExMuse and insan3guy like this.
NitrusReigns is offline
post #3 of 13 Old 04-25-2017, 10:40 PM
houltmac's Avatar
I Ride: '16 ZX-6R 30th Anniversary
'09 and '13 were where the main changes happened. If I imagine you'll get mixed opinions about which is better. Each have advantages. For example, '09 is a 599 so runs in more 600 races and has a damper but '13 is a 636 so more power but not always race eligible, no damper, slipper clutch, some base electronics.
I've had both. Both are epic.
Matt
2016 ZX-6R 30th Anniversary
Akrapovic slip-on, ASV Shorty Levers, Radiator Grille, Bobbins, Micro LED Indicators, R&G Tail Tidy, Silver Indicator Bulbs
Matt
houltmac is offline
post #4 of 13 Old 04-26-2017, 08:51 AM
Johnmark101's Avatar
I Ride: 2013 Ninja 1000, 2015 ZX6R
If you can find a good deal on a 2013 or newer you will get decent stock suspension, a nice slip and grip clutch, and traction control as well as excellent stock brakes. Also the 2013 and up gives you more mid range since they achieved the 636 displacement by increasing the stroke rather than the bore. Does not sound like much but it makes a real difference for street riding......puts a little more grunt right where you need it when you are not going to be in the upper rpm range so often.
Nothing better than riding with a few friends in the grip of a shared obsession.
Johnmark101 is offline
post #5 of 13 Old 04-26-2017, 04:52 PM
For the track, I think 2009 - 2012 is the better option. FYI, this model also has a slipper clutch.
post #6 of 13 Old 04-26-2017, 06:03 PM
VohrteFahrt's Avatar
Never ridden anything prior as far as the zx6 goes but i am loving the power and feel of my 15 zx6r
VohrteFahrt is offline
post #7 of 13 Old 04-26-2017, 07:36 PM Thread Starter
bjturner27's Avatar
I thought the handling of a newer one would be better.
post #8 of 13 Old 04-26-2017, 10:13 PM
houltmac's Avatar
I wasn't clear in my post. Both have the slipper clutch but only one works. I had two '09's and in both cases the slip was poor. On my '16 it is improved beyond words.
Matt
Matt
houltmac is offline
post #9 of 13 Old 04-26-2017, 11:40 PM
Been racing a 09+ since 2010 and NEVER had an issue with the slipper clutch... and I can't even blip throttle properly so I hardly ever try. Rode the 13+ 636 a few times on track and to me the clutch was the same. Engine has A LOT less top end but definitely more mid range. But then again, neither bike was stock so hard to say. Both have full exhaust + filter + fuel management and etc. The 13+ even had the "09-12 v.stacks mod", apparently it helps with the lack of top end owner told me.
I'd still stick with the 09-12 for track duties though (and I have). Also, yes... the 09-12 comes with damper but it's pretty lame in stock form and you need to spend a little to get it work properly so it's not all roses. Stock forks are quite good till you're at the pointy end of the competition and then you'll need cartridges but it's still a lot better than just about every stock set of forks I'd tried before. Can't compare with the 13+ as it had Ohlins cartridges when I rode it.
ZX6R OZ is offline
post #10 of 13 Old 04-27-2017, 11:49 AM
They softened up the suspension quite a bit on the 2013+ models for "better" street riding. The 2009 - 2012 are already pretty well set up for track riding.
post #11 of 13 Old 04-28-2017, 06:20 AM
That is due to how they accomplished the 636cc in the 09-12 vs 13+/. in 09-12 they actually had a larger bore size. for the 13+ they increased the stroke instead which is how they get better mid range.
post #12 of 13 Old 05-02-2017, 04:20 PM
Have you gotten your suspension tuned to your weight? That would likely make MUCH more difference than a new bike...
I think you may be confused...I don't think the 09-12 is a 636
Please feel free to provide evidence to the contrary, but I was under the impression that 13 was a reintroduction of 636 since 07-12 had all been 599. Yes or no?
post #13 of 13 Old 05-02-2017, 04:30 PM
You are correct. I got confuzzled. The previous 636 so 04-06 would have been a bigger bore, whereas the new models 13+ have a larger stroke. You are correct on the 599. Also I think the ZX6RR's are still 599 cc.
confused about my 2003 bike being zx6r or zx6rr MeleeGarage The ZX6R 10 05-31-2014 11:42 PM
05-06 ZX6RR cam in ZX6R Utard Mechanical and Technical 8 01-12-2014 07:19 PM
06 zx6rr clutch place replacement issues maddmike06 Mechanical and Technical 8 08-02-2013 12:51 PM
FS: Running '04 ZX6RR engine Steel Classifieds 1 06-24-2013 03:42 PM
04 zx6rr front calipers and 05 zx6rr front brake lines Steel Classifieds 0 02-13-2012 10:59 AM
