PLEASE HELP - 2008 ZX6R Cluster Problem - ZX6R Forum
post #1 of 6 Old 05-13-2017, 12:56 PM Thread Starter
I Ride: ZX6R 2011
Hi All
R1CWK is offline
post #2 of 6 Old 05-13-2017, 01:28 PM
Buy a new cluster?
post #3 of 6 Old 05-13-2017, 02:01 PM Thread Starter
I Ride: ZX6R 2011
R1CWK is offline
post #4 of 6 Old 05-13-2017, 05:56 PM
Buy a new bike?
post #5 of 6 Old 05-13-2017, 06:00 PM
Check to make sure all the contacts and pins are clean and dry. Hit it with some contact cleaner spray.
Trace the wiring all the way back to the ECU. IF the wiring checks out fine, the only other faulty thing I can think of is the ECU itself.
Try to find a buddy with the same bike and swap the ECU's to test it out.
post #6 of 6 Old 05-13-2017, 07:18 PM
Scorpio is on the right track..... I'd suggest that you unplug every electrical connection you can reach on the wiring harness one at a time, and apply dielectric grease to each one.
If you swapped clusters and still have the fault, it's either the ECU, or the electrical connections between the two. Including a possibility of worn or chaffed wiring.
« zx6r newbie | Howdy »
parts swap for the 6r through out the years scoobs Mechanical and Technical 14 12-15-2016 08:22 AM
2002 ZX6R Complete Rebuild - Relay problem videophotog New Users 4 09-12-2014 09:12 PM
