ZerO and the DragonThis is a discussion on ZerO and the Dragon within the Pictures forums, part of the Multimedia category; Originally Posted by zeroplace
Its candy emerald green.
Sick color, never seen it around....  |
08-12-2011, 05:47 AM
#61 | | Track Star
Joined: May 2011 From: New Jersey Posts: 298 I Ride: 2006 zx6r | Quote:
Originally Posted by zeroplace Its candy emerald green. | Sick color, never seen it around.
08-12-2011, 06:46 AM
#62 | | Superbike Champion
Joined: Mar 2011 From: Saint Augustine, Florida Posts: 1,099 I Ride: 2008 ZX6R P8F |
Zero, that's a sick bike.
I have never liked the older body styles quite as much as I like yours. Not sure why, but something about it just works for me. The red and black you had before is definitely something I am going to consider for my personal bike now.
Props for a -KICKASS- D.I.Y. bike.
08-12-2011, 07:25 AM
#63 | | Track Star
Joined: May 2011 From: U.S Posts: 454 I Ride: ZZR600/ZX6R Hybrid | Quote:
Originally Posted by los78 Sick color, never seen it around. | Maybe because it is spray paint. I did the whole bike in rattle can paint. Quote:
Props for a -KICKASS- D.I.Y. bike. | Thanks mate! We have been through hell together that is for sure. I was going to nominate her for 6OTM but I'm not going to nominate myself. Seems a bit unjust to do so.
08-28-2011, 08:10 AM
#64 | | Track Star
Finally got around to setting the preload on the steering stem. Now she is a whole different ride, and in a great way! I should have done it a while ago but have been real busy at the shop and just needed to rest after the days. My next list item is putting new rubber under her and going to re jet.
08-28-2011, 09:53 AM
#65 | | Pro Racer
Joined: Apr 2011 From: Chesapeake, VA Posts: 849 I Ride: '06 ZZR600 fighter |
Are you going with those Pilot Road 3's you were talking to me about? I'm curious to know if they have decent grip on the outer edges.
08-28-2011, 10:29 AM
#66 | | Track Star
Yeah... pilot Road 3. I know a couple of guys with them and read all kind of reviews. I will let you know. I have a set at the shop right now, but can't afford to reimburse the shop if I use them.
08-28-2011, 10:38 AM
#67 | | MotoGP Champion
Joined: Jul 2011 From: Ellicott City, MD Posts: 2,818 I Ride: Green 2006 ZX6-RR (was Limp) on Viagra/ 05 ZX6RR (parts bike) |
Zero u r d fuckin man
08-28-2011, 10:43 AM
#68 | | Post Master General
Joined: Aug 2009 From: Looneyben escapee Posts: 8,368 I Ride: 2007 ZZR/ZX6R |
Scott, Good to see you about the forum man, Don't be such a stranger.
Say you got the preload set? What have you got it set at?
& how you liking the job?
08-28-2011, 12:38 PM
#69 | | Track Star
Originally Posted by ZX6RRECTION Zero u r d fuckin man | Lol! Thank you. I'm just a regular guy that works on bikes. Quote:
Originally Posted by oldninjadude Scott, Good to see you about the forum man, Don't be such a stranger.
& how you liking the job? | Thanks Michael! You have to set the stem preload by feel. The way to do it is...
Put the bike on a rear stand.
Then jack the front up, even with the rear, where the steering is free.
Place the front end in the middle, as if you were riding straight.
Slightly tap one side of the bar to the other side.
If the trees hit the stop and bounce slightly, the stem is not tight enough.
You want to be able to place the bars, at any position, and they stay there without moving on their own. You also want the bars to barely hit the stops when slightly pushed from center. You can tighten the preload without taking the upper tree off. Just loosen the tip nut and then use a flat blade and mallet to tighten or loosen the 2 locking fasteners.
08-28-2011, 12:42 PM
#70 | | Track Star
Oh yea... The job is great! Mon-Fri from 10-5. No benefits to take but I do get parts at cost and have access to the shop at any time to work on the Dragon, if needed.
08-29-2011, 09:00 AM
#71 | | Pro Racer
Joined: Apr 2011 From: Chesapeake, VA Posts: 849 I Ride: '06 ZZR600 fighter | Quote:
Originally Posted by zeroplace Lol! Thank you. I'm just a regular guy that works on bikes.
You want to be able to place the bars, at any position, and they stay there without moving on their own. You also want the bars to barely hit the stops when slightly pushed from center. You can tighten the preload without taking the upper tree off. Just loosen the tip nut and then use a flat blade and mallet to tighten or loosen the 2 locking fasteners. | Just make sure you don't tighten that stem too much (not speaking to you Scott, just in general). The 05/06 ZX6R service manual (since that's the front end I'm running) says 11 ft-lbs of torque on those two locking rings. I wasn't about to figure out how to get a torque wrench on those, so I did the same and went by feel. Front moves pretty freely, but not loose per se. Quote:
Originally Posted by zeroplace Oh yea... The job is great! Mon-Fri from 10-5. No benefits to take but I do get parts at cost and have access to the shop at any time to work on the Dragon, if needed. | No benefits, but at least they give you the discounts and let you use the shop for personal reasons. That's really freakin' cool, man. Now you can just go nuts with mods if you like. Maybe even make some extra cash on the side fabricating stuff. Maybe?? Just keep it on the D-L. |
08-29-2011, 10:20 AM
#72 | | Track Star
Originally Posted by LarryJ Just make sure you don't tighten that stem too much (not speaking to you Scott, just in general). The 05/06 ZX6R service manual (since that's the front end I'm running) says 11 ft-lbs of torque on those two locking rings. I wasn't about to figure out how to get a torque wrench on those, so I did the same and went by feel. Front moves pretty freely, but not loose per se.
No benefits, but at least they give you the discounts and let you use the shop for personal reasons. That's really freakin' cool, man. Now you can just go nuts with mods if you like. Maybe even make some extra cash on the side fabricating stuff. Maybe?? Just keep it on the D-L.  | It's all good! I like to keep the front end a bit tighter than what the manuals say. To me, its easier to upright after a turn because the bike feels as if its righting herself.
08-31-2011, 03:45 PM
#73 | | Track Star
I love my job! I was just paid to work on and wash the Dragon (My Bike).
08-31-2011, 03:57 PM
#74 | | Post Master General
^ hahaha That's great, Now if only I could do that.
08-31-2011, 04:00 PM
#75 | | Track Star
Originally Posted by oldninjadude ^ hahaha That's great, Now if only I could do that. | It is pretty cool, but there are days where I want to just leave.
| | | Search tags for this page | | 06 636 apart, custom paint 07 zx6r, custom painted zx6r, green zx6 led park lights, puig fender eliminator on 07 zx6r, sv650n custom black body silver frame, zx6r, zzr600 custom paint
