Mr KAWASAKI'S Build Thread - Page 3 - ZX6R Forum
 5Likes
post #31 of 57 Old 02-13-2017, 10:36 PM Thread Starter
MR KAWASAKI's Avatar
I'm going to skip taking bodywork/seat off and start with removing the tank.
Remove the tank bolt
Unplug the fuel pump connector
MR KAWASAKI is offline
post #32 of 57 Old 02-13-2017, 10:37 PM Thread Starter
Now its time to remove the fuel line spread apart the clip and slide it down
Careful you will lose a lil bit of fuel have a shop towel ready
post #33 of 57 Old 02-13-2017, 10:37 PM Thread Starter
After removing the tank you will have the airbox exposed now remove these bolts
Then unplug this connector and the bolt on the frame
Now you can change the air filter. Mine will be staying stock for a while
post #34 of 57 Old 02-13-2017, 10:53 PM Thread Starter
To get the bottom portion off you need to loosen these bolts on each side.
Remove these two hoses
Should look like this
post #35 of 57 Old 02-13-2017, 11:02 PM Thread Starter
Plug in all the connectors from the kit and tidy them up
I routed the loom along the brake lever side and integrated it into the factory wire ties.
After taking the battery tender leads off I put the control box here
post #36 of 57 Old 02-13-2017, 11:11 PM Thread Starter
** Bonus Graves Block off plates **
While I had the tank and airbox off I decided to do the blockoff plates.
I have a California model with all the other emission crap attached to the throttle bodies so I removed it and capped off the extra 2 inlets with these caps from the 49 states model.
post #37 of 57 Old 02-13-2017, 11:43 PM Thread Starter
Cool
Now put the bike back together will look like this
Here's the sensor on the shift rod
This quick shifter has hundreds of kill times it can choose from for each gear so no setup is needed. Grab a coke and admire your work then take it for a test ride.
Sanctuary likes this.
post #38 of 57 Old 02-17-2017, 11:22 AM Thread Starter
This just showed up
So another fun filled weekend
Ohlins SD 042
post #39 of 57 Old 02-17-2017, 08:00 PM Thread Starter
**Ohlins Damper Install**
I couldn't wait until the weekend to put this on so here are the install pics.
The only unusual tool you'll need is a 12mm allen socket for the triple tree nut.
This is what you'll start with
Remove the insert to expose the allen socket then remove it
post #40 of 57 Old 02-17-2017, 08:00 PM Thread Starter
Now put the damper pieces together should look like this I used a little red Loctite
Then add the damper bracket
I changed the bolt that holds the damper one with a TI one
post #41 of 57 Old 02-17-2017, 08:01 PM Thread Starter
Add the Damper and check the clearances
Done
post #42 of 57 Old 02-23-2017, 07:44 AM Thread Starter
Time to get rid of that awful fender.
R&G to the rescue
Tail tidy with the led rear signals.
This is going on and I got a couple other items on the way.
post #43 of 57 Old 02-23-2017, 07:52 PM Thread Starter
** Tail Tidy Install **
Start here then take the panel off to expose the wiring.
Close up of the wiring
post #44 of 57 Old 02-23-2017, 07:52 PM Thread Starter
Wires all loomed up
Close up
All done
post #45 of 57 Old 02-23-2017, 07:53 PM Thread Starter
Neat and tidy
Finished product
Bennett636's new bike/ build thread Bennett636 The ZX6R 73 03-12-2017 07:02 AM
My Plasma Blue 2008 ZX6R “PLC ZX6R” Build Thread PLCZX6R The ZX6R 10 07-20-2016 08:36 AM
Sunshine and the Phoenix - A Build Thread PowerGroove Mechanical and Technical 35 06-02-2016 01:51 PM
03 636 Build thread Apollo 39 The Build Thread 10 11-16-2012 01:23 AM
