Brakes locked up, went down today. - Page 2 - ZX6R Forum
 14Likes
post #16 of 57 Old 04-20-2014, 05:58 PM
booter22's Avatar
I Ride: 2005 ZX6R - Green!
shit deal. but glad to see you are ok!
booter22 is offline
post #17 of 57 Old 04-20-2014, 06:16 PM
Trajiks6's Avatar
I Ride: 2013 636R Stardust White
Holy Smokes Mang! Good to see that you walked away with minor injury. I would double check to make sure you mounted the front wheel back on correctly. I haven't taken my Kawi front wheel off yet so, I am not sure if Kawasaki uses front wheel spacers.
I did make the mistake on my 2001 Honda CBR 929 of note putting the wheel spacers on the correct side. It resulted in brake drag but, not lock up. I swapped the spacer and wheel spun freely again. Hope for a speedy recovery and a quick repair of your bike.
Trajiks6 is offline
post #18 of 57 Old 04-20-2014, 06:57 PM
Chalkman's Avatar
I Ride: 03 636
Glad your ok man,it's a good day when we can walk away from something like this.Fix her up and get back in the saddle bro.Post some photos when you get her done.
Chalkman is offline
post #19 of 57 Old 04-21-2014, 11:27 AM
Glad you are okay man!
2009 ZX-6R (57,124 miles and counting)
post #20 of 57 Old 04-21-2014, 11:36 AM
Ebster1085's Avatar
Dont the 05/06 bikes have an issue with the master cylinder which cause the brakes to lock?
There is a known issue with the 05/06 MC but the issue causes the system to lose pressure which results in a soft lever. Have never heard about it causing the brakes to lock.
Originally Posted by jackflash View Post
Any suggestions on front caliper rebuild/replace aftermarket/replace with same or different year?
I would suggest you go the same route that myself and many others went and look for a set of 07-12 ZX6 calipers which are a direct replacement. They are supposed to be much better and can be found cheap on eBay.
jackflash likes this.
Track Bike: 2006 ZX6R
Daily: 2007 Speed Triple
A link to my build thread!
Ebster1085 is offline
post #21 of 57 Old 04-21-2014, 11:42 AM
ZxRican's Avatar
I Ride: 2002 ZX-6, 2006 ZX6R 636
Wow glad your OK, again more proof why ATGATT, is very important, you just never know.
How did your boots take the fall?
"Riding a race bike is an art - a thing that you do because you feel something inside."
-Valentino Rossi
ZxRican is offline
post #22 of 57 Old 04-21-2014, 11:45 AM
NitrusReigns's Avatar
Glad you're alright man!
I had this happen on a bike with the rear brake once...I think the aftermarket pads I put on were too thick and were rubbing just a bit the whole time I was riding and eventually it heated up (and expanded) the brake fluid which made my brake lock up...I don't know this for sure, it's just the best explanation I could come up with
NitrusReigns is offline
post #23 of 57 Old 04-21-2014, 11:48 AM
Brandon35's Avatar
Originally Posted by lowcel View Post
Glad you are okay. Did you take your brake lever off lately by any chance?
Rear brake locked on him guys
Superstitious? No, but I am a little stitious - Micheal Scott
Brandon35 is offline
post #24 of 57 Old 04-21-2014, 12:17 PM Thread Starter
jackflash's Avatar
I Ride: 06 zx6r
My boots and gloves were untouched, helmet had a little scratch. I think I have read every post known to man on the subject but hadn't thought about the pads being too thick.
ZxRican likes this.
jackflash is offline
post #25 of 57 Old 04-21-2014, 12:18 PM
Ebster1085's Avatar
Never heard of such a thing....
post #26 of 57 Old 04-21-2014, 01:52 PM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
OP had the front locked up...
....the front brakes completely locked up sending me over the bars,
If you had too thick pads, shouldn't it be dragging from the moment you installed them on the bike?
Although, if they dragged they should also have faster wear.
I've only witnessed drag to a friends gixxer who had some braking(<-brand) brake disks installed and they were thicker than stock brake disks.But even there, his brake didn't lock up, just the brake disk got a little blue-ish from the heat...
Also, on my 636 which i didn't have ss lines, if brakes got hot (going down a curvy mountain in summer) then it made my brake lever soft and i had less braking power.I know that was because of my stock brake lines, but it makes me hard to believe that you have the exact opposite result because you do have ss lines...
Maybe there is something wrong with your master cylinder and fluid doesn't go back to the fluid reservoir?I know that Suzuki that uses the exact same master cylinder made a recall for all models since 2004 and replaces master cylinder and brake lines for free.I wonder why...
Originally Posted by http://www.suzukicycles.com/Recalls/2004-2013%20GSX-R%20Master%20Cylinder%20Recall%20Notice.aspx
Recall: 2004-2013 GSX-R Master Cylinder Recall Notice
November 18, 2013
Model: All 2004 – 2013 GSX-R600 & GSX-R750 includes all special and limited editions, All 2005 – 2013 GSX-R1000 includes all special and limited editions.
Summary: 2004-2013 GSX-R Master Cylinder Recall Notice
MrZ is offline
post #27 of 57 Old 04-21-2014, 03:27 PM
Nyxesque's Avatar
I Ride: 2014 zx6r
Cruising down the a main road at about 65-70mph, I felt the 636 start to drag. I quickly switched to the outside lane and pulled in the clutch when....the front brakes completely locked up sending me over the bars, onto my shoulder and sliding down the road.
Wow... so glad you're alright! Sorry about your bike though.
~In a mad world, only the mad are sane~
=^.^= Youtube and Instgram =^.^=
Nyxesque is offline
post #28 of 57 Old 04-21-2014, 06:14 PM
hellonearth's Avatar
I Ride: 2007 zx6r :D
Cruising down the a main road at about 65-70mph, I felt the 636 start to drag. I quickly switched to the outside lane and pulled in the clutch when....the front brakes completely locked up sending me over the bars, onto my shoulder and sliding down the road. And now, to our feature presentation.
huygiang likes this.
hellonearth is offline
post #29 of 57 Old 11-16-2015, 01:12 PM
Well there went my theory. Good luck getting it figured out.
What was your theory ? My 2014 zx6r is having brake issues right after me taking the lever off an putting it back on .
Austin lit46 is offline
post #30 of 57 Old 11-16-2015, 02:08 PM
Hydraulic lock from overfilled master cylinder. A very common, and entirely avoidable, mistake.
PainfullySlo is offline
  ZX6R Forum > ZX6R Forum > Ride Reports
06 636 front brake locks up after market lever
06 zx6r slider install
2001 gsxr 1000 brakes lock up easy
2007 zx6r front brake locking up
front brakes locked up 04 636
zx6r brakes locked up
zx6r brakes locking up
Dropped my Bike today foosama The ZX6R 20 06-24-2014 04:38 PM
Bleed those brakes, its rude not to... Dirtmonky The ZX6R 16 11-27-2013 03:08 PM
front brakes locks up 2slow Mechanical and Technical 17 10-12-2012 09:22 AM
Spongy Brakes = old rubber lines? tomoney Mechanical and Technical 18 10-08-2011 03:15 PM
Laid dow my bike lastnight now no front brakes 05christj Motorcycle Talk 17 02-27-2011 05:13 AM
