Brakes locked up, went down today. - Page 4 - ZX6R Forum
 14Likes
post #46 of 57 Old 12-16-2016, 09:48 AM
Old post. Not a fan of the look. But to each his own.
the prophet is online now
post #47 of 57 Old 12-16-2016, 01:40 PM
I Ride: '12 zx6r track bike
I'm thinking it's spam - and a sales pitch from a new "member."
post #48 of 57 Old 12-16-2016, 06:31 PM
ZedExMuse's Avatar
As has been pointed out, the over filled reservoir is the most likely culprit. It's worse as it were with braided lines because they have a much more limited expansion than O.E. rubber lines.
There are two more things your are most likely guilty of: 1) You need to really clean the calipers, pull the pads completely out. Give the pins the once over with either steel wool or 0000 wet/dry sand paper. Pull the pucks out and give them the same once over. After the pockets are cleaned up lube the pockets that the pucks reside in. Do not over do, you absolutely want no grease on your rotor/pads. Be tidy in all bike related procedures.
2) Your made the other neophyte mistake: You did not clean your rotors - I'm not talking as quick wipe off with a spot of water & soap. You need to get yourself a hone that you insert into a drill and scour the compressed crap the previous pads left on the rotor. Your rotors need to be completely removed from the wheel in order to do this properly. Do not feel bad for not doing this. Most rookies ignore this step (note: wipe down the rotors w/isopropyl or acetone; or brake cleaner but wear rubber glove if you go this route.)
C8H10N4O2
ZedExMuse is offline
post #49 of 57 Old 12-16-2016, 07:21 PM
THUG's Avatar
"2 kINDS OF RIDERS" WELL DONE GLAD YOU ARE OKAY FAM !
JAMES 1:12
THUG is offline
post #50 of 57 Old 12-16-2016, 09:04 PM
I Ride: 2006 ZX6R 636
Did a little research last night and found out Puig makes the R12 frame sliders for my bike year but heard some just mediocre reviews on it from RevZilla. Was really hoping that the Puig Pro Sliders would fit but they won't. So I've narrowed my top three picks to be
1) Puig R12 frame sliders
2) OES Frame sliders
3) The knock off ali express aluminum frame sliders
Im more tempted to go with the OES mainly because they have a kit that comes with bar end sliders, front axle sliders, spools and the frame sliders.
However I like the look of the Puig R12 way better so Idk...
As well did a take a look at the spiegler LSL frame sliders but they happen to be the most expensive.
Any Ideas or thoughts on which ones you guys think I should go for?
ID:	52089   Click image for larger version
ID:	52097   Click image for larger version
ID:	52105   Click image for larger version
dr4ke is offline
post #51 of 57 Old 12-16-2016, 09:07 PM
LOL no sales pitch just looking for some ideas on frame sliders... Actually been a member for sometime just forgot what the password is for my old account and the email linked with it I no longer use...
dr4ke is offline
post #52 of 57 Old 12-16-2016, 09:36 PM
I Ride: 2014 Kawasaki ZX-6R
IMO Woodcraft, R&G, LSL and Motovation make good sliders.
In addition, I've been weary of using sliders since there have been various cases of them cracking the thin frame mounting points. I am currently using motovation frame sliders in conjunction with engine case covers and my thinking is they can reduce damage, given the crash is a "slide" and not a tumble or in a situation where it is knocked down. If there is excessive damage I'll just use my insurance coverage.
I've gone down with and without sliders and there was definitely less damage with them installed, but every crash is different so I always expect damage.
Martillo y Mantequilla #99
post #53 of 57 Old 12-16-2016, 11:29 PM
I have a few reviews of people describing how the frame slider cracked their frame which kind of worries me. I don't track my bike and have never been in any accidents. However, one hot summer day while at work I came out to find my bike toppled on its side. Found out that because of the immense pressure exerted on the stand and it sitting for a while on the hot asphalt it essentially melted in the asphalt causing it to collapse. Now had I had frame sliders the damage would probably been minimal if any. As I didn't it cracked my whole side faring and broke my turn signal and scuffed up my tail section. Anyhow I know from now on to carry a piece of wood to rest under my stand. Even so I'm still worried if it ever falls breaking fairings... Now that I've saved up enough money I'm doing the bike exactly how I want it. As it was originally stock. Meaning Blue New Monster fairings, new levers, new euro turn signals, new rearsets, new windscreen, new carbon fiber heel guards and wheel guards. But don't want it to go to waste if it gets dropped... So if frame sliders might crack the frame in the case of a crash would a cage do the same or no...
dr4ke is offline
post #54 of 57 Old 12-17-2016, 09:28 AM
Gawernator's Avatar
Woodcraft sliders are the way to go, especially the short ones or those that fit under the fairings. Their puck design is great,
Gawernator is online now
post #55 of 57 Old 12-17-2016, 12:38 PM
ZedExMuse's Avatar
Perhaps something less 'arty', and something decidedly more functional. I've road test these more times than I care to admit to with (2) R1s, (3) CBRs, & (1) ZX. I'd put nothing less on any bike I'd own.
www.woodcraft-cfm.com - KawasakiZX636RR0506FrameSliderBaseKitpuckssoldsepa rately
With these frame sliders, because the centre is not bored out, they hold up remarkably well, and all one has to do after a drop is order up a replacement puck.
I also use their Folding Toe pegs (brake & gear shift), Front Axel Sliders, Starter Idler Gear Assembly. Eric Wood is a racer, thus uses his experiences, plus those of his competitors to assist in his product development.
C8H10N4O2
post #56 of 57 Old 12-17-2016, 07:58 PM
Petrolsexual's Avatar
I Ride: 2009 ZX6R
Like you said, in minor accidents on a hard surface (asphalt, concrete, ...) frame sliders can help. But at my last race my friend low sided and went into the grass hauling ass. His frame slider dug in and got the combo bonus points, breaking both the frame and ripping open the cylinder head on the engine. So, I personally won't use them. A cage can rip your engine casing and frame apart just like a frame slider. Just depends on the crash.
Edit- And obviously any frame sliders that don't protrude past the fairings will be useless to you.
Petrolsexual is offline
post #57 of 57 Old 12-17-2016, 08:15 PM
Just ordered some sweet race rails from sick innovations. My thinking behind the race rails is that there is a less likely chance of cracking the frame because the pressure is spread out over a more broad surface area. Oppose to frame sliders as its one point that has to take the grunt of the impact. As for catching on surfaces and such I think there might be a greater chance in some situations like high siding but you're pretty much screwed in the event of a highside; In most cases it'll be totaled. Gonna cost me I little over $160 with tax and shipping but definitely think it's your best bet between frame sliders and a full on cage. Doesn't look nearly as bad as a cage either. At the end of the day I don't track my bike so no worries there and if something were to happen on the road or up in the canyons that resulted in a totaled bike, I'd go through my insurance.
dr4ke is offline
  ZX6R Forum > ZX6R Forum > Ride Reports
06 636 front brake locks up after market lever
06 zx6r slider install
2001 gsxr 1000 brakes lock up easy
2007 zx6r front brake locking up
front brakes locked up 04 636
zx6r brakes locked up
zx6r brakes locking up
Dropped my Bike today foosama The ZX6R 20 06-24-2014 03:38 PM
Bleed those brakes, its rude not to... Dirtmonky The ZX6R 16 11-27-2013 02:08 PM
front brakes locks up 2slow Mechanical and Technical 17 10-12-2012 08:22 AM
Spongy Brakes = old rubber lines? tomoney Mechanical and Technical 18 10-08-2011 02:15 PM
Laid dow my bike lastnight now no front brakes 05christj Motorcycle Talk 17 02-27-2011 04:13 AM
