refurbished or new shock??This is a discussion on refurbished or new shock?? within the United Kingdom forums, part of the Regions category; Hey guys, my 2003 636 rear shock has seen better days. The bike has only done 11,000 miles but has been left to battle the ...  |
07-23-2011, 01:29 AM
#1 | | Squid
Joined: Jun 2011 From: England Posts: 12 I Ride: 2003 zx636A1p | refurbished or new shock??
Hey guys, my 2003 636 rear shock has seen better days. The bike has only done 11,000 miles but has been left to battle the elements before i got it. The spring is rusty and looks tired. As i cant quite afford a top class after market job, would it be ok to get a new spring and re-gas the unit, rather than replacing it with a cheaper after market one??
Any help on this would be great !!!!!
07-23-2011, 02:55 AM
#2 | | Post Master General
Joined: Jul 2007 From: melbourne Posts: 10,221 I Ride: 1998 zx6r, 1999 sv650 |
you could if its cheap over there to get a newer shock of a 05/06 or even newer if there cheap?
08-07-2011, 09:56 AM
#3 | | Squid
Joined: May 2009 From: Lincolnshire,England. Posts: 86 I Ride: ZX6R. |
It`s about £100 to rebuild a shock,that includes new seals,check over,oil and a re-gas.The springs rarely need replacing but if you want to replace the spring because it looks bad,that will be around another £80-£100.
Nitron and hagon both do new aftermarket shocks for under £300.The Nitron shock has good reviews, is length adjustable and seems simple to set up with rebound and compression combined!!!
08-07-2011, 04:55 PM
#4 | | Track Star
Joined: Aug 2011 From: No.VA, USA Posts: 565 I Ride: ZX6, ZX10, BMW |
I have to agree with both of you....... depending on budget.
Used, but newer shock for under $150= win!
Rebuild and re spring your existing unit= Win Win!
If you have the cash, rebuilding yours to your weight and riding style would produce the most benefit. If you don't, a low mileage newer one is a good bet too.
08-07-2011, 06:40 PM
#5 | | Team Green
Joined: Sep 2010 From: Western, NY Posts: 166 I Ride: '03 636 |
I had the same problem. A bushing got all bound up inside and turned stiff as a rock. I bought a used shock on eBay for $28 and just tossed in a new spring. Guy told me a rebuild was about $200-$250. So I spent less than $140 for the shock, spring and setup (Had a local shop set the bike for my weight). Suspension is THEEE best upgrade I think I've ever done. She sits so smoothly in corners now.
08-07-2011, 08:11 PM
#6 | | Post Master General
what year shock did you get zx636r?
08-08-2011, 09:05 AM
#7 | | World Superbike Racer
Joined: Jun 2011 From: england Posts: 1,615 I Ride: zx6r 1997 streetfighter |
if its just down to looks then take spring off and powder coat it or spray it (clean it up well first)
also tidy up the shock unit while its in bits
08-08-2011, 10:30 AM
#8 | | Post Master General
Joined: Aug 2009 From: Looneyben escapee Posts: 8,368 I Ride: 2007 ZZR/ZX6R |
eBay. Iv got three low mileage ones in the last 4 years, An 07, 08 & now an 09.
All from ZX6Rs, there much better than the stock unit on your bike.
Even when it was new.
08-08-2011, 03:17 PM
#9 | | Team Green
Joined: Sep 2010 From: Western, NY Posts: 166 I Ride: '03 636 | Quote:
Originally Posted by arron what year shock did you get zx636r? | I bought one off an '04. The shock themselves aren't bad for everyday street-beating. The springs from the 03/04's are just too stiff for even the bigger people. Throw in a new spring and it feels way better.
08-09-2011, 01:23 AM
#10 | | Post Master General
I got a 07 shock and knuckle in the mail today and its going on my 98 from OND.. thanks mate |
08-09-2011, 02:25 AM
#11 | | Pro Racer
Joined: Apr 2011 From: Chesapeake, VA Posts: 849 I Ride: '06 ZZR600 fighter |
I grabbed an 09 ZX6R shock off of ebay for $54 shipped at the end of last year. I could NOT pass up that deal, and I'm glad I didn't. It is a lot better than the 06 unit I was running before, though I don't know how many miles were on that shock before I got it. Anyways 07 and newer ZX6R shocks are better than the 05/06, unless you get the 05/06 ZX6RR shock, which is supposedly the same performance as the 07/08.
09-15-2011, 04:29 PM
#12 | | Squid
Joined: Sep 2011 From: Northants Posts: 3 I Ride: RVF400, ZX6R, R6, CBR400rr x 3 |
I had my J1 done by K-Teck. Cost all in around £120. Had it done at 8000 miles as it felt sloppy. Has made the bike turn quicker but you lose comfort.
Now done about 24k and suspension still feels taut. Changed the fork oil for a higher grade too
09-18-2011, 01:11 PM
#13 | | World Superbike Champion
Joined: Mar 2011 From: weymouth dorset Posts: 2,076 I Ride: 2000 zx6r j1 |
iv ot one off my j1 that should fit fine and is in good conditon to drop maq a pm if u want it
| | | Search tags for this page | | 07 zx6r hagon shock review, 07 zx6r shock setting, 1997 zx6r rear motorcycle shock, 1997 zx6r shock, 2003 zx6r 07-08 shock, 2006 zx6r shock on sv650, 2007 zx6r shocks seal, 2009 zx6r rear shock spring, how the shock on zx6r, rear spring(1997 zx6r), refurbished 03 zx6r forks, spring shock zx6 send, zx6 rear shock leaking, zx6 rear suspension work, zx6r 09 shock tool, zx6r 636 shock rebuildable, zx6r shock rebuild
