| Integrated rear brake light and turn signals.
Hi all,
Just fitted an integrated rear brake light and turn signal to my 2005 model zx6r. All seems fine but the turn signals are blinking slower than before?
Are slow blinking indiactors an MOT failure?
The unit came from Hong Kong. Has the normal three prong terminal for the main unit. Only has one wire going to each turn terminal so I assume they are earthed within the light unit.
Any ideas? I have seen stuff about using a different relay if they flash fast, does the same apply if they flash slow?
