Check Your Wheel Alignment Zx6r - ZX6R Forum
post #1 of 12 Old 06-19-2008, 03:42 AM Thread Starter
I Ride: 2007 ZX6R
Exclamation Check Your Wheel Alignment Zx6r
Just checked my wheel alignment out for the first time, as i had to make a new set of straight edges up (my last set got bent). The marks on the blocks and swing arm were spot on, but in reality the front wheel was 10mm out. I have been reading on some of the forums about the need for steering dampers. If your wheels are not in a straight line then you will get all sorts of trouble and thus will need a damper. Correct wheel alignment is a lot cheaper.
I have been doing my chain tension with alignment bars for years, various bikes are differant amounts out, but my 07 zx6r is the worst one yet. I have only had one bike that had adjusters that were spot on. So be warned!
shamus is offline
post #2 of 12 Old 06-22-2008, 01:29 AM
amb67's Avatar
I Ride: ZX6R F3
Shamus,
What did you make your straight edges out of and how did you confirm that the straight edges are true?
amb67 is offline
post #3 of 12 Old 06-22-2008, 05:05 AM
Steve636's Avatar
I Ride: Kawasaki ZX6R B1H, Yamaha R6 09 Superstock, Aprilia RSV4 R
Don't use the notches anyway, first time i used em i lined it up looked at the wheel and could blatantly see that the rear wheel wasn't straight, just use mk1 eyeball nowadays
Thundersport GB, Superstock 600 #99
YouTube Channel
Steve636 is offline
post #4 of 12 Old 06-22-2008, 07:36 AM
Bryan's Avatar
I Ride: ZX6R J1
Yep I agree, I did mine using eye alignment and it handles great.
Bryan is offline
post #5 of 12 Old 06-22-2008, 01:09 PM
onebaddazzdj's Avatar
I Ride: 07 ZX6R
heres a good vid for those who have no idea on how to align a bike wheel
http://youtube.com/watch?v=RBxK-OQ--fg
onebaddazzdj is offline
post #6 of 12 Old 06-23-2008, 12:54 PM Thread Starter
I Ride: 2007 ZX6R
I got some square section aluminium extrusion from a metal suppliers (£22). I drilled them on the piller drill at work, 3mm then 10mm so you can put 10mm threaded bar through your back wheel with two nuts. Square section is usualy very straight but when you put the two together you can see if they are not straight. The method on the video on (this thread) is good. Which is cheaper.
Good luck
shamus is offline
post #7 of 12 Old 07-02-2008, 01:42 PM
ginger.ninja's Avatar
I Ride: ZX6R_G2
Yeap I use the string method and it works great!
ginger.ninja is offline
post #8 of 12 Old 07-03-2008, 12:56 AM
I Ride: 2007 ZX6R
flourecent light tube or lazer go kart aligner
geordieninja is offline
post #9 of 12 Old 07-03-2008, 07:53 AM
raized1199's Avatar
Good post Bro.
I dont think Ive never had a Kawai with accurate marks.
Remember...
are also timed for 70 mph.
-->Urban Assault Vehicle<--
raized1199 is offline
post #10 of 12 Old 07-03-2008, 06:20 PM
I Ride: Not a Kawasaki
Great Post - going to double check this weekend - have been relying on swingarm marks
dunx-hg is offline
post #11 of 12 Old 07-09-2008, 11:22 AM
amb67's Avatar
I Ride: ZX6R F3
I must have the one then!
Strung my bike to check the alignment and it was all fine, the marks on the swingarm are all spot on too.
It still feels as if it goes round a right hander bend better than a left hander, perhaps I'm just imagining it.
Thanks for the posts guys, came in handy.
amb67 is offline
post #12 of 12 Old 07-09-2008, 06:56 PM
Yeah checked it out with the string - the alignment was ok.
Have to adjust and lube chain very soon so will use string method from now on.
dunx-hg is offline
07 zx6 how to align rear rod
07 zx6r wheel alignment
2005 zx636 front wheel off center
alighment on a 04 kawasaki 636
check alignment on zx6r
how to align rear zx6r wheel
kawasaki 636 wheel alognment
kawasaki zx6r 1999 alingment
kawasaki zx6r wheel alignment
zx6r rear tire alignment
zx6r rear wheel alignment
Parts compatibility list ! Stiggy Mechanical and Technical 151 12-16-2016 10:23 PM
Kawasaki ZX6R Model Designations Lash The ZX6R 25 09-28-2014 10:26 AM
WTB: front wheel 05+ ZX6R or 06+ZX10R!!!! LarryJ Classifieds 3 04-29-2011 03:13 AM
FS: 2003- 2004 zx6r 636 wheel combo nolazx6r The ZX6R 1 07-02-2009 10:42 AM
