G1 or J1, is there any real difference? - ZX6R Forum
  • 1 Post By mJZ
  • 1 Post By scoobs
post #1 of 9 Old 01-25-2014, 12:16 PM Thread Starter
OK, so I have a tiny insignificant budget, but I want a 6R. I kinda like the J1 (I think its the twin headlight that does it) but there is (what looks like) a MINT G1 near me for sale, which is well within budget.
Is there any reason someone can give me that I will be missing out getting a G1 over a J1 (other than the headlight looking 10x better)?
Cheers in advance
Karl is offline
post #2 of 9 Old 01-25-2014, 12:29 PM
mJZ
mJZ's Avatar
I Ride: 2002 ZX-6R J2
A bit more power 112 bhp rather than 109, J is slightly lighter than G, rear tyre 180 (J) rather than 170 (G), added 5 grease nipples on swing arm and shock linkage in J, better generator and coils in J.
That's all I know about.. possibly more. J is just more refined. I would defo pay a bit extra to get J rather than G.. But do yourself a favour and get A1P
SteveZZR likes this.
mJZ is offline
post #3 of 9 Old 01-25-2014, 12:53 PM
weaponzero's Avatar
I Ride: 2000 Suzuki SV650 (Sold), 2006 Kawasaki ZX-6R SE (Sold), 2014 Yamaha FZ-09
The J had more power but the truth is it's a small amount 98% of riders would never notice. The biggest NOTICEABLE difference between them is that the J came with much better brakes, which were notoriously weak on the G. There were subtle differences but nothing you would notice unless you were highly skilled and pushed the limits.
weaponzero is offline
post #4 of 9 Old 01-25-2014, 12:54 PM
Baldeagle's Avatar
I Ride: zx6r a1p
If your budget is really tight then not much difference on the road
but
as mJZ says the little differences are worth the extra and the a1p does not have a bird cage plus a 636 carb'd engine.
good luck
Baldeagle is offline
post #5 of 9 Old 01-25-2014, 02:41 PM
scoobs's Avatar
I Ride: something naughty
I have put the differences down before but wont go into details now
a J model engine has a lot of light weight redesigned parts ie crank rods pistons etc over the g model .....it is a far superior engine
redesigned electrics even down to using stick pack coils ......
so no its not a g with twin headlights .....there is a lot more to it
valve cover ....sump......clutch cover etc made of magnesium
had an internally braced swinger which a g didn't have etc etc
the list is pretty long
an a1p is a j with a large cylinder bore ....and no birdcage......that's it
scoobs is offline
post #6 of 9 Old 01-25-2014, 04:57 PM
whocanitBnow's Avatar
I Ride: an OLD bike
swing arm is different between G & J
Yeah....I can try & make that for ya.
whocanitBnow is offline
post #7 of 9 Old 01-25-2014, 05:13 PM
arron's Avatar
I Ride: 1998 zx6r, 1999 sv650
The brakes are the same on the g-j just depends what pads and how you use them.. The g you can run a 180 rear tire cos I do and love it... Like anew people have said its a tad lighter and a bees dick more power but who can tell the difference right? You can do a twin head light conversion to the g to make it the same as the j if you can find the parts for cheap.. Any pics on this g you have found?
still lovin forever!
arron is offline
post #8 of 9 Old 01-25-2014, 05:48 PM
The G and J rear wheel is also identical so no issues at all putting the 180 tyre on.
Didn't realise A1P had no cage, lot of people get a ZZR 05-08 bracket for their J anyway so wouldn't have thought anything of it.
Its all a matter of skill, the F is a cracking bike and would keep up easily unless you're at the limit.
I ride an N reg E model (ZZR 600E) which is even earlier and I'm faster than a lot of people on much, much newer bikes.
One of my track pics has a 636C behind me I'd just burnd past on Park Straight at Cadwell
That was my first and only track day too!
Originally Posted by scoobs View Post
dave just tell her you are THE MAN and it was just a pair of nockers nothing more .......
then ask her did you pull over to the side of the road and flop your manhood out and thrash it uncontrollably.......NO
and then ask her did you stop the bus pull the girl out with amazing nockers throw her to the ground and plant your Little Dave into her cream donut......NO
so tell her its life things like that happen........... HAHAHAHAHA
SteveZZR is offline
post #9 of 9 Old 12-07-2016, 03:03 AM
Rab
Rab's Avatar
I Ride: ZX6-R 636 A1P
whats the difference would the hugger from a G fit a J?
Rab is offline
Difference in M4 GP Exhausts Scorpi0 Mechanical and Technical 2 05-08-2013 12:20 PM
Is there a sound difference between akra slip on and akra full exhaust system? ninja03 The ZX6R 21 11-06-2009 07:41 PM
Difference in width between 98 zx6r and 05 zx6r? DellsNinja The ZX6R 19 08-05-2009 03:57 PM
